FixYa.com
Tags:
GE Superadio III AM/FM
Milwaukee Job site radio
posted by bd19 on Jan 24, 2008
battery works on the radio, but the ac cord does not , do you know why
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jan 24, 2008
Not Rated (0)
sharcnet
Rank:Guru Guru
Rating: 91%, 303 votes
Questions:
1. Does the AC cord look ok? Not damaged?
2. Have you tried another AC outlet?
3. Does the AC cord unplug from the radio?
When you operate the radio from the AC power cord, the radio uses an internal power supply consisting of a step-down transformer, rectifier, and filter that converts the AC to DC to operate the radio.
When you run the radio off of batteries, it powers the radio directly. In some radios, when you plug the AC cord into the radio, it activates a switch that disconnects the battery voltage to the radio so that the batteries wont be damaged from the voltage created by the internal supply.
The radio can be powered by either the batteries or the internal supply. You don't want either supply affecting the other, so that is why a switch is sometimes used.
Since the radio works fine off of batteries, that would indicate that there is a problem with the internal power supply. This could be a blown fuse, bad transformer or bad rectifier diode.
Good Luck,
- Jim
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Personal Radios problems?
Personal Radios
manual for Audiovox AXR48 crank...
Audiovox AXR48-hand crank radio Answer This...
Personal Radios
Audiovox AXR48- find manual?
I can't find a manual for my... Answer This...
Personal Radios
Need replacement earpads for...
Hi, folks....My radio is a few... Answer This...
Personal Radios
Radio display out on 2006...
The sound system on my Harley... Answer This...
Milwaukee Job Site Radio AM-FM...
Customer brought in this radio... Answer This...
Repair Service
Find Personal Radio Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
