Question about Metrologic Instruments METROLOGIC VOYAGER LASER SCANNER W/TRIGGER IBM PORT 9E (70004)
Ms9520 I have a metrologc scanner ms9520. It comes on with one beep at start up the infared comes on when you pass object under it. But it does not scan at all some times it will work when i check it but then it just stop suddenly. please can you give me some assistant.
  • 106 Answers
Try to reset a bar code ,from the manual
Posted on Feb 05, 2008
How i can configurate ms9520 by rs232 which command can i use
Scanners are programmed by printing the barcode & then scanning with them. For this one, go to https://www.honeywellaidc.com/CatalogDocuments/00-02544%20Rev%20K%202-11.pdf
print it & scan the relevant barcode.
Dec 16, 2014 | Microsoft Metrologic MS9520 Voyager...
I want scan barcode 39. Hou can i program mine ms9520 voyager scanner. Thank you
http://www.honeywellaidc.com/CatalogDocuments/00-02544%20Rev%20K%202-11.pdf
That is a link to the PDF help file for the MS9520. It has barcodes inside that you scan with your scanner to enable/disable certain features. It looks like you should be able to enable Code 39 barcodes by scanning the barcode found on page 2-2 (actually on page 10).
May 26, 2011 | Honeywell MS9520
We are using a Metrologic MS9520 (keyboard wedge) with QuickBooks. It won't scan barcodes provided by Quickbooks, even though it's supposed to be compatible. We've downloaded about every driver, config,...
What I would first is to bring the barcode scanner back to factory defaults. To do this you will need the manual that came with the scanner, on the first page is a bar code that say "enter/exit configuration mode" scan that first and you will hear three beeps, then scan the bar code for "recall defaults" and rescan the bar code to "enter/exit configuration mode" then retry using your scanner, if this does not work bring up "notepad" on your computer and try to scan any bar code form any retail item. This should scan, if it does net then it could be a defective scanner. See page 2 on the manual link
http://www.posguys.com/download/voyagerprogramming.pdf
Nov 11, 2010 | Microsoft Metrologic MS9520 Voyager...
Microsoft Metrologic MS9520 Voyager Barcode Scanner problem
If it is using the MX009 USB Cable it wont scan with the standard configuration. You will need extra configs such as enable Rs-232 Mode, Enable Xon/Xoff handshaking etc..
These can be found on the www.Metrologic.com website which will divert you to Honeywell website
May 25, 2010 | Microsoft Metrologic MS9520 Voyager...
I have not instruction for default settig where are barcode for default setting
Check metroselect single line configuration guide page no. 2
1) Scan Enter/Exit configuration mode it gives 3 beeps
2)Scan recall defaults it gives single beep
3)Scan Enter /exit configuration mode it gives 3 beeps
Now scanner is set to default setting
Sep 16, 2009 | Microsoft Metrologic MS9520 Voyager...
Metrologic barcode scanner - laser is a dot not a line
This would be a fault with the scan engine. The dot is created when the mirror inside of the scan engine is not oscillating. The best solution is to have the device repaired, hopefully your scanner is still under warranty, or to purchase a replacement. /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-parent:""; margin:0cm; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} @page Section1 {size:612.0pt 792.0pt; margin:72.0pt 90.0pt 72.0pt 90.0pt; mso-header-margin:35.4pt; mso-footer-margin:35.4pt; mso-paper-source:0;} div.Section1 {page:Section1;} --> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Mar 09, 2009 | Microsoft Metrologic MS9520 Voyager...
Scanner beeps. Laser is a dot instead of a line.
There is a problem with the scan engine. The dot is created when the mirror inside the scan engine stops oscillating. If your scanner is still under warranty send it back for repair or request a replacement.
Voyager 5929 doesn't work with Vista
The problem isn't your scanner or Vista, it's your adapter. Power requirements and speed of data require special adapters. One I always recommend is Scan Technology's part # STI-PS2-USB. I've tested it with all Metrologic scanners and it hasn't failed yet.
Dec 30, 2008 | Metrologic Instruments Voyager MS9520...
Locked Metrologic MS9520-37 (keyboard wedge) after unintentional programming
You programmed it for usb interface, but the scanner is keyboard wedge. Try pointing the scanner at the "recall defaults" barcode in the manual as you plug the scanner back in.
Feb 12, 2008 | Metrologic Instruments Voyager MS9520...
Ms9520 buzzez and then will not scan
Look at your user's guide on Pg 14, here is a online link for it: http://lib.store.yahoo.net/lib/barcodescannersdiscount/MetrologicVoyagerUG.pdf "Continuous Razzberry Tone with all LEDs off: If, upon power, the scanner emits a continuous razzberry tone, then the scanner has an experienced an electronic failure. Return the unit for repair to an authorized service center." Is the "Razzberry Tone" the low buzzing you refer to(?) Pg 24 has a "Trouble Shooting Guide" take a look at it too.
Jun 06, 2007 | Metrologic Instruments METROLOGIC VOYAGER...
Computers & Internet Logo
1,190 people viewed this question
Top Metrologic Instruments Computers & Internet Experts
Gareth Cockram
Gareth Cockram
xak_tay98
Level 1 Expert
Daniel Dollive
Daniel Dollive
Are you a Metrologic Instruments Computer and Internet Expert? Answer questions, earn points and help others
