Question about SanDisk Sansa c250 (2 GB) MP3 Player (SDMX7-2048)
Sansa C200 connection problem
I've had my C250 for one year with only minor problems. Now when I connect it to my computer it appears to go into a "Loop" ( My computer recognizes it over-and-over-and-over... again), and it never stops or goes into the Sansa/Rhapsody site which I've used all along.
Please help.
  • Anonymous Feb 15, 2008
    Thank you for your suggestion; however, the problem is not solved. After going through the entire process the display on the C250 says:
    Please connect USB
    Mini-B->Device Mode
    USB 2.0 MSD
    LUN 0 Locked
    LUN 0 Unlocked
    SCSI Cmd #2
    SCSI Cmd #2
    SCSI Cmd #2
    SCSI Cmd #2
    ...over-and-over-and........
  • 4,102 Answers
Hi read my next post i tell you what you need to do just give me 2 min ok
Posted on Feb 14, 2008
  • paul proctor Feb 14, 2008
    Hi what you need to do is install the latest firmware to do this you need to goto the sandisk site and download the newest firmware this will solve any problems you have but to do this you need to put the device into recovery mode but before you do this download the firmware and follow the installing instructions after downloading it then select it it will ask you to connect the mp3 but before you connect it you need to do this only follow these instructions if you have downloaded the firmware and your comp is asking you to connect the mp3 player ill list the recovery mode procedure now ok but download firmware first and start the firmware when asks connect mp3 do this just before ok.
    1. with mp3 switched off push lock button to on so that keys are locked
    2. hold down rec button on the left hand side keep holding down.
    3. whilst holding rec button down then press on but keep holding down rec.
    Now your device should be in recovery mode now connect to computer when your comp asks you to this will then take you through the recovery procedure if after doing this you still have problems but you shouldnt but if you do uninstall the software that came with mp3 then reinstall and try it again but you should have solved your problem before you need to do this ok.
    Let me know how you get on or if you need further assistance ok
  • paul proctor Feb 15, 2008
    Hi then th problem is going to be an internal one its sounds like rom mem on the mp3 player has failed or shorted this could be due to the device getting banged or damp or anything along these lines even the part on the actuall mp3 player could be faulty witch is more than likely in your case.
    What you need to do now is contact their customer support either by email or by phone and they will tell you where to take it to get it fixed.
    you shouldnt have to pay as the problem is more than likely a fault then something you have done so they will repair or replace for free as their customer service is good you should have no problems let me know how you get on ok
6ya staff
SOURCE:
I'am having problems with my sandisk sansa c250, when i plugued in the computer at first it recognize the divice but after a minute it doesn't recognize the sansa c250 and i been serching for the driver...
The support site for the Sansa c200 series is listed here:
http://kb.sandisk.com/app/answers/detail/a_id/4487#c200
important
Take notice of the manual, how to connect and disconnect.
When having problems with the player, first try resetting the player as told in next link:
http://kb.sandisk.com/app/answers/detail/a_id/189
Updating firmware will erase all data from the player !
Verify your version player selecting the manual and when manually updating the firmware of the player.
For easy updating, use the automatic Sansa Firmware Updater.
Need more help ? Just post a comment.
Dec 24, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
Sansa device is not displayed on my computer
If it is connected to the PC, then this is normal.
If it is not connected to the PC, reset the device.
Here is a link to your user's manual: which shows you the reset:
http://www.sandisk.com/sansa/assets/English/products/c200/c200_userguide_en.pdf
-Tha Mp3 Doctor
Mar 23, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
My Sansa c250 is not seen by my computer. the drive has a yellow exclamation mark
Sansa c200 series – Computer/OS Not Recognizing
Connect the device to the PC in MSC Mode
View/c200: Turn on then press and hold the rewind button while plugging to the PC
If that fails, unplug the Sansa from the computer. Uninstall all the Sansa software in the add/remove programs section of Control Panel. Reinstall the clean version of the software from Sandisk’s website – make sure you get the files for the c200 series. Then replug the Sansa and try again. The root of the problem is that Sansa has one set of drivers and Windows has another. If you plug the mp3 player into the computer before installing the Sansa drivers, the Windows drivers will trump the Sansa’s.
Here is a helpful link from Sandisk on the problem with extra information on Vista operating systems:
http://kb.sandisk.com/cgi-bin/sandisk_en.cfg/php/enduser/std_adp.php?p_faqid=42&p_created=1221328944&p_sid=8VPwlRmj&p_brand=sansa&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9NzQsNzQmcF9wcm9kcz00JnBfY2F0cz0mcF9wdj0xLjQmcF9jdj0mcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1jMjAw&p_li=&p_topview=1
-Tha Mp3 Doctor
Dec 31, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
USB not getting recognized
-Tha Mp3 Doctor
Free memory
Format
This will format your Sansa c200 player’s internal memory
1) Select Settings from the Main Menu.
2) Select Format
3) Select Yes to format the internal memory or No to cancel.
-Tha Mp3 Doctor
-Tha Mp3 Doctor
Aug 03, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Please free memory
-Tha Mp3 Doctor
Sansa c240
-Tha Mp3 Doctor
Jul 29, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Sansa
-Tha Mp3 Doctor
Jul 21, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Cannot upload music to my sansa c200
Try plugging in the player(turned off) before you turn on the computer.
Feb 10, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Cant load songs
the best way for that is to read your manual.
MINIMUM SYSTEM REQUIREMENTS
Windows XP SP1
Windows Media Player 10
Intel Pentium class PC or higher
CD-ROM drive
USB 2.0 port required for hi-speed transfer
CONNECTING AND TRANSFERRING
Connect to your Computer
1. Connect the small USB Cable Connector to the USB port on your computer, and then plug the larger
Cable Dock Connector in to your Sansa c200 port.
2. Once connected to computer, it should be detected by the operating system automatically and is
shown as an additional drive called “Sansa c200”.
SANSA MEDIA CONVERTER
You will need to use Sansa Media Converter to transfer photos to your Sansa c200. Insert your SanDisk
CD and select Sansa Media Converter to install it to your PC. Then you can load your personal photos
onto your Sansa c200 by using Sansa Media Converter.
TRANSFER MUSIC
To transfer music to your Sansa c200:
1. Connect Sansa c200 to the computer.
2. Drag and drop files from your computer to Sansa c200 by using a variety of music software
programs to transfer/synchronize your files.
3. In MTP mode as long as the files are WMA or MP3, they can be dragged into the Media folder.
Otherwise, they can be dragged into the Data folder (these files will not appear on the player).
4. In MSC mode, files/folders can be dragged/copied to the device.
Jan 27, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
SanDisk Sansa  c250 (2 GB) MP3 Player (SDMX7-2048) Logo
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
