That could be caused by the CP150, CP120 and CP114 capacitors on the deflection board. Very famous issue. You can get the RCA repair kit by that same name from www.tvrepairworld.com which has the capacitors and the CD with repair instructions
sounds like the cP150, CP120 and CP114 capacitors need replacement. You can get the CP150, CP120 and CP114 repair kit from www.tvrepairworld.com the kit contains the capacitors and the CD with instructions.Its listed under the RCA repair kits as RCA makes the GE models.
Try replaceing the CP150, CP120 and the CP114 capacitors. Very common problem with RCA. You can get the repair kit by that same name from www.tvrepairworld.com which also includes instructions.
www.tvrepairworld.com has a RCA repair kit called CP150, CP120 and CP114 capacitor repair kit which should repair that issue. The kit also contains the CD with instructions.
Liz, yes it is a power supply problem, better question is; low voltage or high voltage power supply ? count the blink code, it should repeat the code, once you have the code call your local tv shops and give them the model number of your tv and the blink amount and they`ll tell you price to fix, gl, video-tek
Check hori output Transistor if it is shorted set will not come on Part # NTE2324 if it is ok CK second ribbon connector on the deflection board going to board on right. make sure it is in good if it isnt set will make noise and not come on,
