Question about Toshiba 52HMX84 52" Rear Projection HDTV-Ready Television
When initially turned on the picture jumps around for several minutes
It looks like a cable channel you don't get. the audio also cuts out at the same time. 'Fonzie'-ing it sometimes helps and the problem generally goes away within 20 minutes. yes, it's 2008 and i have to wait for my tv to 'warm up' for 20 minutes.
  • 518 Answers
"Fonzie-ing it" ? It's terrible that I understood what that meant. lol
Sounds like the tuner has a bad solder joint. You may need a Repairman.
Posted on Jan 24, 2008
How to program channels
go into settings and then rescan for channels
May 07, 2015 | Televison & Video
The audio on my LC-45GD6U goes in and out (mostly
if its fine on other channels i would not suspect the tv
Aug 26, 2009 | Sharp Aquos LC-45GD6U 45 in. LCD HDTV
Sony KV-27V22 scrambled picture and loud buzzing audio
the variation from higher channels from lower channels, few things changes eg frequency, voltage, and current.
take your tv to a w/shop and have the following
tunner voltage pulse variation on a avo meter has you change channels. if the difference of voltage is not unform when you are changing from to channel then you should change the control ic on the rf stage or check the capacitors a round the rf ic for variations in value.
Mar 25, 2009 | Sony KV-27V22 TV
Sharp Aquos 32" lcd hdtv, looses video, audio still works.
that's D44 serial common problom,the cables connected to the panel made the problem
Mar 23, 2009 | Sharp AQUOS LC-32D44U 32 in. LCD TV
maybe the problem is the display panel or front panel.
Feb 25, 2009 | Insignia LCDTV26 26 in. Television
No picture or sound but get channel and clock on screen display
Initially, suspect would be your audio/video sources such as the DVD, Home Theater, Cable box, Satellite Receiver. Pls check the cables/wirings or how they are attached to the PTV. If the PTV is connected directly to a cable provider with the this issue, then it is either your cable provider's signal is not reaching you or the PTV's tuner section needs to be looked up.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Nov 02, 2008 | Televison & Video
S.O.S anyone out there
Projection TV sets have several common problems listed below.
Problem #1) Convergence
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
Sep 03, 2008 | Mitsubishi VS-55705 55" Rear Projection...
Element hdtv flx3210 shuts video off after a few seconds.
Send the set back for service.
The power supply most likely failed, or another circuit board has failed and the set is in the protect mode.
I would consider to see if the dealer would exchange the set for a well known quality brand name set and pay the difference.
Jerry G.
Jul 11, 2008 | Televison & Video
Rolling Picture
Mebe the tv tuner no good.
Jan 12, 2008 | RCA 27V530T 27" TV
No sound
have you check with other input like a vcr?...good luck
Aug 10, 2006 | RCA F32649 32" TV
Toshiba 52HMX84 52" Rear Projection HDTV-Ready Television Logo
43 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
