Question about Brother MFC 8500 All-In-One Laser Printer
MFC 8500 - Error Code 71
I've started getting a message that says it's offline, open cover, then close cover, then Error Code 71, unplug the machine and call Brother. I saw on one website that it might be the bearings in a motor and that I might need to replace the Laser Scanning Unit.
Is there any way around this? I can sometimes get it to print a page or two before it starts giving me this error business.
Appreciate any help short of going to buy another all-in-one machine. Any recommendations on what is worth buying?
Thanks!
  • 2 more comments
  • Anonymous Feb 20, 2008
    my problem is when I stack a number of sheets in the feeder to copy, one will come thru and then printer gets held up and the error message reads
    pls close cover but the cover is not open. I shut the machine off and turn it back on and it's okay for awhile and it happens again and I get another error message and this time it is error 71.
    brother 8640D error code 71
  • jimhart May 20, 2008
    I'm also receiving this error code 71. Any help.
    Thanks
    Jim
  • jid1152 Dec 03, 2008
    My fax if giving me the following message:
    PLC Open Cover Offline
    and cover is closed. We open/close the cover and the same message comes out.
    Thanks,
    Jose I Diaz
  • 159 Answers
SOURCE: Hae brother MFC-8500 and just replaced
This is an easy one. With the power on, open the front door, where you installed the drum. Press the CLEAR button. The display will ask something like, "Change Drum? Press 1 for yes. Press 2 for no."
Press 1.
Close the front door.
Posted on Feb 15, 2010
Testimonial: "thanks for your help...this is an awesome way to get help!.....although I didn't think to go online and look up the manual.but with dial up it's slow"
early1234
  • 871 Answers
SOURCE: Brother MFC 8500 Fax machine error "offline"
is your fax machine connected to the phone line? this usually indicates the connection status, thus, if your phone line is in...you wont have the "offline message".
hope this helps.
Posted on Jan 23, 2008
Teckies
  • 226 Answers
ok. right click on my computer,
click on manage,
click usb ports,
delete all files named composite device.
unplug the cable from your printer
restart your computer.
plug it again the cable.
start your printer.
good luck...
Jimsta01
  • 405 Answers
SOURCE: MFC-440cn brother printer error unable to print 4f
Problem with printer head or main board
Posted on Mar 29, 2010
SOURCE: Scanning to email on MFC-9840CDW Laser Printer
This is a little dated, and I hope you have found your solution already, but for everyone else:
Press the # button Use the directional pad to scroll over to the @ symbol. When It is underlines press OK
To insert a ., press the * symbol, scroll over until . is underlined and do the same as above.
Posted on Jun 28, 2010
Back cover open message although cover is closed
Open the top and back covers. If you see any jammed paper or
other item, gently pull it out, then close the covers. If the error message
remains, open and close the covers again. If the FAX/MFC cannot reset
itself and return to the date and time prompt, it will display MACHINE
ERROR XX. Please call Brother Customer Service
and tell them the Machine Error number at:
In USA:
1-800-284-4329
In Canada:
1-800-853-6660
In Montreal:
1-514-685-6464
Jan 15, 2011 | Brother IntelliFax-2820 Laser Fax
hope this helps.
Jan 23, 2008 | Brother MFC 8500 All-In-One Laser Printer
Error 77
I just got the same message on my mfc-8500 after a brief power outage.
I opened the front panel, removed the toner and closed the panel. The printer tried to warm up and then said to open the panel door. I then opened the door, inserted the toner, closed it and the machine error was cleared.
Perhaps all you need to do is remove the toner and put it back in.
Oct 06, 2010 | Brother FAX4100E
Brother MFC 9880 error 71
error 71 indicates problem with the laser unit motor.. 80% is the motor problem and 20% could be the LVPS board... make sure all the cover and interlock switch are close properly.. as any interlock switch which are not close properly will effect the voltage to the motor..
May 28, 2010 | Brother MFC 9880 All-In-One Laser Printer
I GET A PLS OPEN COVER OFFLINE BUT NOTHING IS
I think the machine is telling you to look inside for a foreign object or scrap of paper:
1) Turn the machine OFF
2) Open the cover
3) Carefully inspect inside for a bit of torn paper, staple, paperclip or other such foreign object - gently clear any problem materials. Do not touch internal parts if possible. Use tweezers for small hard-to-grasp objects.
4) Close the cover, and power ON
5) If the MFC cannot reset itself, or if no foreign material is found, the machine should report an error code, for example "Machine Error XX"
6) From this code, brother support should be able to diagnose and help with your problem
Mar 11, 2010 | Brother MFC 8500 All-In-One Laser Printer
Press 1.
Feb 10, 2010 | Brother MFC 8500 All-In-One Laser Printer
Cover open pls close cover error machine 71
DCP-1400 HAS ERROR MESSAGE "MACHINE ERROR 71" HOW DO I CORRECT THIS?
May 07, 2009 | Brother DCP 1400 All-In-One Laser Printer
Mfc9880 machine error 71
error 71 is a problem with the polygon motor which is in the laser unit. This error usually means that you would need the laser unit replaced.
I'd suggest calling out an engineer.
Dec 12, 2008 | Brother MFC 9880 All-In-One Laser Printer
Unable to print
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
  1. Check for foreign objects, such as a clip or ripped paper, inside the machine.
    Open the scanner cover by pulling up on the lower right corner of the cover. Look inside the machine and remove any foreign objects. If you see jammed paper or another item inside this area, gently pull it out and then close the scanner cover securely.
  1. If the error continues to appear, the machine may have a mechanical problem.
    If the error message continues to appear, the machine will need to be reset.
See page 123 of the manual for more. http://welcome.solutions.brother.com/BSC/public/files/dlf/doc000222/MFC-210C_UsaEngUsr_B.pdf
Sep 02, 2008 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 8500 All-In-One Laser Printer Logo
1,843 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
