Question about Sharp AR-F152 Fax
BLACK LINE DOWN THE MIDDLE OF ALL FAXES (LASER BROTHER MODEL 782ON)
HELP??
  • salvon May 26, 2008
    mine is on a 7420, and I can't figure out how to get to the scaner lens. Do I need to take out screws to do this?
  • 62 Answers
Reciving or sending.
Posted on Mar 07, 2008
    Genius:
  • 1,003 Answers
Clean theSCANNER LENS WITH GLASS CLEANER ON A MICROFIBER TOWEL(SCANNER lens is under large feed roller on auto document feeder
Posted on Jan 24, 2008
6ya staff
SOURCE:
I have a Brother Intelifax 2820 that when you fax anything it puts a black line down the middle of the page. I have taken a soft dry cloth and cleanded the corona wire and that didnt seem to help.
the corona wire, which is on the drum unit only comes into play when you are receiving faxes. if i read right and its only on sent faxes, you need to clean the scan glass. that is located underneath your control panel where your originals to fax out get fed. open up your control panel and locate piece of glass that goes left to right across machine. clean that good as you probably have white out or something similar on that.
hth,
razors
Sep 21, 2011 | Brother IntelliFax-2820 Laser Fax
Black Stripe on outgoing faxes
If the stripe is a thin line, the scanner glass is dirty, if it is wide stripe you have a bad scanner block. EXPENSIVE
Jul 01, 2010 | Brother IntelliFAX 4100 Laser Fax
Thick black line down recipeints faxes
Your scanner glass is caked with ink or lint. Open front cover and clean with windex or rubbing alcohol.
Apr 23, 2010 | Brother IntelliFAX 2800 Laser Fax
Black line going down the middle of the page
lift the auto feeder and clean the scanner glass that your pages scan across -it is dirty. You can make a copy afterward and this will tell you if you have solved the problem.
Mar 05, 2009 | Brother IntelliFAX 775 Plain Paper Thermal...
Black line about 1 1/2 inches wide down side of faxes or copies
if your RECEIVED faxes look good, then leroyal is dead on. you will need a new CIS which stands for contact image sensor. if you have an authorized brother service center nearby, they may be able to do it for 100 to 150.00, depending on their pricing of course. if rec'd faxes are bad also, pull drum out and make sure the blue tab on top of drum is all the way to the right side, although that usually only leaves about a 1/2" black band.
hth,
razors
Jan 27, 2009 | Brother IntelliFAX 4100 Laser Fax
Black line down middle of page
Clean the inside of the printer with a soft rag, be gentle and get as much toner up as you can, also your toner carttridge may be empty or the crum may be bad, start with a fresh toner carttridge and clean the printer out where the cartridge sits.
Dec 13, 2008 | Brother MFC-7820N Laser Printer
Black stripe down middle of page when copying
open the top cover on the left hand side glass plateform with a narrow piece glass clean it with alcohol.
Dec 13, 2008 | Brother MFC-7820N Printer
Thick Black Line on my copies and faxes
Can't image it being anything but scan glass, if prints are fine, are you sure you cleaning scan glass(inside of where originals are fed)?
If so then scanner lamp faulty, but I've never come across it myself on this model.
Oct 26, 2007 | Brother MFC 8500 All-In-One Laser Printer
Sharp AR-F152 Fax Logo
199 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
amir hamza
amir hamza
k24674
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
