Question about Dell E176FP 17" LCD Monitor
Says digital imput power safe mode. will not change
Need help with starting the monitor
What you need to try doing is.. finding another cord that attaches from the computer to the monitor. Thats how I fixed mine.
I was told if the plug in is slightly bent which you probably wont be able to see, cause I couldn't that the monitor will automaticly go in power safe mode. Try that hopefully it works..
After I plugged in a new cord it turned right on.
Good Luck!!
Posted on Feb 25, 2008
    Novelist:
  • 138 Answers
What do you want to do?
Posted on Feb 10, 2008
Monitor imput out of range
screen resolution set to high start in safe mode select 800 x 600 at 60 hz save and restart if vga cable is detachable replace cable and check for bent pins
Mar 09, 2013 | Hannspree I-inc Il195abb 18.5in Vga Led...
Resolution set too high ..no picture cant get safe mode to work up down arrow buttons wont move ..computer wants to start normal...cant get into computer with no monitor display ...help...brand new...
Sounds like you need to boot up in VGA mode instead of Safe Mode
Step 1. Power Down your computer.
Step 2. Powwer on your computer and press F8 to enter Safe Mode
Step 3. Instead of selecting Safe Mode, Select VGA mode.
Step 4. Once in Windows, uninstall your graphics card for your Monitor.
Step 5. Restart your machine, when you log back in Windows will reinstall the drivers for your monitor.
Apr 21, 2010 | ViewSonic VX2025wm 20.1" LCD Monitor
The screen says imput not supported but I can hear the startup sc
You need to set your PC video resolutiotn to the native resolution of this monitor, 1440 x 900 @60Hz. You get the message because the old setting for your old monitor (crt?) is too high for your Acer. You may have to hook up your monitor and set up the new resolution. Or you boot up in safe mode, set the resolution to 640 x 480, reboot into regular mode, reset the resolution again to be 1440 x 900 @60Hz
Apr 04, 2010 | Acer V193w LCD Monitor
Monitor displays "warning pc entering power saving mode
Hello
Sounds like to power settings were set too low. Restart the PC, before it gets to Windows press F8. This will send the PC into SAFE mode. You'll get a menu of which SAFE mode to select, just select SAFE mode with networking. Once in SAFE mode, go to START, Control Panel, Power Options. From there select new settings. Since this is a desktop, I would make the settings very long. Good luck
Mar 03, 2010 | HP Pavilion F1503 15" LCD Flat Panel...
Computer screen says imput not supported what do i do?
i believe at boot you should hold f8 for advanced booting options, and then select safe mode, which will start the computer in a lower resolution graphix. from there, set the resolution down on the display. right click on the desktop and select properties or personalize, then look for the display setings for screen resolution. its prolly set to 1680 x 1050, and needs to be set to something around 1280x768 or something: maybe its set to a different aspect ration or just plain different size.
Oct 09, 2009 | E-Machines eMachines Monitor E15T4
Accidentally set computer to wrong refresh; now get no image on digital monitor; how do I change back?
Start the computer in safe mode. Shut down your computer and restart. Tap the F8 key while the computer is starting up until you get a menu with the option to start in safe mode. Make your changes and restart.
Jul 10, 2009 | E-Machines eMachines Monitor E15T4
5 sec after starting windows the monitor goes to sleep itself.
go to safe mode.. change the power settings for windows...
to go to safemode.. simply restart your computer.. then press f8 several times til you see the boot menu.,.. select safe mode.. from there.. you should be able to boot windows.. change the power settings in control panel
Jul 09, 2009 | HP Compaq FP 7317 17" Flat Panel LCD...
Lcd screen broke external monitor wont work
Sounds like you resolution is too high or vista doesn't recognise your driver.
Try starting in Safe Mode by powering up your PC and tapping the F8 key until you see a menu. Select Safe Mode from the menu. Once in safe mode change the resolution to 800x600 then restart in normal mode.
If that doesn't work then download and install the correct drivers for your display card here;
ftp://ftp.work.acer-euro.com/notebook/aspire_3680/
Once downloaded, you may need to install it in safe made once again.
Thanks
C
Mar 28, 2009 | Acer Aspire 3680 Laptop
Annalog power safe mode
Could be a could a couple of things
#1 Ensure the video cable is connected to the correct jack on the tower (Some systems have both an integrated video card and an Expansion card. See if there are 2 blue 15 pin vga ports, if there are 2, connect to the other one.
#2 You may be using DVI (White connection) and have the imput select set to D-Sub (Analog) Use the input select button on the monitor to sleect DVI
Jul 06, 2008 | LG Flatron L1951S-SN 19" LCD Flat Panel...
Dell E176FP 17" LCD Monitor Logo
55 people viewed this question
Alun Cox
