Question about Mitsubishi WS-55807 TV
Picture too big for the screen
Sometimes my WS-55807 sreen seems too small. For example, the scores that you would normally see at the top of the screen is cut off. I have tried to adjust the "display Format" but it says "format not available for HDTV now"
Is this normal? Is there any other way to adjust the picture?
  • Anonymous Apr 01, 2008
    I have the same model and same problem. We recently relocated from Japan back home and shortly after my convergence went out and I had to replace the convergence amps. That done, the convergence is good but I now have the same issue as previously described where the top of the heads are cut off sometimes. I have downloaded the manual and can perform adjustments but have now test equipment. Is there an adjustment I can do to get the picture horizontally centered and the right size....Jack
    Sergeant:
  • 261 Answers
If you are using any type of set top box weather it is a cable box or something along those lines, You are out of luck. The formating is controlled in whatever box is connected to tv. So to format the screen size keep this in mind. Cableboxes usually only let you adjust for 1080i and widescreen. But aspect is subjective to how they send the signal to you. Also make sure you hookup a HDTV cable box or I recommend Dish Network to this set because it is easy to operate the formating using the button on bottom left of remote. " * " STAR button is great. ALSO the DVR is larger and you can run the 2nd TV off the same box although it is Standard defination, the 2nd remote is very handy because it talks to the box via RF signals, which means no IR or line of site problems. Its awesome. If i can help you further. don't hesitate to email back. Thank you and have a good night. Jay
Posted on Jan 31, 2008
High Definition--WS-55807
IF the MITS has 3 component inputs blue red yellow RCA jacks on the back then yes at 480 or 720p, you'll need to attach 2 audio cables for sound. If it has a HDMI input then absolutely.
please rate!
Mar 11, 2009 | Mitsubishi WS-55807 TV
Tv doesn't come on
Mitsubishi WS-55807 Manual
I think that the solution that you are seeking is on page 63 of the manual.
Feb 12, 2009 | Mitsubishi WS-55807 TV
Mitsubishi WS-55513 55 in. - Picture to latge for scheen
Change your Display Format (widescreen mode) . You're using ZOOM. Press FORMAT on the TV remote control to cycle through the available display formats.
Feb 09, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi ws 55807
Good Day;
It sounds like your TV is experiencing a CONVERGENCE CIRCUIT failure. YES, it is worth repairing, it's a great TV. The cost will be from $450.00 to $650.00; call an Authorized Service Center and have them give you an estimate B4 repair. Good luck, big IRISH. PS: It's Not An Easy repair to do your self.
Sep 08, 2008 | Mitsubishi WS-55807 TV
Mitsubishi WS 55807
Good Day, Girl 1;
Hey, Girl 1, I have four girls not counting my wife . So, helping you may be difficult. Just kidding!
I would highly suspect that you have fluid on your TV's PCB's (printed circuit boards).
So, at this point that you should call an Authorized Service Center and have them give you an estimate before any repairs are performed.
If you want to try repair on your own e me at mmrkcar@yahoo.com.
Thanks you and Good Luck, big IRISH.
Aug 09, 2008 | Mitsubishi WS-55807 TV
Spots on sreen
Your spots on screen is normal, which is called color spots.Those were often found on crt tube, where discharge to grounding is slow.
Rdgs
Alan
Feb 24, 2008 | Mitsubishi WS-55807 TV
Oval shaped picture problem with Mitsubishi WS55807
Self test: Turn on and Press the input and menu buttons on front panel together and hold for 5 sec. after 5 sec the power LED will blink a 2 digit seq. This will let you know what error code. Count the first blinks then a short pause then the second blinks. Example 2-3, 3-4, 4-1. Let us know what it is
Nov 21, 2007 | Mitsubishi WS-55807 TV
Mitsubish WS-55807 HDTV 55" 1080
RGB picture guns ( CRT's ) are ok. Your set needs a common
convergence circuit overhaul requiring replacement of two IC's,
part # STK392-570. Usual cost about 400.00.........T.
Oct 31, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Screen is distorted on the top and bottom
Loose connection on convergence board, you could tapp and should go back to normal, find loose conn. and solder back.
Sep 09, 2007 | Mitsubishi WS-65807 65" Rear Projection...
Mitsubishi WS-55807 TV Logo
294 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
