Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Keeps shutting off
Tv keeps shutting off
  • 5 more comments
  • Lady2007 Jan 25, 2008
    How do you fix this? I'm so frustrated. Reply please.
    Is this procedure worth doing for the sake of the T.V?
  • littlebut Feb 03, 2008
    my model # is hd61w66 and my will come on then cut off and then come on byitself 3 or 4 times then the on light will start flashing. what is the problem here?
  • jaxjordan Feb 03, 2008
    My t.v. comes on three times as well, then off. took the back off dusted everthing, did not help.
    What does a ITC222 chassis cost and can I repair it.
  • Anonymous Apr 04, 2008
    I have a problem with my rca 27" picture tube bought in 2004. Tv will come on and all of the sudden it cuts off. Sometimes it will cut back on itself and then it just cuts back off in different times. Big problem might be my sony 35"(9 yrs old, is it the same problem or a co-insid) tv popped real loud 1day earlier and I can't get it to cut back on. I have directv but I unplugged everything to it and it still cuts off. thanks for any info.
  • oldenuff May 01, 2008
    my tv will come on, it will sometimes stay on for an hour or two and at other times it only stays on for 15 or 20 mins and then shuts off. It acts
    like it wants to come back on, the led light will click on and off several times by itself and never power on. After it sits for a while, it will power
    back on. I have blown it out to clear any dust. I have put a fan on it to keep
    it cooled off. I have changed the batteries
  • wade830 Jul 01, 2008
    power button just flashes 3 times then nothing can anyone help me with this its an RCA 52 inch projection
  • screaminemo Dec 28, 2008
    mine is a 38 inch rca television and it seems to like to shut down. after about 15 min of it being on it shuts off and the light on the power button goes from a steady green to a flashing green. any solutions please email me jaycethehottie@aim.com
I have a RCA tv that turns itself on and off intermitedly.Do you have any suggestions of how I may repair it myself?Thanks Darrel
Posted on Dec 29, 2008
Go to www.tvparts.com and give them a call!
Posted on Jul 01, 2008
    Problem Solver:
  • 11 Answers
CP 150 may be bad. it will be on the board to the left, toward the front behind a heat sink. if it is bad the top will be swelled. The value is 25v at 2200 uF
Posted on Apr 30, 2008
    Champion:
  • 206 Answers
These ICT222 are a real pain, there is no one reason that shuts them down. They vary from defective flybacks, open or defective capacitors on the main deflection, simple cold solder joints, mabe a bad signal board or a defective pin conector to the convergance. I have worked on over 300 of these and no real problem stands out. And since most warentey shops will simply replace a entire board rather than componet level repairing the set almost all RCA suppliers are running out of these boards. Then RCA will use 4 or 5 differant boards in the same model run and this means the set has to come apart just to get the right part number. Wish I had a simple way to fix these but at this time there is none
Posted on Feb 07, 2008
I also have the same problem... I get no picture when I go and to turn it on, the power light just flashes about 3 times...
Alex
This seems to be a regular problem with this particular model. Mine failed after 11 months and authorize repair depot could not repair it. They had four others in the shop like it. It was out of service for three months.
After much complaining to RCA (Thompson's), they replaced it.
-=George=-
(¯`·._.·ns¢ävë·._.·´¯)
www.nscave.com
Posted on Jan 27, 2008
  • RCA Master
  • 8,617 Answers
You will need a new Power/scan board unless you have some real good troubleshooting Skills. This is the ITC222 chassis it is not very easily diagnosed without the proper diagnostic equipment, It is going into protective shutdown. Replacing the entire module is your best bet. Let me know if I can assist you further.
Posted on Jan 25, 2008
My sony bravia tv keeps shutting off
in this case you tv main board is defective because this is a temperate error please replace main board
Feb 28, 2015 | Sony Bravia Kdl - 46Hx800 46 inch 3D Led...
Shuts off and on while trying to watch, the power light flashes 30 times when off then the tv comes back on again
Power supply trouble. The TV keeps trying to start then operates for 2 seconds and shuts down. The cycle keeps repeating until eventually the TV will not start at all.
Nov 27, 2013 | Sony KDF-60X5955
Power board problem. Get a honest TV tech.
Nov 12, 2013 | Televison & Video
TV keeps shutting off.... won't stay on, any ideas?????
Check for bad capacitors in the power supply. Check for voltages. You can get a board at Encompas Parts.,
Nov 19, 2011 | RCA TruFlat 27F520T 27" TV
My tv keeps shutting of after I replaced the lamp.
Please recheck new lamp is placed in its position correctly and lamp cover is well seated.
Hope that will help to fix TV.
Sep 18, 2009 | Samsung Televison & Video
TV keeps shutting off automatically
Since your plasma is less then a year old, I would suggest to contact the manufacturers to get it fix under warranty. If the plasma keeps shutting off by itself, that is not normal and should be repair.
Jan 28, 2009 | Pioneer Elite PRO-111FD 50 in. Plasma TV
your tv may have a sleep alarm built into it- go into the menu screen for your tv and see if it has one and if it is set up to turn off after so long
Dec 06, 2007 | Durabrand DWT1304 13" TV
Tv shuts off
This shutting on and off~On Durabrand TV`S. If your Tv Turns Off after about 1-11/2 minutes after turning it on then you need to replace your batteries in your remote control with BRAND NEW BATTERIES or it will keep doing it. It is a real pain in the behind especially if you dont have brand new batteries handy!
Dec 06, 2007 | Durabrand DWT1905 TV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
348 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
