Question about RCA OPAL M4001 MP3 Player
Mp3 player shutdown
I was listening to my mp3 player attached to my computer speakers. It had been working fine, then I went to push the next button and it froze for about 30 secs, then shut off completely. I have tried plugging it into the computer for power, checking the hold button, and holding the start button down for long periods of time. Even tried the reset button. Help?
  • classof09man Feb 08, 2008
    the battery wont charge and my computer says that it
  • Anonymous Mar 23, 2009
    when i plug it into the comp. to charge, it won't charge, and says the battery is full!?!
Mine does the same thing i dont kknow how to fix it
Posted on Jan 24, 2008
6ya staff
SOURCE:
Samsung YP-U3
go to my computer> properties>hardware > device manager >universal bus driver>right click on it> update driver>
then1
1.yes this time only> next 2.choose advanced option>next 3don't search i"ll update from........>next4.click on show campatible> next> next 5. now it updated then restart you computer
Then try to format your drvice sir
hope this is helpfull or if problem still please type in comments
regards
golu_fixya
Apr 26, 2009 | Samsung YP-U3 MP3 Player
I Think I Have A Virsus On My Mp3
Since you have this type of problem the best way to solve this is to format the player, if you have a format option on your mp3 player menu you can use that, but if not just connect the mp3 player to your computer and format it from there....
Nov 27, 2008 | SanDisk Sansa m250 MP3 Player
Buttons won't work and it keeps freezing
my walkman is stuck in the logo window its been charging for over 5 hours and still wont turn on when i press the on button
Oct 25, 2008 | Sony Walkman NWZ-S616F MP3 Player
It Broke!
I just took mine apart by prying it apart from where you connect it to the computer and then took out the 4 little screws on the green part and then took out the button from the other attached part then put it back together and then now I stick stuff down the hole to push the button.
Oct 12, 2008 | Nextar MA933A MP3 Player
SHUTDOWN???
Firmware Upgrade
Mar 14, 2008 | RCA OPAL M4001 MP3 Player
Shutdown
there should be a button that is for resetting it and that should work fine if there isent a button it should tell you in the manual how to reset it.
Feb 26, 2008 | RCA OPAL M4001 MP3 Player
Sansa e280 "frozen" won't turn off or respond to buttons pushed
I had the same freeze problem and after doing everything I could think of I read the downloaded user manual and found the answer was to hold down the menu button for 15 seconds. It acts as a power off button and cancels out the last operation thereby unfreezing the offending action.
Feb 17, 2008 | SanDisk Sansa E280 MP3 Player
My mp3 player wont work
ok! easy solution for you^^ 1) Make sure your Zen is powered OFF. if the blue light is on and won't turn off, here's what you do: set the hold button at the top of the player to the ORANGE position, then hold your power button for 3 seconds. the keypad will flash and your player will power down. 2) push in the reset button with a pin or other fine implement. the reset button is located on the bottom of the unit, right next to the connector. your player should power up as normal now. charge it fully! your computer should be able to read it during it's charge as long as you leave it powered on^^ I hope this helps you^^
Mar 25, 2007 | Creative Labs ZEN SLEEK MP3 Player
RCA OPAL M4001 MP3 Player Logo
52 people viewed this question
Top RCA Audio Players & Recorders Experts
Ekse
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
