Uniden TRU8885 Digital Answering Machine Logo
Posted on Jan 24, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Caller id time recorded in caller id does not tally with the time that had been set. All call recorded at 12.00 am
Anonymous
Level 2:
New Friend:
  • Expert 136 Answers
  • Posted on Mar 30, 2008
Anonymous
Expert
Level 2:
New Friend:
Answers
136
Questions
Helped
51279
Points
315
You must set the base time as well as the handset time
enter global setup menu then
time and date submenu
then vol. up / down for day
then hour
then minute pressind save each time
1helpful
Have uniden dect 6.0 plug in system and landline .how d we delete 101 calls from the uniden after they have been dealt with on the land line
I believe you are asking how to delete the call ID log<?>.
If you can identifiy the (caller ID/right) key on the large round multifunction button of the handset, do the following.
To delete all the Caller ID numbers, press (caller ID/right) key when the phone is in standby. Press MENU/SELECT and select
Delete All. When the phone asks you to confirm, select Yes.
Notes:
• When you delete a Caller ID number, you delete it permanently.
• Caller ID numbers are stored separately in each handset. Deleting a record from one handset will not delete
the record from any other handsets.
1helpful
How to get caller id for missed calls for Panasonic kx-t7730
Panasonic KX-TA624/824 automatic Caller ID logging How to set up automatic Caller ID logging
in the KX-TA624 phone system with KX-T7735 phones. (for dash four and five, and KX-TA824)
System Programming:
  1. In System Program number 900, enable Caller ID for the lines you have Caller ID on. (To get into system programming, press Program * # 1234.)
  2. In System Program number 901, select your own area code and any other area codes that don't have to be dialed when making a call. The area code digits are removed from Caller ID log information so you can return a call without dialing unnecessary digits which would mess up the call.
  3. In System Program number 902, if necessary, indicate the number of digits to be removed, and a particular digit (usually 1) that might have to be added, when returning a local phone call. The default programming is to remove the first three digits, and add nothing; which is correct for most locations.
  4. In System Program 903, if necessary, indicate the number of digits to be removed, and up to 4 digits that might have to be added, when returning a long distance phone call. The default programming is to not remove any digits, and add a 1; which is correct for most locations.
  5. In System Program number 909, enable Call Log Assignment for each phone where you want to log Caller ID information. You can use * to indicate you want logging at all phones.
  6. Get out of system programming. (Press Hold or End, then Program.)
Phone Programming:
  1. Program a button for Caller ID Indication on each phone where you want to log Caller ID information. Press Program, then the button you want to use for Caller ID Indication (we recommend the top button in the left column), then 96, then Store, then Hold, then Program. (If you want a phone to record Caller ID information individually, rather than for the whole system, use 6 instead of 96.)
  2. At each phone where you want to log all calls, press intercom, then 7382#.
User Tips:
  • The Caller ID Indication button will light up only when the system has logged UN-answered calls.
  • Use the Navigator Key at the lower right corner of the phone to scroll through Caller ID information.
  • You can erase the entire Caller ID log by pressing Intercom, then 70**#
  • You can erase an individual Caller ID record by pressing Transfer while the information is displayed.
  • If your phone does not have a Navigator Key, you can program an available button for Caller ID Selection. Press Program, then the button you want to use for Caller ID Selection, then 97, then Store, then Hold, then Program. (If you want a phone to record Caller ID information individually, rather than for the whole system, use 7 instead of 97.)
  • To call a number displayed on the Caller ID log, pick up the handset or press the speakerphone button, and press the Caller ID Indication button.
Uniden D2280, answering system trouble.
i have a chipper and it started giving lot of problems 4 yrs ago, so I got this free Pdf manual from reliable-store for free and I don't think Ive visited a mechanic or fixya for help for more than 3-4 times out of the 20 times I fixed the chipper in these 4 years
Power out. how do I reset clock GE DECT 6.0
Make sure the answering system is ON.
Press and hold the DAY/CHECK button to set the day of the week.
Press and hold the HOUR button to set the hour (a.m. or p.m.).
Press and release the MIN button to advance the clock in one minute intervals. Press and hold to increase by 5-minute increments.
After the time is set, the real time clock will be displayed on the handset within 1 minute.
NOTE: You must set the day manually. You may choose to set the time manually as well, although the time is automatically transmitted by your local phone company as part of Caller ID service. If you subscribe to Caller ID service, the current time is set automatically when you receive your first CID record.
NO MANUAL HOW DELETE CALLERS IN LOG ?
You can download the owners manual in PDF format from this link.
412CID 4 Line Telephone
To answer you question - From the owners manual:
Erasing Caller ID Records
In order to delete a specific Caller ID record in the log:
1. Using the [<] or [>] key, find the particular record you would like to delete..
2. Press the [ERASE] key. The LCD display will indicate that the record has been deleted.
3. You may erase all caller information records simultaneously by pressing [ERASE] from the summary
Call ID display.
Hope this Helps.
On screen caller id failure
common problem on 625 receiver. Have you hit menu 6-1-2 to enable caller id? If so call Dish and have them send you a new receiver out and give it a try. I'm sure it won't work every time, but it has to be better than what you have.
I only seem to get Caller I.D.records for calls to line 1
Go into the menu option under set up and go step by step and it will bring you to caller id option. There , you should be able to turn on the caller id for both lines. I just went through this with my parents phones. after you do it you wont believe how easy it was.
Caller ID function does not work.
Turn off your computer off and temporarily remove the DSL filter to see if the Caller ID then works. If that makes no difference you will need to contact the dish company.
Top Uniden Lands Phones Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
