Question about RCA P52926 52" Rear Projection Television
Audio The volume is not working on the set. I cannot locate the original remote and I need to see if I can fix it by using the menu or do I need to have a repair man come out. Can someone help me? Billie
  • Justmyself Jan 30, 2008
    Volume suddenly stopped. have original remote, don't know what to do with it. Picture fine, just no sound. Please assist
  • ucmajorpharr Aug 21, 2008
    I was watching my T.V. and suddenly the volume went off. The picture is fine, but just no volume.
    Aaron P
  • RCA Master
  • 5,138 Answers
Do you have menu btton on front of tv if so press menu then use your channel up&down bottons to move to audio then use vol- and vol+ to turn sound on.also check to see if speakers are on internal or external make sure it is on internal speakers. you can go to dollar store buy 4 in one remote controller only 5.00 codes are in book .your code 000
Posted on Jan 25, 2008
Samsung tv mute button is not cancelling tried to get volume back but cant get any sound
  1. On the TV remote, find and press the Menu button to enter the display for audio and video settings on the TV screen. ...
  2. Locate the Audio menu to turn the speakers on or off and select "on"
  3. Select "Fixed" in the Audio out section of the setup menu if available.
If this does not work add the model number to your post.
Sep 25, 2017 | Samsung Televison & Video
No sound
  • 1 Make sure that your audio cables are plugged in properly to the correct ports if your audio is distorted or noisy. Every cable should be inserted completely. If you still encounter bad audio, replace the cable and then attempt to use a different device with the old cable. This will help you pinpoint the source of the bad audio problem.
  • 2 Use the "Volume up" button on the remote or TV buttons panel to turn up the TV audio volume if the volume is quiet. If the volume is still quiet, check to see if your audio source device has volume settings. If it does, turn the up the volume on your device (see your device documentation if you need help with this).
  • 3 Press the "Mute" button on your remote control to disable the mute function if you can't hear any audio. Once disabled, press and hold the "Volume up" button on your remote control to turn up the volume. If there is still no audio, press the "Menu" button on your remote control, select the "Audio" menu, and ensure that the "TV Speakers" are set to "On." If you are still not having any luck and are using the built-in TV tuner, open "MTS Audio" inside the "Tuner" menu and make sure it is set to "Stereo/English." If there is still no audio, verify that all your audio cables (including the antenna cable if you are using one) are plugged securely into the proper ports on your TV and audio source device (if applicable). If you are using an antenna, reposition it to a clear, open area; preferably near a window. If your audio source device has audio settings, check to make sure they are set the way they should be (see device documentation).
  • Read more :
    Mar 08, 2014 | Vizio Televison & Video
    Panasonic CT 27 SL - 13 GL how to connect external speakers
    This TV is set up to connect to an external amplifier which that controls the speakers. It has an analog audio output which means you need an RCA audio cable (2 RCA plugs (red and white) on each end. You can't directly connect a set of speakers. The audio output jacks at between the antenna in and the video inputs. Then you need to enter the menu and enter the Audio submenu. Go to the Speakers item. Turn the TV speakers to off and fixed audio out.(The amplifier will adjust the volume.) Use the Up/Down arrows to navigate through the menu options, press enter to enter a sub-menu and the volume up button to change a setting.
    There is also a headphone jack which may be compatible with computer speakers. That has a 3.5 mm jack. To use headphones, set the Speakers Audio item to TV speakers Off and variable audio out. (The TV controls will adjust the volume.)
    To use a Universal remote to set the audio or modify the channel list, you need one that matches the Menu function of the original remote. You may need to try multiple codes for Panasonic TVs to get the button to work. Some low-end universal remotes may not have the menu button; get a different remote or use the menu button on the front panel of the TV.
    To set the channel list, press Menu and select Setup. Go to the Prog Chan option. Then set your Mode in the first option (Cable or Air). Then choose Auto Program to scan all channels or Manual Program to edit the channel list.
    The manual for the TV is available at retrevo: . You will need to enter a code to access the manual. See page 5 of the manual for the input connections (page 7 of the PDF).
    Sep 13, 2012 | Panasonic Televison & Video
    Sony KE-42M1 Volume Out Settings Change
    Some of the sets in the service menu you can be altered but usually it is only for initial vol level when set is turned on. All adjustments are done with the Sony remote.
    Aug 31, 2012 | Sony WEGA KDE-61XBR950 61 in. Plasma HDTV
    Got a Sanyo DS25320 and using a universal remote. The screen is blue and says Video and when I hit menu it only gives me the option of auto/ manual/ game or language, can not get to the other selections....
    The tv universal remotes are having very limited options in functions and tv universal remotes are only work correctly are like buttons power on/off volume up/down and channels up/down.Menu button and a Video setting option modes functions setting are another story all together.These two functions Menu button and Video setting modes funtions will not work correctly in any tv universal remotes.Because these Menu and Video setting modes are belong into the internal setting of the tv itself.It will only work correctly with the tv original remote only.Try website like to buy the tv original remote to use.
    Sep 15, 2011 | Sanyo AVM-3259S TV
    No volume in Zone 2
    Get the original Yamaha remote, go to Set menu, manual setup, speaker setup, and look for "extra speaker." it needs to be set to "zone 2." This is off the top of my head, so it should be pretty accurate. Get used to doing this, though, as this amplifier assignment to zone 2 is prone to resetting itself in those Yamahas.
    Sep 05, 2009 | Yamaha RX-V661 Receiver
    Max. VOLUME on Samsung TVs Too Low
    Some models have a volume limit setting, check the MENU and look at the audio settings.
    If this has external speakers use other speakers. If it has audio output connect them to a external amp and useing the remote adjust the volume. Check if audio settings are set to internal, external and fixed or vairable output.
    Jan 09, 2009 | Samsung LN19A451C LCD TV
    Using headphones with Logitech X-230 speakers
    I really don't know, because some of the newer gadgets come with fixed volume control due to law suits, ect. Try to see if you can bring you TV menu up and see what the sound setting is.
    Dec 25, 2007 | Logitech X-230 Computer Speakers
    Volume control doesn't work on the enternal speaker
    On some sets that have audio output jacks, the level of the audio output on the RCA jacks is fixed, and it does not change with the TV's volume control. On some sets, such as Sony, you can choose fixed or variable output. I have also seen some sets that have both fixed and variable RCA jacks on the back. With variable audio out, the audio level at the audio output jacks follows the TV's volume control. If you go into the TV's menu and navigate to the audio page, look for fixed or variable output options. If you have the owner's manual, read the section on audio output. If variable output is not an option on your model, then the level is constant and the volume will have to be adjusted with the stereo's volume control.
    Aug 25, 2007 | Toshiba 27DF46 27" TV
    RCA P52926 52" Rear Projection Television Logo
    27 people viewed this question
    Top RCA Televison & Video Experts
    matt martin
    matt martin
    Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
