Computor monitor Is blinking on and off, wont stop, I tried it on another computor and the same thing happens. I can go onto the Internet between blinks, e-mail etc,etc. It almost resembles the flipping on the old screen televisions. Is it deceased????? Dave Envision 17" Monitor, 2 years old. Model# EN7410e
  • 1 more comment
  • mblair50 Mar 09, 2008
    From the very first time the computer was booted up with new screen it started blinking, going to black then back on. Some times it does it constantly, to the point you can't use it and other times its fine for a while then starts blinking after the computer has been on for a while.
    I have the 22" display hooked to a Dual 1 GHz power PC G4 mac.
    I switched from Digial to analog. Disconnected all cords and replugged everything back in.
    Display is set 1680x1050 with refresh of 60Hz
  • dave May 03, 2008
    i have the same problem, i did read a reply to this about how to fix it. the problem is i have no idea what he was talking about, and was wondering if its even worth paying some one to do it ? and how would i find such a person ? thanks for any help. jdtb
  • ValRealtor Jul 26, 2008
    I have four EN7410e monitors on the same desktop computer working just fine for about 2 years (since June/2006). All of a sudden the displays started to blink on-and-off coming back from the screen saver mode... until they simply blacked out completely.
    Found their website www.envisiondisplay.com then called the distributor (1-888-838-6388), explained the situation & 10 minutes later I was issed 4 different RMAs.
    Sent them out at once (in one big box containing all 4 monitors without the cables & bases) to Jastron-Texas for repairs on 07/16/08 on my dime. Got them back today, 07/25/08 on their dime, supposedly repaired.
    Re-installed them with the same previous configuration and, so far, they work really good!
The backlight or the power-supply or the inverter. Try replacing capacitors in the Power-supply, any of the larger ones. Backlights:
various lengths are available on eBay for about $20
Posted on Feb 07, 2008
6ya staff
SOURCE:
Power on, status light blinking, wlan blinking, 1 & 2 blinking, but cannot pick up internet on laptop.
Is this a new installation? Or did it just happen, and was working before? Are you using DSL service or cable or dial up? Not enough info....
If it was working before, and suddenly stopped, then first thing to do is unplug the router for 30 seconds or so, then plug it back in.
If it was working on the laptop and stopped working, then you need to find the connection icon in the system tray (next to the clock) and right click on it, choose REPAIR from the popup. Let it finish and try to connect again.
If new installation, did you follow directions to install and use?
Open your Internet Options, and "connect" to the network. Wizard will walk you through it.
Start with the above - If no help then call back here.
Nov 12, 2010 | D-Link AirPlus DI-524 Wireless Router
Every time I open Yahoo Mail, it causes my cursor to blink and jump around eradically. As soon as I close Yahoo Mail, it stops.
It is just a problem with your browser plugin ; try resetting IE - Tools >> Internet Options >> Advanced >> Reset
Mar 27, 2010 | Yahoo Mail
Power went out now the tv wont turn on, there is just a blinking
Does the power light just blink? Some of the Mitsubishi sets have a receiver built into them; if the power is removed the power light upon return of power should blink for 70 seconds and then go out--then the set should turn on---if the light never stops blinking---2 possible things--set should have a recessed button on the front keyboard(reset) that you can depress with something not sharp and see if after 70 seconds the light will stop blinking; if no, the set now has a damaged receiver(from the back of the set it is a large metal box on the far left side-----the blinking power light is the receiver trying to boot up like a computer---only should happen if power lost---let me know what you find----the receiver if bad is usually no longer available and can only be repaired by removing it and sending out for repair/rebuild.
I do this here for free so if this information helped you take a minute and give me a vote here......ALSO IF YOU HAVE ANY QUESTIONS OR NEED HELP REPLY TO THIS POSTING.
SD TECH
Sep 07, 2009 | Mitsubishi WS-55711 55" Rear Projection...
Hp Pavillion Tx1320us..wont boot up
You're probably one of thousands of victims of defective nvidia chipsets in these systems. Call HP and complain.
Jun 08, 2009 | HP Pavilion TX1320US Tablet PC
Mitsubishi WS-65511 HDTV
Well, this is how that set is supposed to work. After it is plugged in the LED should blink for 70 to 90 seconds. That is normal and is the amount of time it takes for the Digital Module to boot up. During 'boot up' time the set is inoperable. Once the LED stops the set should operate normally. If the blinking never stops there is a problem with the Digital Module. If the blinking does stop but the set wont come on there are other things you can do to narrow down why the set is not working.
Jun 02, 2009 | Mitsubishi WS-65511 65" Rear Projection...
1994 Grand Cherokee Jeep wont start
Need more info. Does it turn over and not start? Does it not turn over? Have you tried to jump start it?
May 29, 2009 | 1994 Jeep Grand Cherokee
Yahoo.won't let me read my mail
This can just be due to corrupted temp int files. Clear the temporary internet files or browser cache and cookies on the browser that you are using. Restart the computer and check your yahoo mail again. If no go, note any error that you are getting, or indicate what is happening when you attempt to read your emails.
Mar 14, 2009 | Yahoo Mail
Acer blinking screen problem
Sounds like your system files have got corrupted, I think you may have a virus,
Best thing to do is back up everything onto discs and run the recovery program to correct this.
Sorry..!
Sep 24, 2008 | Acer Aspire 5500 5570-2609 Laptop
Open Questions:
Computers & Internet Logo
724 people viewed this question
Ekse
Marvin
Marvin
