Question about Toshiba MW27F51 27 in. TV/VCR/DVD Combo
MW27FP1 MY TELEVISION DISPLAYS BLURRINESS AND A VERY DARK PICTURE. PLEASE LET ME KNOW IF IT'S SOMETHING I CAN DO TO FIX THIS PROBLEM. THANK YOU
  • 579 Answers
If you promise not to touch the wrong thing, you can adjust the screen and focus knobs on the high-voltage transformer (what we call the flyback). Do you see the big red wire going to the CRT tube? That is the anode lead of the high voltage (around 25,000 volts). The thing that it goes to on the circuit board has 2 little knobs coming out the back of it. Try adjusting those (use a tool with insulated handle if you please) to increase the brightness and improve the focus. When the screen adjustment is all the way up and it is still too dark - then its time for a new TV.
Posted on Jan 24, 2008
Lg flatron w2353vp
make sure the 'VGA' lead is plugged in properly. if still dark turn up the brightness on the monitor. if still dark after that, go onto the computer settings and turn up the brightness on the display settings.
Hope this helps!!!
Feb 21, 2014 | Computers & Internet
Telefunken picture
picture problem. might be the connection internal is loose
Jun 04, 2013 | Televison & Video
Wega KDF-50WE655 has purple spots, support says wega engine bad
I have over 10 years experience in electronic tech support.
I know this isn't what you want to hear, but the problem you've described sounds like one of the circuit boards that control the picture quality needs to be replaced. The cost of the board would likely be in excess of $200. There are usually several boards in a TV like that that control the picture and when one goes, you can get anything from lines in the picture to poor picture quality from blurriness. The main question is do you want to spend $1000 to fix a used TV?
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Jul 04, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Shadowing and blurriness
needs a convergence board repair, not too hard to fix if you are handy with a soldering iron.
get the 2 convergence chips for this model @ partsstore.com
Mar 19, 2009 | Hitachi 50FX30B 50" Rear Projection...
Dark picture
are you using the s-video input
Jan 10, 2009 | RCA P52926 52" Rear Projection Television
I have a sony 61HS10 rear projection tv. The small displays work, showing two or more pictures at the same time but when you want to display just one large full screen picture there is sound but no pi
As you told big picture freeze is working ,then there could the problem in the main processors which not to able pick video input signal ...If you would like to attempt a DIY, you will need a service manual to guide you. You can find one here:http://servicemanuals.vstore.ca/ which also contains the part number incase you need a new part...
Good luck.....
Dec 06, 2008 | Sony KP-53HS30 53" Rear Projection...
NO PICTURE.
When tv shows dark picture or Lamp LED start flashing at front of tv then you need to replace Lamp.
Now let me know do you get blue screen on all video inputs or just on cable / antenna ?
It would be nice if can paste picture of tv showing problem to understand easily, like I'm pasting your tv picture as reference.
Thank you.
Oct 07, 2008 | Sony KDF-55WE655 55" Rear Projection...
Picture is Dark on all stations
It sounds like a bulb. I would call toshiba and ask them what the replacement part is for that. I briefly googled for it but couldn't find the matching bulb for the 46H83
Dec 12, 2007 | Toshiba 46H83 46" Rear Projection...
RCA D52W20
Check for smooth,accurate adjust of RGB focus located up front behind speaker grill.If jumpy or inaccurate,replace RGB adust block.If that is not the cure,you may have bad CRT(s).
Jul 19, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
DSC-T7 Blurriness
Try this test: Mount the camera on a tripod or set it on a secure base and use the self timer to trip the shutter. Doing this will totally eliminate any possibility of camera shake causing blurriness. If the picture is still blurred then there might be a problem with the AF but if it isn't blurred then the problem is either camera shake OR subject movement (or both).
Sep 12, 2005 | Sony DSC-T7 Digital Camera
Toshiba MW27F51 27 in. TV/VCR/DVD Combo Logo
77 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
