Question about EPoX BT-PA04AU (192062001) Print Server
Epox bt-pa04au brother dcp1200/mfc9750
Running vista, have an older printer still works well, tried to add a bluetooth usb printer adapter. When installing new printer says I need printer driver. Unable to find one for vista.
Thank you
    Problem Solver:
  • 3 Answers
Well If you give the manufacture a call they will mail you the url link that will guide you to the Vista driver
Posted on Apr 01, 2008
6ya staff
SOURCE:
How do I get my anka Bluetooth keyboard to connect 2 my Windows 10 desktop
Bluetooth (BT) is hardware. If your KB didn't come with a usb dongle, and your machine didn't come with BT capabilities, you'll need to buy a USB BT adapter.
https://support.microsoft.com/en-us/help/15290/windows-connect-bluetooth-device
Mar 31, 2018 | Computers & Internet
Asus nv50
Are you telling us that you are using a Bluetooth adapter to try to connect your ASUS N50Vn laptop.to a wireless network??? For that you need a (wireless) network adapter (it plugs into an available USB port on your laptop. like the BT adapter), not a Bluetooth adapter.
Sep 05, 2014 | Adapters.com BT-0333 Bluetooth USB Adapter...
How to turn on bluetooth
Hi.........
Hello........
Try looking around in the Control Panel. The "classic view" might help you find exactly where it is located.
These computers can be made with Bluetooth, but it is still an option, so you may or may not have it. If you don't, small USB adapters are available anywhere that sells electronics (Target, Wal-Mart) for about $20 if you really need it. Bluetooth is slower than a direct USB connection, so if its not too much of an inconvenience, a direct USB connection might work better anyway.
Regardless, here are the instructions I found for installing a Bluetooth device on your laptop:
To install a Bluetooth enabled device:
a. Set up the device so that your computer can find it. To do this, you must:
i. Turn the device on.
ii. Make it discoverable.
b. Click the Start button Picture of the Start button, click Control Panel, click Hardware and Sound, and then click Bluetooth Devices.
c. Click Add, and then follow the instructions.
To install a Bluetooth enabled printer:
a. Open the Add Printer wizard by clicking the Start button, clicking Control Panel, clicking Hardware and Sound, clicking Printers, and then clicking Add a printer.
Good luck.......
Sep 21, 2011 | Amstron Dell Studio 1537 Laptop AC Power...
Need a driver for a Tiny USB 2.0 bluetooth EDR dongle mini wireless adapter, can you help me locate the driver Mike
These dont need drivers on VISTA or windows 7
However in some instances under XP you may need to give it a nudge
This is done by going to the DEVICE manager and selecting the device then under DRIVER select UPDATE DRIVER.
I have a few of these in various flavours. Also you may want to take a look at "bluesoliel"
It is a very nice BT application that makes using and connecting BT devices a breeze
http://www.bluesoleil.com/
Jan 30, 2011 | Tiny Computers Tiny USB 2.0 Bluetooth V2.0...
Brother DCP1200 Machine Error 76
This refers to a error with the fuser temperature you need it repaired by a service technician. Parts can be as little as $15 for the thermistor sensor or as much as $100 for a new fuser.
Jan 04, 2010 | Brother DCP-1200 Laser Printer
IOGEAR GBP301 and HP Deskjet D1341
Please make sure that the printer is already VISTA compatible meaning if it is known to have VISTA printer drivers.
Jan 17, 2008 | IOGear GBP301 Print Server
RE:BT320/BT620
Hi Leba,
Try downloading these lastest drivers, and see if that helps. Drivers off of CD can be really old.
http://www.broadcom.com/products/bluetooth_update.php
Let me know it they work, please, since I just order two of these units to update my older ones.
Good Luck!
Jan 07, 2008 | Adapters.com BT-0333 Bluetooth USB Adapter...
Lose wireless internet when printer is on.
the only thing that connects the printer to the internet fault is the fact that the printer and your belkin are both usb connected. If you are using a laptop then it could be a usb power problem and the motherboard is disconnecting the belkin adapter for some reason, the only one i can think of is a power problem. The same can apply to a desktop pc if there is a usb problem Firsly i assume you are using the belkin software to connect the usb adapter to the router, so on your taskbar on the right there is normally the little aerial type icon for the belkin adapter and a little pc screen showing the connection also, if you right click on one of theses icons you should get a line reading 'enable windows WZC', if you do get the option enable it and try using the windows connection software instead of the belkin as it may stop the disconnecting. Also ensure that when you installed the software to your printer your firewall and antivirus was dissabled as certain elements to the driver may not have been installed. Lasly, try using different usb ports if you have spare ones, with both the printer and the adapter as sometimes the chip on the board may be instructing the usb ports incorrectly as to which is required first, as windows asks for certain things eg input/output ports to be used first,in other words the IRQ (interupt request) may be causing the problem.
Jun 23, 2007 | Belkin F8T003 Bluetooth (F8T003V) Wireless...
The mouse keeps getting erased from the Bluetooth Devices Menu
Try pairing again.
Or re-install the bluetooth driver.
Oct 21, 2005 | EPoX BT-MS02B Mouse
Open Questions:
See all EPoX BT-PA04AU (192062001) Print Server Questions
EPoX BT-PA04AU (192062001) Print Server Logo
150 people viewed this question
Top EPoX Computers & Internet Experts
Ekse
Marvin
Marvin
Steven Wander
Steven Wander
Are you an EPoX Computer and Internet Expert? Answer questions, earn points and help others
