Question about Maytag (MFI2568AEW) Bottom Freezer French Door Refrigerator
CONTROL PANEL REMOVAL
How do remove control panel cover and replace control panel?
model:MFI 2568 AES
noavatar_s.png Navycpowif
Rank:nonexpert_s.gif Apprentice
Rating: 100%, 1 votes
This is NavyCPOwif- As you read above I have a crazy Maytag H20 as well!
I am a research person so looked around a little last night and found a site. for DIY folks. Every one is halving the same problem. I suggest a civil action suit !!! But in the mean time I am going to have my Navy Avionics Technition husband tackle it rather then deal with Maytag right now. " cost almost as much as a military fighter jet, so he should be able to do it!" BUt I wanted to pass this information along to other DIY folks out there. We have not done it yet since ours just went crazy Friday night. So we disconected the door /water connection. But everything else seems to be working fine at this point. Serious about the class action suite!!! these should be recalled we bought ours in GA June 2006 so it seems that the ones made in the 2006 time frame are the ones with the issues- I assuem that the folks that are having problems with in the 7 8 month time frame have the same lot due to ours is 18 months old but we paid $2600 were some have paid $1500.00. So not sure but something needs to be done becouse the list of other issues with this fridge seems pretty long and very expensive.... Good luck!
Site to fix panel issue: for $3 to $20- DIY:
I have just fix my maytag M#MFI2568AEB at a cost of $3.00 Believe or not. You need to go to website hhttp://68.195.103.87:8083/liny/maytagice2o.htm Everything you need is on the site. (yes gets Maytag off the hook, but gets your fridge going quicker)
DIY site for those interested:
http://forums.partselect.com/refrigerator-freezer-repair/maytag-ice2o-digital-board-going-crazy-3189.html
Comment by Navycpowif, posted on Jan 17, 2008 We fixed our ourself with the information I posted above- cost was $5. no problems.... no new panel just 2 circuits.
Posted on Jan 24, 2008
How do I remove the center console where the heater control switches are located on a 2006 Pt Cruiser GT
DESCRIPTION A manual temperature control (MTC) single zone type heating-A/C system or a manually controlled heater-only system is standard equipment on this model, depending on market.
To maintain the performance level of the heating, ventilation and air conditioning (HVAC) system, the engine cooling system must be properly maintained. The use of a bug screen is not recommended. Any obstructions in front of the radiator or A/C condenser will reduce the performance of the A/C and engine cooling systems.
The engine cooling system includes the radiator, thermostat, radiator hoses and the engine coolant pump. Refer to 7 - Cooling for more information before opening or attempting any service to the engine cooling system.
All vehicles are equipped with a common heater, ventilation and air conditioning (HVAC) housing (1). The heating-A/C system combines heating, ventilating and A/C (if equipped) capabilities in a single HVAC housing mounted within the passenger compartment beneath the instrument panel. The HVAC housing includes:
  1. Mode-air doors (2)
  2. A/C evaporator (A/C system only) (3)
  3. Recirculation-air door and actuator (A/C system only) (4)
  4. Blower motor (5)
  5. Mode control cable (6)
  6. Temperature control cable (7)
  7. Heater core (8)
  8. Blend-air door (9)
On heater-only systems, the A/C evaporator is omitted from the HVAC housing and is replaced with an air restrictor plate.
Based upon the system mode selected, conditioned air can exit the standard heater-only or optional heater-A/C housing through one or a combination of the three main housing outlets: defrost, panel or floor. The defrost and panel outlets are located on the top of the HVAC air distribution housing and the floor outlets are located on each side of the distribution housing. Once the conditioned air exits the HVAC housing, it is further directed through molded plastic ducts to the various outlets within the vehicle interior. These outlets and their locations are as follows:
  1. Defroster Outlet- A single large defroster outlet is located in the center of the instrument panel top cover, near the base of the windshield.
  2. Side Window Demister Outlets- There are two side window demister outlets, one is located at each outboard end of the instrument panel top cover, near the belt line at the A-pillars.
  3. Panel Outlets- There are four panel outlets in the instrument panel, one located near each outboard end of the instrument panel facing the rear of the vehicle and two located near the top of the instrument panel center bezel.
  4. Front Floor Outlets- There are two front floor outlets, one located on each side of the center tunnel near the dash panel.
  5. Rear Floor Outlets- There are two rear floor outlets, one located on each side of the floor panel center tunnel near the front of each rear seat foot well.
  6. REMOVAL
    WARNING: Disable the airbag system before attempting any steering wheel, steering column, or instrument panel component diagnosis or service. Disconnect and isolate the negative battery (ground) cable, then wait two minutes for the airbag system capacitor to discharge before performing further diagnosis or service. This is the only sure way to disable the airbag system. Failure to follow these instructions may result in accidental airbag deployment and possible serious or fatal injury.
    NOTE: Illustration shown with instrument panel removed for clarity. (Refer to 23 - Body/Instrument Panel/BEZEL, Instrument Panel - Removal).(Refer to 24 - Heating and Air Conditioning/Controls/CONTROL, A/C and Heater - Removal).(Refer to 23 - Body/Instrument Panel/COVER, Steering Column Opening - Removal). 5. Remove the screw (1) that secures the temperature control cable (2) to the left side of the HVAC air distribution housing (3). 6. Disconnect the temperature control cable from the blend door pivot lever (4) and remove the cable from the vehicle.
    REMOVAL
    WARNING: Disable the airbag system before attempting any steering wheel, steering column, or instrument panel component diagnosis or service. Disconnect and isolate the negative battery (ground) cable, then wait two minutes for the airbag system capacitor to discharge before performing further diagnosis or service. This is the only sure way to disable the airbag system. Failure to follow these instructions may result in accidental airbag deployment and possible serious or fatal injury. (Refer to 24 - Heating and Air Conditioning/Controls/CONTROL, A/C and Heater - Removal).(Refer to 08 - Electrical/Clock - Removal).(Refer to 08 - Electrical/Power Windows/SWITCH, Power Window - Removal).(Refer to 24 - Heating and Air Conditioning/Distribution/OUTLET, Air - Removal).
Oct 31, 2016 | Cars & Trucks
How do I remove the cover on my snow blower?
If you could supply a make and model number someone may be able to assist you.
Nov 24, 2014 | Cars & Trucks
How to access/replace the vent selector(defroster) ?
buy one
and install it.
it has clamps remove them or unsnap them and .....
access? its in the dash.
the FSM covers all HVAC work , you can get that and read it
or hope that ALLDATA.com covers R&R for the cables.
but will cover access. (huge job on some cars)
working on the dash with out and FSM invites more broken parts.
plastics.
hidden screws and such , and how to get to them are covered in the book.
here is the control panel, pasted
Removal & Installation
  1. Remove the upper console panel.
  2. Remove the instrument cluster finish panel
  3. Release the 2 fitting claws and pull out the heater control assembly.
  4. Using a screwdriver, open the claw of the cable clamp and disconnect the defroster damper control cable. NOTE Be careful not to bend the cable wire. If the cable wire bends, the heater control assembly operationally becomes worse.
  5. Using a screwdriver, open the claw of the cable clamp and disconnect the air mix damper control cable.
  6. Disconnect the connector, remove the heater control assembly. 42050_coro_g0008.gif Removal and installation of the control panel
To install:
  1. Install the inner cable end of the air mix damper control cable to the heater control lever.
  2. Install the outer cable of the air mix damper control cable to the cable clamp. NOTE Be careful not to bend the cable wire. If the cable wire bends, the heater control assembly operationally becomes worse.
  3. Operating the heater control knob and check that it properly stops at both ends of MAX. COOL and MAX. HOT and no recoil is identified.
  4. Check that the outer cable should not be disengaged (moved) from the heater control assembly when the cable is pulled.
  5. Install the inner cable end of the defroster damper control cable to the heater control lever.
  6. Install the outer cable of the defroster damper control cable to the cable clamp.
  7. Operating the heater control knob and check that it properly stops at both ends of FACE and DEF and no recoil is identified.
  8. Check that the outer cable should not be disengaged (moved) from the heater control assembly when the cable is pulled.
  9. Connect the connector, install the heater control assembly.
  10. Install the instrument cluster finish panel
  11. Install the upper console panel.
Dec 13, 2013 | 2005 Toyota Corolla
Removal of operator control panel on lexmark c935
You will need to remove the top cover and a couple of screws to remove the operator panel. However, we do not suggest that you do this yourself. There are a lot of wires involved in removing the operator panel. I suggest you call our Technical Support Hotline on 1-800-539-6275 to request assistance.
Aug 13, 2012 | Lexmark C935dn Laser Printer
Removing the heater control switch 2004 Pontiac Grand Prix
Procedure for the control panel pasted below. I don't see a separate blower switch, so you might have to replace the entire control panel. Before doing that, I recommend you browse this post:
http://www.fixya.com/cars/r6234839-doesn_t_heater_or_air_conditioner_blow and let me know if you have questions.
  1. Disconnect the negative battery cable.
  2. Remove the instrument cluster trim plate, using the following as a guide:
    1. Remove the instrument panel access hole covers from the instrument panel using a small flat-bladed tool. Remove the screws from each end of the instrument panel cluster trim plate.
    2. Remove the screws from the lower edge of the right lower instrument panel trim plate.
    3. Open the instrument panel compartment door.
    4. Pull the right lower instrument panel trim plate from the instrument panel.
    5. Pull steering column tilt level and tilt the steering column to the lowest position.
    6. Grasp the instrument panel cluster trim plate at the right edge, slowly pull an working from left to right, release the retainer clips. Lift the trim panel from the vehicle.
  3. Remove the screws holding the heater & A/C control panel to the instrument panel and gently pull the assembly from the instrument panel. Detach the electrical connector(s) from the back of the panel. Some models may have a vacuum line connection that must also be removed.
  4. Installation is the reverse of the removal process. Use care to make sure the retaining clips are properly seated and all screws are in place. This helps avoid rattles and squeaks later.
CAUTION Vehicles covered by this manual are equipped with a Supplemental Inflatable Restraint (SIR) system, which uses an air bag. Whenever working near any of the SIR components, such as air bag module, steering column and instrument panel, disable the SIR.
Fig. Instrument panel accessory trim plate removal-Pontiac shown, others similar
Fig. Heater & A/C control panel removal. Top: Standard system; Bottom: Automatic System-Pontiac shown, others similar
Oct 11, 2011 | 2004 Pontiac Grand Prix
Need to put passenger miror on. i need help to show me how to take the door panel off.
Section 01-05: Trim, Interior 1998 Windstar Workshop Manual REMOVAL AND INSTALLATION Procedure revision date: 01/22/1999 Trim Panel, Door Front
Removal
  1. Remove door latch cover by prying from top edge and pulling trim free of retaining clips and sliding trim away from latch.
  1. Remove portion of armrest containing door lock switch and window regulator control switch (14529) by pulling straight up.
  1. Remove rear view outside mirror mounting hole cover assembly by prying at top and pulling upward to release double-sided clip.
    Trim Panel
    Item Part Number Description 1 23942 Front Door Trim Panel 2 56908-S58 Screw (1 Req'd), Right Door 56906-S58 Screw (1 Req'd), Left Door 3 18B978 Radio Speaker Grille Name Plate 4 56911-S58 Screw (1 Req'd) 5 17D720 Cover Assembly Rear View Outside Mirror Mounting Hole
  1. Remove screw attaching front door trim panel (23942) to front door (20124) under switch plate.
  1. Remove two screws located at bottom of front door trim panel.
  1. Disconnect the door lock switch (14028) and window regulator control switch electrical connectors.
  1. Remove door window regulator handle if equipped by unsnapping and pivoting away the handle cover from base to expose retaining screw. Remove screw from the door window regulator handle.
  1. Pull front door trim panel from the top to release hooks from front door .
  1. Remove front door trim panel.
Installation
  1. Replace any bent or damaged fasteners.
  1. Follow removal procedure in reverse order.
Body Side
Removal
  1. Remove door handle retaining clip by sliding a shop towel between handle and door trim. With tension on the cloth, pull one end of the cloth so it slides between the handle and the door trim. If handle does not come out, reverse direction.
  1. Unfasten 13 christmas tree fasteners using double-acting spring-loaded trim removal tool and pull body side trim panel from body side door.
  1. Remove forward and rearward mating sections from under window trim.
Installation
  1. Replace all christmas tree fasteners.
  1. For installation of handle, install clip to handle, then push handle onto shaft to snap in place.
Back
Removal
  1. Disconnect rear window defroster wires.
  1. Remove the liftgate window garnish moulding as described.
  1. Remove screws attaching liftgate handle to liftgate and liftgate inside trim panel.
  1. Using Rotunda Windshield and Moulding Trim Removal Kit 107-R0401 or equivalent, pry pushpins retaining liftgate trim from the liftgate.
  1. Remove liftgate trim.
Installation
    Liftgate
2010&c18=modelyear&c35=wsm%2ctrim%20panel%2c%20door%2csww%2c01-05%2cremoval%20and%20installation&s=1366x768&c=32&j=1.3&v=y&k=y&bw=995&bh=405&ct=lan&hp=n&[aqe]
Mar 07, 2011 | 1998 Ford Windstar
How to install a blower moter and fan
Well, here's the instructions from the service manual. The labor guide says this can be done in 1.6 hours...I don't see how, unless the instructions are wrong about having to remove the instrument panel. My thoughts are that if you are only doing the blower motor, the blower assembly will come out without pulling the dash. You probably only have to do a partial disassembly and remove the glove box and the glove box lower support.
BLOWER ASSEMBLY
Removal and Installation
1. Disconnect battery ground cable. Remove Instrument panel. (See Instrument Panel Removal) Disconnect resistor connector. remove blower assembly duct. Disconnect motor connector. Remove blower assembly
2. Remove blower assembly screws and blower motor assembly. Remove clip and fan from assembly. Separate motor case and remove blower motor. To install, reverse removal procedure.
INSTRUMENT PANEL
Removal
1. Disable air bag system. See AIRBAG RESTRAINT SYSTEM article in ACCESSORIES/SAFETY EQUIPMENT SECTION. Disconnect negative battery cable. Scribe mating marks on steering wheel and shaft for installation reference. Using Steering Wheel Remover (J-29752) remove steering wheel. Remove steering cowl.
2. Remove instrument panel grilles and plug, or driving pattern indicator panel (A/T Models). Disconnect electrical connections. Remove instrument panel hood, instrument cluster ezel and instrument cluster. Remove hood release handle. Remove knee protector.
3. Remove dash fuse/relay block and side trim. Remove engine control module box. Remove radio console and glove box lower reinforcement. Remove speaker covers and glove box. Remove heater control panel knobs and cover. Disconnect heater control cables, and remove heater control panel. Remove illumination control knob. Remove instrument panel.
Installation
1. Install instrument panel. Install and adjust heater control cables. To complete installation, reverse removal procedure. Ensure mating marks on steering wheel and shaft align. Apply grease to contact ring and tighten steering wheel nut to 26 ft.lbs. (35 N.m).
Feb 28, 2011 | 1995 Isuzu Rodeo
How to remove front dopr panel on 1995 Lincoln Town Car
Front Door Panel - Town Car - Removal
CAUTION: To avoid breakage of door pull cover(s), insert a screwdriver diagonally between pull strap and chrome bracket. Snap out both sides then remove.
Snap out two door pull strap retaining screw covers. Remove screws.
Remove two screws on front and rear side of front door trim panel.
The following procedure must be used during removal and installation of the door armrest and trim panel. Refer to the appropriate illustrations for component and vehicle model identification.
Using the Trim Pad Removing Tool from Rotunda Windshield and Moulding/Trim Removal Kit 107-R0401 or equivalent, pry the trim panel retaining clips from the door inner panel.
NOTE: Do not use front door trim panel (23942) to remove trim clips from door inner panel. Replace any bent, damaged or missing push pins.
Remove window regulator control switch housing from back of front door trim panel . Lift up housing, remove retaining screws and disconnect all connectors.
Disconnect driver seat regulator control processor switch (driver door only) if equipped.
Twist out interior lamp wire assembly and remove the front door trim panel.
Installation
Ensure plastic watershield is secured to door panel.
Position front door trim panel to door. Connect interior lamp wiring.
Position the window regulator control switch housing and connect switch connectors. Install the retaining screws.
Connect driver seat regulator control processor (14C708) (driver door only) if equipped.
Align door lock side to its mating slide on the sheet metal (front doors only).
Snap in front door trim panel. Ensure all retainers fit properly.
Install two retaining screws on front and rear side of front door trim panel .
Install two retaining screws and pull strap covers.
Good luck Remember rated this).
May 31, 2010 | Lincoln Town Car Cars & Trucks
Need a diagram for installing a drivers side electric power mirror on a 1995 mercury villager van
here's 1996, all I have. Please rate.
Mirror, Power — Outside Rear View NOTE: This procedure applies to both RH and LH power outside rear view mirrors.
Removal
  1. Remove the front door trim panel (23942). Refer to Section 01-05 for the removal procedure.
  1. Remove the two outside rear view mirror inside mounting hole cover screws and the outside rear view mirror mounting hole cover (17K709) from the front door (20124).
  1. Remove the wire clip.
  1. Disconnect the power outside rear view mirror electrical connector.
  1. Remove the three power outside rear view mirror bolts and the power outside rear view mirror.
Installation
To install, reverse the removal procedure. Tighten the three power outside rear view mirror bolts to 3-4 Nm (27-35 lb-in). Glass, Outside Mirror
Refer to the glass replacement procedures in Manual Mirror for power outside rear view mirror glass (17K707) Trim Cover
Removal
  1. Remove the front door trim panel. Refer to Section 01-05 for the removal procedure.
  1. Remove the two outside rear view mirror inside mounting hole cover screws.
    Remove the outside rear view mirror mounting hole cover.
Installation
To install, reverse the removal procedure. Mirror Control
Removal
  1. Use a small flat-blade screwdriver to pry the power outside rear view mirror control switch from the instrument panel (04320).
May 13, 2010 | 1995 Mercury Villager
Need to remove drivers door panel
please rate if this helps. Section 01-05: Trim, Interior 1995 Thunderbird, Cougar Workshop Manual REMOVAL AND INSTALLATION The interior trim component Removal and Installation procedures generally apply to all models. If some of the steps do not apply to the particular models being serviced, proceed to the next step. Trim Panels, Door Removal and Installation
  1. ssd~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not pry front door trim panel (23942). Prying on front door trim panel will break the hook retainers.
    Disconnect battery ground cable (14301) .
  1. Carefully pull front door trim panel finish panel (23712) away from front door trim panel .
Item Part Number Description 1 23713 Front Door Trim Panel Finish Panel 2 17B676 Outside Rear View Mirror Control 3 14028 Door Lock Switch 4 55928-S55 Screw (5 Req'd) 5 14529 Window Regulator Control Switch 6 23942 Front Door Trim Panel
  1. Disconnect wires from front door lock switches (14017), outside rear view mirror controls (17B676) and window regulator control switches (14529) , if equipped; remove front door trim panel finish panel.
  1. Remove front door trim panel retaining screw through front door trim panel finish panel opening.
    Trim Panels, Door
    Item Part Number Description 1 20124 Front Door 2 23942 Front Door Trim Panel 3 383356-S100 Nut (2 Req'd Each Side) 4 56903-S58 Screw (2 Req'd Each Side)
  1. Remove interior lamp lens cover.
  1. Remove screw through interior lamp opening.
  1. Slide front door trim panel upward to disengage hooks.
  1. Rotate top of front door trim panel away from front door (20125) , and lift bottom hooks from front door.
  1. Disconnect window regulator jumper wire (14A630) .
  1. To install, reverse Removal procedure.
May 07, 2009 | 1994 Mercury Cougar
Maytag (MFI2568AEW) Bottom Freezer French Door Refrigerator Logo
5,160 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
