Hot SpaPool, approx.600 gallon Water, Filter Pump is on but Water is not filtering or not moving at all. ? (Salt water Spa).
I can see Motoer counts 60 making Noise, but Water is NOT moving, No Jets running...no water rotations at all.
Any suggestions?
Thank you.
Roger.
You have probably pulled the center out of the impeller. Please shut this pump off immediately before you over heat and distort the housing and damage the motor.
You use a paper filter on this device? This has salt water in the tub? or you use salt water as a water treatment?
I think you had your spa running and you turned it off for some reason and immediately turned it back on. If there was ANY pressure in your system, that pressure was running the impeller backwards when you turned the motor back on and that is why the center is pulled out of it.
Of course there may be other reasons for this problem and you will never get anyone to admit to doing this ... but it was evidently done.
I frequently find this problem at work where I maintain three public bodies of water ... till I got rid of the 'pool attendant', that is!
thanks for posting your question at FixYa.com
If you find this response helpful, please vote
thanks
WATER FILTER CHANGE REMINDER
(Select Models)
For some refrigerator models featuring
water filters, the Water Filter Change
Reminder function monitors the life of the
filter and provides a reminder when it is time
for the filter to be changed.
When the system detects either 12 months
of usage, or the filtering of 416 gallons of
water (whichever comes first), the CHANGE
FILTER indicator light will illuminate. This
indicates that the water filter should be
changed and the light reset.
To reset CHANGE FILTER light: Press and
hold the LIGHT and LOCK pads until the
CHANGE FILTER light blinks (approx. 3
seconds). The control is now reset for 12
months or another 416 gallons.
Note: The Water Filter Reminder will
operate if the filter bypass is in place.
If you have other questions please let me know, Thanks Sea Breeze
