Just purchased a 94 Cutless cierra 4 door, signal lights are not working, replaced and fixed fuses.. was told the remote starter may have wiring problems affecting the signal lights.. hazard lights work
Click on the link, check fuse f13--20 amp. Not only check the fuse, check the fuse circuit for voltage, use a test lite, hot all the time.
You have to test when problem is ongoing. The fuse is for brake lamps.
At the moment, I don't know if trouble shooting one system will fix the rest? With multiple issues, I pick one system and trouble shoot.
Its a faulty turn signal switch.Try this,push down and hold brake pedal while pushing on the hazard switch and if the brake lights come on then replace the signal switch.
The starter need a lot more charge to crank the engine then lights, door lock and other auxiliary equipment. So it could be a battery. Try jump wire your car. If this does not help - check the starter relay in the relay box of engine compartment.
Remove plastic Grill (6 screws)
Remove Turn Signal Light (3 Screws)
This allows you to access the 4 screws that hold in the Headlight. Remove these and then remove the headlight. Once out, then just turn the bulb and remove. Be careful with the plastic clip that holds the bulb to the wiring harness. Since the car is old, the plastic will easily break.
Try replacing light bulbs and flasher which may correct the turn signals. Check all fuses, however as for the speedometer, the plastic clogs or wheels have run their course, If you intend to replace these, suggest you purchase a repair manual for your vehicle.
1) remote starter was not hooked up to the factory arm wire
2) trunk release was programmed to disarm factory alarm before popping trunk
3)parking light wire on remote starter was not hooked up
4)disarm wire from remote starter was not hooded up
5)this is not normal and they should fix the problem or have it done by some one else and have them pay for it, how much did they charge,
Bring it over I'll fix it right and not charge overpriced amount
