CANON PC 20 COPIER
Copies come out wrinkled; i see a spring hanging loose one the far side of the paper feed area, but cannot figure out where to attach it.
also, copies have black streaks despite cleaning all copying areas and other areas of regular cleaning
  • a4nier Oct 24, 2008
    My copies alaso come out wrinkled. I see a clear plastic band on the left side just forward of the feed rollers, that seems to be broken.
  • todorovic_dg Nov 13, 2009
    canon fc 20 error code e 0
    Problem Solver:
  • 7 Answers
I think the plastic broke that held the spring, so you need to figure out where it broke and drill a new hole for the spring, and sounds like you need a new cartridge, GOOD LUCK!!!
Posted on Jan 24, 2008
I have an imagerunner 2800 and it only seems to jam in the tray loading area, just bends the long side of the paper randomly. It changes it's performance just like the weather, sometimes I can get multiple...
A couple of things to consider:
Do not load the following types of paper in the paper drawer. Doing so may cause a paper jam.
- Severely curled or wrinkled paper
- Heavyweight paper
- Transparencies
- Paper on which color images have been copied.
- Paper which has been copied on using a digital full color copier (do not copy on the reverse side
either).
- Paper which has been printed on using a thermal transfer printer (do not copy on the reverse side
either).
Also, what # paper are you using?
Oct 12, 2013 | Canon (6981A002AA) for imagerunner 2200,...
Copier wrinkles copies
It cuold be that paper has too much moisture or you nned to replace press roller bushings alonh with cleaner and fixing film
Apr 30, 2010 | Canon PC-940 Black and White Copier
What button do you push, or how do you make a double sided copy on this machine...I've been stuck for awhile. thanks
Canon PC 921 copier does not offer automatic duplexing. It is possible to copy first side, then take the copy and feed it into the bypass (manual) feeder on the right side of copier with printed side facing down or placing in paper cassette printed side facing upward. Don't forget to change your original for second side.
Nov 19, 2009 | Canon PC-921 Black and White Copier
My copy is coming out wrinkled and threw the top slot by the rollers.where the normal copy would come out. Nothing is ****,paper is full,ink level reads green?? I just made a copy yesterday and it was...
There are about 4 possibilites. The paper in the drawer could have bent up corners, not laying in there good and flat, Fuser rollers bad or uneven spring pressure, something could be wrapped around registration roller or something in the paper path is catching the paper as it goes through the copier. Please rate this. Thanks
Jul 01, 2009 | Canon Office Equipment & Supplies
How to avoid paper jams?
hi,the best way to avoid paper jam is cleaning.clean
first paper transportation area,second paper feed rolls in trays.send me result
May 31, 2009 | Canon PC-921 Black and White Copier
Canon pc 420 paper feeds only part way
I had the same problem. I found a parts diagram here http://techno-parts.org/canon/220/320_220.php which showed that the springs hold the bar down. On mine, on each side, one of the spring tabs was broken.
I made a metal pin for one side and insert a screw on the other. Be sure and wrap the spring over the nylon bushing.
May 26, 2009 | Canon PC-420 Copier
Lines repeating on copied paper from Canon PC 745 copier.
You probably have a piece of paper wrapped on your pressure cleaning roller inside the fuser. The patterm on the paper is the same and the spacing is equal and it is in the direction or feed.
Apr 11, 2009 | Office Equipment & Supplies
Paper feed problem Canon PC25 copier
check where exactly it wrinkle .it is most likely to be from the fuser unite.i.e where the paper comes out .if the fuser rollers is having mark or the paper sepration finger ontop of the roller is bend or loses its springing ability
Oct 07, 2008 | Office Equipment & Supplies
Canon pc 430 feeder problem
You may have to fabricate a new anchor for one end of the spring on the side opposite the control panel. There is a wimpy plastic tab that breaks off here, right next to a black Phillips-head screw. Remove this screw and bend a piece of light wire around it, leaving a small hooked end sticking out for the spring to fasten on to. Replace the screw and install the spring. When you install the spring, it must go over the top of the tiny white plastic wheel, in the U-shaped groove.
This is how I repaired my PC430 several years ago and it's still working fine.
Jan 27, 2008 | Canon PC-430 Color Copier
340 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
