Question about HP Compaq Presario R4000 Notebook
Memory upgrade I have located the obvious memory bank located on the bottom middle panel but I cannot find the second bank that supposedly exists, and do not want to tear the entire LT apart to find that it was located under the keyboard or somthing. Please help
It is located under the keyboard. It is concealed under a foil sticker.
Posted on Feb 05, 2008
    Genius:
  • 1,003 Answers
THIS IS THE ONLY ONE YOU WILL SEE AS THE OTHER IS MOUNTED ON MOTHER BOARD BUILT IN THE ONE YOU SEE IS THE ONLY SLOT AVAILABLE FOR UP GRADE
Posted on Jan 24, 2008
My w3107 machine tower just beeps repeatedly when you turn it on and the hp vp17 monitor just says no input signal. Any ideas on how to fix it before my husband throws it out the window?????
Constant beeping when you turn a computer on is an indication that you have a RAM memory error. To confirm this, open the tower (after unplugging the unit and pressing and holding the power button in for 10 seconds to confirm there's no charge left). Locate the sticks of RAM memory and remove 1. Then plug the unit back in and reboot. In most cases, the beeping will go away and the machine will boot up. This doesn't usually mean you have a bad RAM memory module, just a bad "bank" on the motherboard. If you like the machine, and removing the RAM works for you, you can either run minus the stick of RAM (the machine will be slower) or do a motherboard upgrade. You can usually get a good motherboard + CPU upgrade in the $90 range. Choose a motherboard that will accommodate the existing RAM memory to keep the project cost effective.
Sep 06, 2011 | HP Computers & Internet
Changing memory chips-memory upgrade
there is a panel on the bottom of the computer that has one or two screws. take the panel off and you can remove the existing memory and replace it with the upgrade --- PC2700 memory. If this helped you, please rate me. Thank you
Jun 30, 2010 | HP Compaq nc6120 Notebook
Adding computer memory
The only thing you could do is put in a 256MB module in the slot that you have access to. Only one socket is user upgradable. The second socket is only upgradable by a Dell service center. They would have to install a second 256 module to get you to the 512MB max.
Jan 22, 2010 | Computers & Internet
How to install RAM?
You can get detailed description of how to install the ram in the below link
http://www.helpwithpcs.com/upgrading/install-laptop-memory.htm
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
Aug 05, 2009 | Toshiba Tecra M7 Tablet PC
Where is the second SO DIMM slot on my nw8440
Here you go.
You'll need Adobe Reader or the like to view.
Jul 10, 2009 | HP Compaq nw8440 Notebook
Where are the ram chips located on balance cn 1401? i would like to upgrade my memory.hwo do i do it?
usually under the bottom of the laptop there are some covers, the memory will be under one of them. To see what to look for follow this link: http://img.zdnet.com/techDirectory/_MEMMOD.GIF To find a compatible module run the tool from crucial http://www.crucial.com/systemscanner/index.aspx
Jun 21, 2008 | Balance CN1401 Notebook
Sony A690 Memory Location
Some Vaio laptops (and some HP's) have a memory slot under the keyboard.
Jan 26, 2008 | Sony VAIO VGN-A690 Notebook
How to upgrade memory
The NEC Versa m500e has 2 memory slots. Each slot can hold DDR PC2700 with a maximum of 512MB per slot.
I'm not sure where the memory is located on the Versa, but normally in the middle on the bottom of the laptop there is a memory slot. on some units the memory is located under the keyboard, so you have to remove this first to change the memory.
Hope this helps
Dec 27, 2007 | NEC Versa FX Notebook
Compaq armada e500 memory
memory modules are under keyboard,you have to remove this first,1 hidden screw under(indicates a keyboard) and the 4 holds between the Fkeys(pull them down).Remove the keyboard and you''be able to see them....Chris/Greece
Nov 13, 2007 | Compaq Armada E500 Notebook
Memory upgrade
First thin you have to remember is if you want to have to memories in parallel...Then the new one should be of the same size and frequency(ex:133Mhz,533Mhz..etc.,)Then folow these steps:
  1. Turn off the computer and remove all power cords from the computer system.
  2. Locate the panel used for access to the memory modules. This is generally located on the bottom of the laptop computer. Refer to your laptop instruction manuals for locating the panel.
  3. Remove any screws that the panel in place and place somewhere safe to prevent losing it.
  4. Remove the panel from the laptop and set aside.
  5. If replacing or upgrading an existing memory module, remove the memory modules by undoing and module clamps and gently lifting the edge of the module to a 45-degree angle and then pulling the module out of the slot.
  6. Align the notch of the memory module with that of the memory slot and gently insert the module into the slot at a 45-degree angle.
  7. Once all the pins are in the slot, gently rotate the module down flat until the clamps lock into the module into place.
  8. Replace the memory access panel onto the laptop computer.
  9. Replace any screws or fasteners that hold the panel in place.
  10. Replace the power cord and power up your computer system.
Oct 13, 2007 | Acer Aspire 3610 Notebook
Computers & Internet Logo
122 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
