Question about Hotpoint RGB745 Gas Kitchen Range
Oven and broiler won't come on. Cooktop burners are fine.
I've seen some notes about how the oven ignitor should be observed for the "glow" and/or tested for amperage to see if it's bad. The owner's manual suggested that the oven gas shutoff valve mey have been somehow turned off. It includes a small diagram of the valve and it points to the far right corner of the oven surface under the cooktop. Maybe I'm confused, but I see no such animal in that vicinity, even with the cooktop removed.
The manual says it's for models RGB744 and RGB745. I'd like to know the specific model number, but have no idea where it is. It's not obvious on the unit.
I'd like to at least get the baker working.
Advice? Thank you,
Gary Suddeth (gvmbear@aol.com)
It's troublesome, thought, that the broiler won't fire either. Is that not another ignitor/burner? I can't imagine both ignitors failing at the same time. All the cooktop burners are fine.
What I really need is a diagram or something that would show me how to get to and expose a given part.
  • 9 more comments
  • Gair-Bear Mar 09, 2008
    I appreciated the feedback and the problem was solved. Just needed an oven igniter. Broiler was ok.
    Gary
  • cjohnson1214 May 04, 2008
    I'm having exactly the same problem. Neither broiler nor oven will light. I checked on the cleaning issue, because in fact I did clean it recently, but it doesn't light in that cycle either. I'm confused by Gair-Bear's comment -- was your broiler working when the oven wasn't? Aren't they separate igniters?
    I take it back -- my broiler DOES work. At least it does now, but it didn't when I checked it before. Hmmm.
  • Anonymous Jun 30, 2008
    Oven
  • the2bees06 Sep 22, 2008
    My top burners work fine but the oven won't light ... I tried to light it manually with a lighter but still nothing .. Need to know what is causing it and where I can get instructions with drawing to fix it .. ThankYou
  • mlssjan Dec 22, 2008
    Oven does not light, but top burners and broiler is ok. Found the gas valve that was suggested to check. It is behind the bottom drawer in the left corner, but I can not tell by the owners manuel, whether it is on or off and which way to pull it to check with out possibly breaking it. Does anyone have a larger picture of the gas valve and lever, or advice on how to check it ? Thanks!
  • Anonymous Jan 14, 2009
    Top burners work fine. Oven will not come on.
  • rayski3488 Feb 11, 2009
    oven and broiler dont come on and top burners fine no glow or pilot light lit or a smell of gas or and
  • Anonymous Feb 13, 2009
    hotpoint oven will not light (RGB 745 BEH3WH)
  • Anonymous Feb 25, 2009
    Turned on the oven but 10 mins later it was still cold, I checked and the flame never lit. However, my burners work. I don't have the owner's manual and I need to know how to relight it.
  • yessamelyk Apr 27, 2009
    Accidently left my Hotpoint oven on and noticed a few hours later but it had automatically shut off somehow and now will not start back up.  Like others...my cooktop burners are working fine, but no broiler or oven ignition.
  • 3 Answers
Have you run the self-cleaning feature recently? I had a similar problem on my stove of the same model, and it was the switch that detects whether the oven latch is engaged (if it gets stuck and thinks the latch is locked, it will not ignite the main burner or broiler). An easy way to check if that's the problem: without touching the latch, turn the controls to Clean. If the burner lights, that is your trouble.
Posted on Mar 08, 2008
My oven is not working The Broiler works and the stove top works fine but the oven will not heat and when you turn it on no gas comes out I tried turning it on and using a lighter but nothing happens
You gave us good clues in information!-- Thanks!
Most modern gas ovens have a device called a Glow Ignitor to light the burner.
If this ignitor has filed, it will NOT left the gas valve open-- (Good thing, right? :-) )
You say the broiler lights fine-- so let's observe something when the Broiler lights:
Do you see a bright glow near the Broiler burner?
(Usually toward the top rear of the oven--)
Well, you should see a similar bright glowing near the BOTTOM rear of your oven, for the main burner to light off-- If you do NOT see this glowing-- then you need a new ignitor-
You can remove the bottom burner cover, and dig deeper into the repair if you like-
But a new ignitor needs to be exactly like the failed one-- the safety circuit is very fussy about the exact same ignitor-- or it will not allow lighting-- even with a new 'generic' installed.
How deep do you want to go into this repair?-- Maybe it is time to call the service people into do the job?-- You can tell them that you think the ignitor needs replacing-- and approx. what will they charge you for the service call and the ignitor?
I hope this helped.
Mack B
Jan 27, 2011 | GE 30 In Freestanding Gas Range ...
My broiler works but oven is not heating. Is this an ignitor problem?
That could be a good analysis---
Here is an observation you can make thru the oven door:
When you turn the oven on to BROIL-- do you see the bright glow of the ignitor?
(It is almost like a light bulb was in there-- buy the burner!)
When you start the oven (on BAKE) setting-- do you see a similar bright glowing light?
(Tho down lower, near the Lower Over Burner)
If you see the bright light-- then the ignitor is apparently heating up--
If not-- then, YES-- you are likely right--
Ignitors are fairly common failure items-- and they can obviously stop the burner from lighting-
Make sense?
Let us know if we can help further.
Mack B
Jan 15, 2011 | GE Ovens
SET DIGITAL THERMOSTAT TO SAY 350 DEGREES WILL NOT TURN ON OVEN,,, ? IF I SET TO BROIL BROIL WORKS BUT OVEN WILL NOT TURN ON ?
Possibly the ignitor for the main oven burner has failed--
An observation question:
When the Broiler 'lights' and comes on, do you notice the ignitor glowing bright, before the gas valve (to the Broiler) opens, and you get the Broiler lighting---
Now-- for the main burner to come on, -- there has to be a similar bright glow from the MAIN BURNER ignitor, before its main burner gas valve can open-- No Ignitor?-- No ignition, and not Main Oven burner!
Let me know what you need from this point on --
Mack B
Dec 30, 2010 | Maytag CWG3100A Gas Single Oven
My Maytag Gemini Gas Range works fine as far as the four burners, the bake on the top and bottom oven, but the broiler on the top oven does not work. Is this a pilot issue? I really appreciate the help,...
If the broiler burner is not coming on it may be a bad ignitor or the ignitor may not be getting power. Observe the ignitor when you turn in on ans see if it glows at all. If not then test for power to the ignitor if you have power and not glowing or lighting replace the ignitor. If it glows but does not light the ignitor may just be weak replace it.
Nov 02, 2010 | Maytag MGR6772BDS Gemini Gas Kitchen Range
Oven will not heat cooktop works properly
if your oven has a hot surface ignitor it will be visible when looking in the broiler section of your oven if you have an upper and lower burner the bottom of oven will have to be removed to find the ignitor when oven is turned on ignitor should glow a bright red the ignitor works off 120volts if you have the knowledge and testor however a visual inspection if ignitor does not glow and part of the igniter appears white with a smaal crack line in the middle it is probbably broken at that point also if you have testor you will have a continuity reading threw the ignitor
Dec 07, 2009 | Computers & Internet
Maytag oven will not get hot
the ignitor is bad, the ignitor opens the valve when there is enough amperage. the ignitor isn't pulling enough to fully open it
Sep 08, 2009 | Maytag MGR5870 Gas Kitchen Range
Broiler works, oven settings - no flame, no heat.
Hi, it sounds like the oven ignitor might be bad. Remove the floor panel inside the oven and you will see the ignitor attached to the burner assembly. Turn the oven on and see if it glows. You can test the connection for the ignitor and see if it gets 120V to it. The most common problem with the gas oven is the ignitor. Most of the time, the ignitor glows but is not strong enough to open the gas valve.
Please let me know if this was helpfull or if I can assist you further.
Thanks
Vic
Jul 17, 2009 | GE JGBP33 Gas Kitchen Range
GE XL44 oven not working, but the broiler is...???
CHECK THE IGNITOR, IT SHOULD BE GLOWING ORANGE BEFORE GAS IGNITES. IF NO GLOW, REPLACE IGNITOR.
Jan 28, 2009 | GE JGRP17 Gas Single Oven
New igniter, still won't work
Turn on oven. Ignitor should begin to glow. (if no glow after 30 seconds or so, check to make sure you have 120 volts to ignitor) Observe amperage draw using a clamp on amp meter. When amperage reaches 3.2 to 3.6 (for square syle ignitors) the oven safety valve should open, releasing gas and lighting the burner when the gas hits the red hot ignitor. For broiler, just substitute the word broiler for oven. Old ignitors get " weak " and may not draw enough amperage to allow safety valve to open. Also, voltage will affect the amperage draw, as lower voltage = lower amp draw.
Nov 06, 2008 | Hotpoint RGB745 Gas Kitchen Range
GE Oven does not light - no gas smell and no electronic ignition clicking sound
Gas oven does not work. Burners and broiler work. When oven kGnob is turned on, there is no glow at ignitor, nor any gas smell.
Jul 21, 2008 | Kitchen Ranges
Hotpoint RGB745 Gas Kitchen Range Logo
1,961 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Ismael Rodriguez...
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
