Question about Hitachi 50UX57B 50" Rear Projection Television
HITACHI 50EX01BA NO POWER ONLY CLICK
TV WAS WORKING FINE FOR 8 YEARS GOT TURNED OFF FROM FRONT POWER BUTTON HOUR LATER WENT TO TURN ON THE LED IN FRONT DID NOT COME ON TOOK OFF BACK ALL THE GREEN LEDS LIGHT UP FOR A MILLASECOND THEN ALL GO OFF AND RED PROTEC LED BLINKS DOWNLOADED A SERVICE MANUAL THINK ITS A E991 PART BUT IT STARTS WITH A QUESTION ABOUT CHECKING A RASTER I THINK D & G THEN SAYS TO TEST DIFFERNT LITTLE TRANSISTERS FINALLY ENDING WITH CHANGING A E991 LITTLE THING I FINALLY FOUND AFTER HOUR SEARCH DO YOU THINK A 8 YEAR OLD OBOSLETE TV IS WORTH DUMPING MONEY IN FOR SERVICE CALL OR OFF TO LAND FILL WHAT PRICE SHOULD I DRAW THE LINE THANKS FOR ALL YOUR HELP THIS IS A COOL WEB SITE
  • ICDEADFISH Jan 24, 2008
    thanks for the info since im a rookie could you please give more detail on how to test these items where to find them i do have a ohmmeter and could find a e994 i think if i put ohm meter across and the needle dont move would that say its a blown pico fuse i appreciate your help dont want to throw a 1500 dollar tv 8 years ago into landfill have a great day last question this looks like a big power mother board that i will have to remove to change these items i will make notes where all plugs go back im concerned removing the big red spark plug type wires from a big tall electronic componite also can i test after removed by plugging it in to wall and being carefull not to touch anythig when plugged in P.S. if you have in tile questions will be glad to help tile contractor
    Genius:
  • 1,694 Answers
Check for open E994 pico fuse and shorted capacitor in Horiz
power circuitry.....2KV cap..........Let me know........T.
Posted on Jan 24, 2008
  • Vista Electronics Jan 24, 2008
    Unplug / loosen cables enough to pull chassis back and tilt
    for access................check fuses as you said with ohmmeter...
    C702 maybe your culprit .....will check shorted if bad... might
    be covered with position glue........T.
6ya staff
SOURCE:
Connected to cable box sound no picture reboot left tv on 3 hrs. fine. turned off. 2 hours later turned on now no pic just sound. When the tv is cold no pic. when warm pic. ???
https://www.Abctay.com is an online shop ,
We sell television and electrical accessories,all kinds of TV power supply board, logic board, TV LED screen,
TV LCD screen, mobile phone screen, as well as various types of electronic tools,tv parts power supply,LCD,ccfl ,
LED,OLED,lcd panels,HMI,Inverter,LCD screen,lg screen,display screen,lcd monitor,lg lcd, lg monitor ,flat screen ,
touch screen,hmi,bulb,samsung, innolux ,Mitsubishi,philips, hitachi,auo,innolux,Planar, toshiba, siemens,chi mei,Weinview,
Infineon,industrial LCD,industrial control, sharp monitor,vigor plc,delta, mitsubishi lcd,omron plc,etc
May 13, 2017 | Sony Televison & Video
My television just went off! We tried to turn it back on but it wouldnn't come back oh. Finally the button flashed red like it was trying to come on and we heard 2 or 3 words then that was it.then the...
Tries tv unplug,replug it back like about an hour later.By letting the tv restting itself back to the factory setting.Now tv should be working again.If it have the same result.Yes,the power supply board is the problems and the causes.That the board,where the power a/c cord plug into it.Try website like Ebay.com to buy a whole refurbish power supply board for the replacement.
Feb 03, 2011 | Hitachi P50H401 50 in. Plasma HDTV
61uwx10ba. no power to any boards but power supply.
have you reched around the new soldering area carefully, check for solder spills or drops in the printed circuit, also another thing to look for is some of those replacement stk do not hold their weight, you might want to take them out and try the old ones to see if you recover tv power.
Jan 15, 2010 | Hitachi 61UWX10B 61" Rear Projection...
Tv does not stay on
If you have a rear projection, it is the bulb. Ypou need to replace it.
Jul 24, 2009 | Mitsubishi WS-55859 55" Rear Projection...
RED BLINKING LIGHT ON HITACHI TV CANNOT TURN ON
Check the resisters, that could be the burnt small, also you may need to replace the ICs
Jan 08, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 60ux54b/55k--no sound
For starters, remove the back cover and turn on the TV. You should see 8 green LEDs on the circuit board.
You may have lost power for the audio amplifiers.
Jul 26, 2008 | Hitachi 60UX54B/55K 60" Rear Projection...
Power button makes a click, click sound
The sound is coming from a failed flyback auto transformer. You will need to replace that.
Jun 14, 2008 | GE 25GT507 25" TV
Power button Flashes
the flashing light often shows malfunction ,check the wire connection of your devices something must be wrong .the surge protector you have is for overpower or low voltage too?Ask your neigbours if they have shame problems
Nov 18, 2007 | Hitachi 46F510 46" Projection HDTV
TV Won't Turn ON
Are you getting any response when it 'doesn't turn on' like can you hear the fans spooling or anything? I would begin with verifying all the grounds are properly secure especially the lamp switch cable this can become loose possibly causing there not to be a good ground I've seen it happen on vivitek TV's Verify the TV is OFF and unplugged before you touch anything check the grounds and verify what you can see is properly set. If everything looks ok, check to see if theres a lot of dust in the fans and so fourth, and if not that then replace the power supply.
Feb 03, 2007 | Mitsubishi VS-60719 60" Rear Projection...
Hitachi 50UX57B 50" Rear Projection Television Logo
111 people viewed this question
Top Hitachi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
