Question about Coship CDVB2000E
Re-programming for Optus D2 satellite
How do I re-program my set top box to access the new Optus D2 satellite? My free to air channels were on Optus B3 until 22 January. Can you help?
Leeann Erickson
  • Anonymous Jul 28, 2008
    coship reset
  • henhu Aug 03, 2008
    i have the same problem
What brand of set top box do you have?
Posted on Feb 05, 2008
A/ delete all b3 channels.
b/ in installation menu delete all frequencies apart from 12407 V 30000.
c/ enter 12706v ,22500 on fta network search and 12644h 22500
this will get all available fta channels from d2. more info on www.vetrun.net
Posted on Aug 11, 2008
I HAVE DVB COSHIP RECEIVER AND I LOST ALL MY CHANALS HOW CAN I RE PROGRAM MY RECIVER THANK YOU
Posted on Feb 11, 2008
Do i have to sighn up to netflix just to browse.
Fetch: Netflix Setup & Help - Optus
www.optus.com.au/shop/support/answer/fetch-netflix-setup-help?requestType...For info on set top boxes and Netflix set up. Check out this article. Which type of set top box do I have? There are 4 versions of the Fetch set top box. The...Missing: labours
labours optus box netflix Google Search
Mar 07, 2018 | Cell Phones
My sharp tv wont change channels not even on tv buttons
I am going to assume you have auto-programmed the TV. If you haven't, do so and let it finish. Make sure you are in the right mode, e.g. Antenna for over the air and Cable for basic cable.
If you have a set top box or satellite, that box changes the channels, not the TV.
If auto-programmed it and it still won't change channels you have a bad tuner and you will need a new Main board to fix it.
Feb 15, 2015 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Screen says no signal . How do I connect cable?
Connect an antenna, cable box or satellite receiver to the RF Input on the rear. Set the input to Air, or Cable, and run a channel scan for Digital Channels if using an Antenna.
Sep 27, 2013 | AOC L22W898 22 in. LCD TV
I have upgraded to Windows 7 and also a new Gigabyte GA-H61M-D2-B3 Motherboard. 4GB DDR Ram I have plugged my Cambridge Soundworks SW320 in but I only get some sound, eg all music and back ground sound is...
Gigabyte GA-H61M-D2-B3 Motherboard supports 2/4/5.1/7.1-channel HD audio, whereas Cambridge Soundworks SW320 is 2.1 (only). Hence, the PC should be configured to provide 2.1 Channel output. The audio of your system may be configured to 2.1. So, please check the Realtec Audio sound manager/ configuration from the control panel or from tray (near clock) and set it to 2.1 (2 Channel Stereo Output).
Moreover, audio on your PC may be running on default HD Audio Drivers. So, you may also download/ install the latest drivers for Gigabyte GA-H61M-D2-B3 Motherboard.
(Refer to download section at the bottom of the page). After installing audio drivers, you would be able to configure the audio.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Sep 13, 2011 | Creative Labs SoundWorks SW320 Computer...
I just purchased a new RCA 32 inch w/ DVD. When starting up it asks if you will use Cable or Air. I have Dish Satellite and picked air. I only get one channel and if I try to go up or down channels I get a...
You should not have had to choose cable or air. When you have satellite it is considered the same thing as cable. Air is over the air rabbit ears antenna free programming. When you are connecting a satellite receiver you only have to turn to channel 3 or pick the correct av, component or hdmi input. Oh you must be connecting more than one television to the same satellite receiver. When that is the case tv #2 usually has to be set on a different channel and the satellite tv company tells you which channel. You still use the satellite remote to change channels and leave this television on one channel at all times. This television is good enough for its own hd satellite receiver connected with component cables or an hdmi cable though in order for you to see its full potential for displaying hd programs.
Jan 07, 2011 | RCA L32HD31 32 in. LCD HDTV
NEED CODES FOR BOX SUPER WEST MIDLANDS PLEASE HELP
THESE ARE TW CODES=
00= 83 5D 12 B8 96 F6 1F C4
01= D2 F9 3F 22 0C A7 D6 C9
Oct 07, 2009 | StarTech.com StarView SV211K 2-port KVM...
Eurovox codes
27 nov.
tw.
00.= E8 25 93 B2 6A 90 0E A2
01= 16 CF 0C A7 A7 14 D2 22
n**
00= 62 BD 22 0A C6 86 9C 93
01= 80 AD D1 D3 80 90 FF 2B
Nov 27, 2008 | Audio Players & Recorders
I have a MD8830 and want to use the freesat receiver system for T.V. viewing, the set up guide has an option for a set top box or one for no set top box, can this be used for satellite viewing without a...
If your satellite receiver has an NTSC RF modulated output (RG 59 F connector), you'll need a TV tuner card in your PC to watch it.
If your satellite receiver outputs NTSC composite (unmodulated, RCA cables: yellow, red, white), you can use something like ADSTech DVD Express to connect to your PC using a USB port.
Once you've got your receiver interfaced to your PC or other display, you'll probably need to download the latest programming guides / channel assignments into the reciever using USB or serial cable.
Due to various countries legal restrictions, finding such bin or autoroll files, even for Free to Air satellite programming, is most easily done by word of mouth.
Sep 17, 2008 | Medion Computers & Internet
Codes
NTL IRELAND (54 01) -- [Last Roll 13/06/2008 @ 7.15pm]
00 = 22 DO 9F EA FA CB 10 B3
01 =
9B 0B 4C 80 4F 6A 39 6B (new)
Please google for TheChatterbox TCB.cc they provide a free toolbar that gives access to new keys, I'm happy to help anyone where ever possible but these boxes are illegal when flashed and you really should sort them out for yourself.
Jun 13, 2008 | StarTech.com StarView SV211K 2-port KVM...
New codes please for ntl
22 do 9f ea fa cb 10 b3
9b 0b 4c 80 4f 6a 39 6b
Jun 07, 2008 | StarTech.com StarView SV211K 2-port KVM...
Televison & Video Logo
1,561 people viewed this question
Top Coship Televison & Video Experts
Jaime Hernandez
Donald Pera Deane
Donald Pera Deane
Are you a Coship Televison and Video Expert? Answer questions, earn points and help others
