Question about Frigidaire GLEH1642DS Front Load Stacked Washer/Dryer
Kenmore 110 45862404
The drum boot on my front load washer is damaged. apparently a pen was left in the wash and cut through & ripped the rubber off the drum. Water was all over the floor.
How do I replace this damaged part? Secondly, what part(s) do I need to order.
Is this a difficult repair?
  • labhiker Jan 24, 2008
    Mark,
    Can you re-send your response, for some reason the text in "Solution #2" did not come through.
    thanks
  • 4 Answers
noavatar_s.png marklfixit
Rank:nonexpert_s.gif Apprentice
Rating: 0%, 0 votes
Replace the front bellow or front seal, as it may be called. It is an inner tube shaped rubber liner that seals between the front of the washer door and the front of the drum. The cost is about $35.00-$40.00 and you will need the kit as it includes the rubber spacers that are essential to doing the job. The job takes about 1 1/2 hours to complete. It is not hard, but it is dedious and requires some basic skills. Directions included in the kit are helpful.
Posted on Jan 24, 2008
Noticed plastic slivers in the drum and under the rubber boot.Is the from the drum being unbalanced
Could be that the 'spider' mount for the drum is broken and the drum is catching on the surrounding plastic outer drum.
Mar 15, 2016 | Kenmore Elite 45986 Front Load Washer
Clothes getting burnt & torn in maytag front loading washer...how to resolve this issue asap?
Check the inside of the drum. Chances are, there is a sharp object pointing out that is doing this.
Jan 13, 2014 | Maytag EPIC MFW9700S Front Load Washer
Seems load is out of balance
Your washing drum is spring balanced and your
motor has rubber shocks to keep it balanced so check
both for damage. _( cracks in rubber shocks and breaks in
washing drum spring or springs ) Also springs or rubber
shocks are no longer fastened to motor or chassis.
Feb 11, 2011 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Front gasket ripped
Typically the tear comes from something getting caught on the rubber boot or bellows as it is called on this machine. Or if a pen is left in a pocket it can cause a hole.
The bellows for your model is part number 8182119 and typically runs about $80.00
Here is a link to parts break down showing the bellows # 5 on this diagram. It is not hard to replace but you have to be fairly mechanically inclined. It is held on by a spring clamp in front and a large screw clamp to the tub.
http://www.searspartsdirect.com/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fK0503012-00002.png
Apr 20, 2010 | Kenmore Elite 45986 Front Load Washer
My whirlpool front loader washer leaks water in front of the washer from the bottom of the machine. It does not happen with every load. Any idea on the problem?
Check the rubber boot just inside the door. You have to push the drum back slightly and rub your fingers around the entire boot. I had a similar problem and a key had fallen out of a pocket and cut into that boot. The leak would run out of the damaged boot then come out the bottom onto the floor. I purchased a new boot and it took me about 30 min to install it. The problem was solved. If the rubber boot is fine then the over soap thing is probably your problem.
Oct 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Motor has load poping noise on front end load washer
If it is a front loader, reach just inside in the drum. Pull the rubber boot up and fell to see if something has gotten between the drum and the rubber boot, maybe a lighter.
Aug 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore HE 110.4751 front load
soild metal part fits in groove around door boot spring goes in at bottom they can be tough to get back on after inserting in groove around seal you'll have to stretch the spring and pop it under at the same time band will try to come back out and roll seal back off lip..good luck
Jul 16, 2008 | Kenmore Elite 45986 Front Load Washer
KHWS01PWH0 Front Loading Automatic Washer Leaking
out the bottom of door?? no through the bottom panel???. check the rubber door seal for rips or tears pull it back and look around entire circumference. smalll rip in very front of seal where door should close against will cause leak for sure
Mar 07, 2008 | KitchenAid KHWS02RMT 3.7 Cu. Ft. Ensemble...
Tub seal has rip therefore washer is leaking.
Its pretty comlicated requires dissasembly of the front of the washer. A good tech can do in 1 hour. You may want to pay for it rather than spending all day and possibly damaging something. Let me know if you need further assistance.
Jan 24, 2008 | Kenmore Elite 45986 Front Load Washer
Frigidaire GLEH1642DS Front Load Stacked Washer/Dryer Logo
137 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
