Question about LG 42PX4DR 42 in. Plasma TV
Lg plasma problems
My screen sparkles after like an hour of usage.
  • 1 more comment
  • greg420blues Feb 11, 2008
    Mine is sparkling non-stop from the moment we first turn it on to when we turn it off. I was told that we may just have to adjust the voltages ... can anyone provide any advice to how I'd do this? I don't mind trying ... but need to know where to look, etc.
    I'm getting mostly red sparkles on the screen the entire time I watch it. Where can I look for instructions on how to actually adjust the voltage? Okay .. take off the back panel ... then what do I look for? I'm a novice, but don't mind trying .... even if it messes up the TV ...
  • Anonymous Feb 22, 2008
    my tv 3 yrs old sparkles intermitently. is this likely to get worse? is there a solution?
  • 106 Answers
Try to reduce the Vs voltage about 5-10V below its spec value. Vs is from the Power Supply board. The spec value of Vs was printed on the back of PDP panel. (You need to open the back cover)
Posted on Jan 24, 2008
White dots across screen
Sounds like sparkles, this can be resolved with a software update or replacement of either the Control board & / or the Y & Z sustain board. In extreme cases the screen replacement is the only remedy.
Aug 27, 2013 | LG 50PG20 50 in. Plasma HDTV
Samsung 42' plasma tv,screen keep flashing, blurry,no pics
I'm not really sure what causes this but I might be able to help.
I have an LG 42 plasma which had the same problem. In my case I removed the video and the tuner board (they both were mounted on the same frame which was screwed on the tv chassis) and installed them in a "wooden box" so that there would be no electrical contact with the rest of the chassis except from the cables connected to them. It now works fine.
Jan 11, 2009 | Televison & Video
MY LG PLASMA SCREEN IS PIXILATED... LOTS OF RED AND BLUE AND GREEN DOTS ALL OVER IT. HOW CAN I REPAIR THIS CHEAPLY MARK
is it pixels burnt or a sparkling effect there is a fix for the sparkling effect but if you are having burnt pixles it may be screen replacement
Dec 14, 2008 | Televison & Video
Plasma tv
ned to adjust the VS-voltage or the VSCAN-voltage
Jul 17, 2008 | Samsung SP-R4232 42 in. Plasma HDTV
Lg 42pc1d plasma tv red sparkles
I had the same problem, LG came out and it turned out to be the board that filters out the interference around the screen. I pretty sure that was it, took them 10 mins to fix by replacing a few of the boards inside the screen. Sorry I can't be more specific but its not an unfixable problem, so nothing to worry about.
Nov 11, 2007 | LG 42PC1D 42 in. Plasma Television
Vscan voltages on LG Plasma
Are your sparkles mainly red pixels flashing randomly over the TV screen, especially over darker areas? If so your sparkles are I believe a discharge problem, and can be fixed with a firmware upgrade, which I think resets and corrects the voltage and removes the sparkles, which is caused by misfiring of the gases produced with plasma TV's. I have had my TV repaired with a firmware upgrade, which takes only 10-15 minutes and is reasonably cheap repair, and now the TV looks great, no more sparkles. Don't play around with the voltages let the pros fix it, also beware! leave this too long and it can become permanent, and need a new screen which is half the price of the a new TV.
Oct 15, 2007 | LG 42PX5D 42 in. Plasma HDTV
Sparkles
Makes you wonder why nobody is taking on the problem, doesn't it?
Well , to the best of my knowledge, it is because nobody really can.
To understand why you have to understand what do they sparkles come from.
They are random electricity discharges coming from capacitors or other components that act like capacitors, but mostly capacitors.
When laymen hear about capacitors they usually associate the word with bulged electrolytic capacitors, which often cause problems in electronics of all kind.
Well this time it isn't about them.
It's about all other capacitors - or other components exposing similar qualities - which are installed on the board. Most of them are small filter capacitors put in parallel to the big ones or to other passive components such as diodes and resistors.
The excessive heat developed by the sustain boards damages those capacitors. It hardens the electrostatic material they are made of and small breaks in it start occurring at voltages that shouldn't otherwise be causing issues.
The trouble is, they can be everywhere. You can't just pinpoint which ones were caught at fault and causing the sparkles.
When it gets REALLY bad eventually the whole capacitor burns and either shorts or, more commonly, just breaks.
Believe it or not I've seen a board that exploded before my very eyes and , after the explosion, started working LIKE A CHARM!
Turned out a small filter capacitor had blown. It as not essential for the board's functionality and after being problematic for so long and causing image deffects it had eventually shorted completely and literally exploded.
Luckily, the short it had created was too short in time and apparently in a circuit that could take the load for a short while without getting damaged.
So after it blew everything worked just great!
it's a real story from my repair experience.
Hope this helps all consumers, DIY enthusiasts and competitors alike :-)
For more you are welcome to visit our site and read our tech repair blog at
http://www.coppelltvrepair.com
and
http://blog.coppelltvrepair.com .
Aug 26, 2007 | LG 42PX5D 42 in. Plasma HDTV
LG Plasma TV
first i would try unplugging it for about 5 minutes to reset the set. after that i would need more detail as to the problem is there sparkles in the screen is it a certain portion of the set any info you can give
Jul 03, 2007 | LG 42PX4DR 42 in. Plasma TV
LG 42PX4DR 42 in. Plasma TV Logo
722 people viewed this question
