Question about Belkin (F5D7050) 802.11a/g/b Wireless Adapter
BELKIN MISCONFIGURED? HI I'M HAVING PROBLEMS WITH MY WIRELESS ADAPTER,IT WAS WORKING JUST FINE AND NOW WHENEVER YOU PLUG IT IN TO ANY USB PORT IT READS IT AS A USB DEVICE AND NOT BELKIN WIRELESS ADAPTER LIKE IT IS SUPPOSE TO...I HAVE THE DISC. AND AM ABLE TO INSTALL THE SOFTWARE BUT IT STILL READS USB DEVICE WHEN THE FOUND NEW HARDWARE POPS UP. ANY POSSIBLE SOLUTIONS IN FIXING THIS WOULD BE APPRECIATED.
  • alwis Feb 05, 2008
    i have belkin same wireless adapter. when ever i plug to usb port it start to work fr two minutes and disconnecting. i tried to up date but i couldnt do it.any solution
    Genius:
  • 1,226 Answers
Uninstall the old installation of the driver and the restart the pc. disconnect the belkin and install the software of the belkin.After installation insert the belkin device and let the system detect it. if this act thesame then maybe you update the driver of your belkin here you can download: http://www.belkin.com/support/
Posted on Jan 24, 2008
Belkin 802.11a/b/g usb adapter
It sounds like the plug on the USB wireless dongle is bad or the usb ports in your computer are having problems. My Toshiba notebook does the same thing with the two usb ports near the front of the computer but works fine from the two on the back. When you have a flash drive plugged into the USB do you frequently get the new hardware found message as if you had unplugged and replugged the drive? If you have a powered external USB hub try plugging that in first then when that is stable plugging the USB wireless dongle into the hub rather than the computer. If it is stable then the problem is on the power pin in the USB port of your computer. Good Luck
May 10, 2009 | Belkin Pre-N 802.11g/b Wireless Adapter
Blue screen and Fatal Error
Have you tried plugging other devices into the same USB port? Try this to determine if the problem is with the port.
Apr 18, 2009 | Computers & Internet
Restored factory settings on pc & cant re -instal belkin adaptor
The Belkin site has very specific instructions for installing this adapter in a pc with Vista. These instructions are at: http://www.belkin.com/support/article/?lid=en&pid=F5D9050&aid=6112&scid=0
I would first unistall any Belkin Software that has already been installed, shut down the system completely and then restart. After you have fully restarted the system then follow the Belkin Site instructions EXACTLY. Any variation is apt to mean an unsuccessful install. Good Luck and have patience.
Nov 14, 2008 | Belkin 802.11g Wireless Desktop Network...
Wireless adapter used to work, then stopped, then worked again, now can't be detected...
you mean that the adapter is not being recognised by the pc as a usb device, this adapter works better on a usb2.0 port, not as well on a usb1.0 port, depending on how old your pc is, try other ports., but you must uninstal the belkin driver from add/remove programmes, then install the driver again and inset adapter in a different usb port than before.
the adapter should then be found and click install driver automatically, but leave the cd in the drive as it normally picks the driver up again from the disk on it's own even after installing it yourself.
When installed i would recommend using windows wireless zero configuration (windows own software) instead of the belkin software, to do this right click on the network icon and select enable WZC (windows zero config), as this is a more stable programme for connecting your adapter signal to the router
Personally Belkin is poor in my opinion, netgear has better software and drivers, but it's belkin you have, so follow the above and it should be ok.
Sep 09, 2008 | Belkin (F5D7050) 802.11a/g/b Wireless...
Belkin suddenly not working
have you reinstalled the Belkin drivers for the dongle to work?
Aug 20, 2008 | Belkin (F5D7050) 802.11a/g/b Wireless...
Belkin G+ Wireless USB Adapter
What OS (Operating System) are you using??
If it's Windows 2000, XP, Vista or 7, then they MUST have any USB device plugged into the SAME USB port, or it screws up the OS.
Try going to Control Panel (Classic View), then choose SYSTEM to get into Device Manager, go down to USB and see if ANY Belkin adapters are listed (assuming the USB adapter IS Plugged In) - if you see any listed, double-click the adapters and choose to uninstall then.
If that doesn't work, then reboot, pressing F8 repeatedly before the Windows "Splash Screen" shows up. After repeatedly pressing F8 on Boot Up, you should select SAFE MODE (just the choice that only says SAFE MODE). Once SAFE MODE comes up, open Device Manager the same way you did before, then go down again to USB and Delete ANY & ALL Belkin USB adapters listed.
Then reboot and see it it recognizes the Belkin USB adapter now and hopefully will let you setup it's Software.
If you like this, please RATE me .... Thanks
May 18, 2008 | Belkin F5D7010TTSN-W WIRELESS 802.11G...
Belkin adapter F5D7051
i would think its the usb slot your using maybe its shot. if you use the extender thing you could try not using it and reinstalling. when reinstalled just plug the usb directly into it.
Nov 27, 2007 | Belkin (F5D7050) 802.11a/g/b Wireless...
Can not identify Belkin N1 Wireless USB Adaptor on PC
Hi, A couple of things: 1. Have you tried all the USB ports of your desktop PC (front and back)? 2. What is your desktop PC brand/model or at least the motherboard? and What OS please?; 3. If running Windows in the desktop PC, can you please check in your Device Manager if your USB are 2.0? 4. Are you using a USB hub or directly connected to the PC's USB port? Hope this be of some idea/help. Pls post back with your desktop brand/model/motherboard. Good luck and kind regards.
Sep 16, 2007 | Belkin N1 Wireless USB 2.0 Network Adapter...
Belkin (F5D7050) 802.11a/g/b Wireless Adapter Logo
251 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
