Question about Mitsubishi WS-55809 55" Rear Projection Television
Mitsubishi 56 inch rear projection TV
Turn on the unit immediately turns off - I pushed the input/menu buttons and the code was 2-2. Any suggestions?
  • Anonymous Mar 16, 2014
    input
  • Mitsubishi Master
  • 8,617 Answers
A 22 code in Mitsubishi is a short circuit that is causing your set to go into protective shut down. Check the horizontal output and low voltage regulators for being shorted. Let me know if I can help you further, or if you need any additional info.
Posted on Jan 24, 2008
6ya staff
SOURCE:
65" mitsubishi rear projection tv won't turn
IF model number posted is correct and green power light comes on for a few seconds and then goes off:
On front of set press and hold both the Menu and Input (device) buttons at the same time for at least five seconds and release both buttons.
Power light will then blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code is found and I will tell you what it means.
SD TECH
Oct 09, 2011 | Mitsubishi WS-65611 65" Rear Projection...
My mitsubishi 42' hd 1080 tv turns off immediately after i turn it on.The set is about 7 years old.HELP!!!!!! niteowl42
Have you acessed the power indicator error code by pressing in the menu and input buttons on the front of the set both in together and hold in for 5 seconds? The led will blink a series of blinks to indicate a 2 digit code which will repeat several times. Let me know what the blink seqience is.
May 31, 2011 | Mitsubishi WT-42311 42" Rear Projection...
Mitsubishi rear projection tv.. 55 inch made in june 2003... will not turn on... no lights blink nothing no sound.. push button nothing happens.... looked in back not knowing what to look for or look at...
IF power light on front comes on for a second or two and goes off do the self check this set has:
On front of set when power light goes off, press and hold both the Input and Menu buttons at the same time for more than 5 seconds and release both buttons.
Power light should blink a two digit error code like: 2 blinks, 2 blinks, a pause and repeat the code four more times.
If this information helps and you want to know what error code found means rate this solution as very helpful and comment here and I will tell you what it means.
SD TECH
Aug 22, 2010 | Mitsubishi WS-55513 55" Rear Projection...
Inputs randomly stop registering, screen goes blank
Code 12 indicates no error. Push the Menu and Device buttons after the TV has shut off to get the proper code, not after you unplug and plug it back.
It seems your set is not Mitsubishi WS-55819 so it will help if you can give the exact model.
Dec 12, 2009 | Mitsubishi WS-55819 55" Rear Projection...
I have an Mitsubishi HD 1080 big screen tv. When
Ur power ic inverter board is dead.
U need a new one.
Aug 26, 2009 | Mitsubishi WS-65511 65" Rear Projection...
Stays on for 2 seconds and switches off
A 2-2 code on that unit means over current shutdown. 95% of the time that code indicates defective convergence output IC's.
Jun 09, 2009 | Mitsubishi WS-65869 65" Rear Projection...
2001 Mitsubishi 65 inch HD1080 rear projection. When I turn it on, green light comes on for 2 seconds then it turns itself off. No flashing green light like others I read about.
Ok, try this first. After attempting to turn on set after it shuts off push and hold the MENU and INPUT buttons at the same time on the front of the set for 10 seconds. This should acccuate the self diagnostics function in the micro and the power LED should start blinking a two sequence code. That code will narrow things down.
Jun 03, 2009 | Mitsubishi WS-65511 65" Rear Projection...
Mitsubishi wt-42413
No you have to push the buttons on the set that say menu and the button that says Input or device both in together for 8 seconds to initiate the self diagnosis feature.
Apr 26, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-60607 60inch projection TV, cannot turn on
i have the same and i am having issues with the screen going dark when its suppposed to be a white screen and the picture is darker than it should be during normal watching of tv. also there is a line at the top(letterbox style) of about 1- 1 1/2 inches......anyone know how to fix this
Feb 22, 2008 | Mitsubishi VS-60707 60" Rear Projection...
Mitsubishi WS-55809 55" Rear Projection Television Logo
445 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
