Question about Acer AL1711 17" LCD Monitor
Changeing the refresh rate
I'm using a converter box to use The Acer AL1711 as a TV set for games consoles. I have misplaced the manual for the monitor and am ondering how I go about changing the refresh rate from 50Hz (Current setting) to the required setting of 60Hz. Any ideas welcome.
Thanks in advance,
Wyn
    Novelist:
  • 139 Answers
You can download the manual and view it on this Acer web page. The monitor should adjust itself to the refresh rate provided by the converter box...but you can experiment with the picture clock settings described on pages 9 and 10.
Posted on Jan 24, 2008
My Acer AL1711 goes black but the light indicator on..i've read some of comment similiar to my problem and tried to repair it..but still..it didn't work..i even replaced the 1000uf capacitor..but...
When you repalce the caps, they should be repalced in a set since bad caps can look normal but can have high ESR.
http://s807.photobucket.com/albums/yy352/budm/ACER/Acer%20AL1711bm/
And yes, you can have bad lamp assembly:
http://s807.photobucket.com/albums/yy352/budm/Bad%20backlight%20lamp/
You need spare lamp the test the inverter board.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
May 20, 2011 | Acer AL1711 17" Flat Panel LCD Monitor
Just bought a used SNES. The picture quality is not so good and there are lines scrolling down the screen. Are there ways to improve this coloration related issue?
I would suggest checking the connectors from the console to the tv, as if there are heavily worn they may cause a poor picture. There is not a lot you can change with the SNES in terms of improving the quality, therefore I suggest also checking on another TV to ensure that is not the problem.
May 04, 2011 | Nintendo Super NES Console
How do I connect my acer travel mate 4010 to my sony bravia tv using a vga cable. everything is plugged in but can't get picture on my tv.
Compare the resolution settings on the Travel Mate 4010 with the available resolutions on the TV. You must set the display resolution and vertical refresh rate (sync rate) on the Travel Mate to match one of the formats used by the TV. You will probably have to look in the manuals for both units.
Apr 02, 2011 | Computers & Internet
I got a new tv 52" sanyo i was pretty good at the cod games and now everything feels delayed i reset my tv..... then when i looked in the tv menu it said on tv if you have this problem go to console...
This will probably be due to the refresh rate of your new screen, plug your PS3 into your old screen if you don't experience this delay effect it is due to your TV. There is no way to fix this on your TV so I would take it back to the store and buy a TV of a refresh rate of at least 60Hz 120Hz would be best though.
Mar 08, 2011 | Sony Playstation 3 (PS3) Console
Acer monitor lights then off immediately
Look for bad caps with domed tops, replace them in a set.
http://s807.photobucket.com/albums/yy352/budm/Acer%20AL1711bm/
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Please leave rating if it helps.
Feb 06, 2011 | Acer AL1711 17" LCD Monitor
My acer al 1711 monitor goes off after three seconds of applying new settings with resolution chgs or refresh rate the monitor display is blank but the light is green.
my acer al 1711 monitor goes off after three seconds of applying new settings with resolution chgs or refresh rate the monitor display is blank but the light is green.
Nov 27, 2010 | Acer AL1711 17" LCD Monitor
On booting up, screen stays black. When I switch it off and on, picture appears briefly. I need to do this several times before the picture finally "catches" - and then stays stable.
this could happen when there is a missmatch in the operating frequency (refresh rate) between both VGA card and screen, try to reset your screen settings to default, and set the refresh rate on your vga card settings to 60 HZ
Feb 19, 2010 | Acer AL1711 17" LCD Monitor
I misplaced manual for my 13 inch DWT 1304 and I need to set up tv for antenna reception in order to program my dtv converter box - in order for converter box to work, along with the indoor antenna, I have...
http://www.funai-corp.com/support/manuals.aspx
Click on link to download the manual for your tv.
Please rate this solution, the only compensation I receive is a good rating from you.
Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
May 03, 2009 | Televison & Video
I get snow on the screen when I play DVDs
I have a feeling it could be the refresh settings on the xbox 360, some games require a different i know Hitman u need to change the refresh setting to play the game. Have a look on the back of the box of the game it should state the refresh rate on the bottom.
hope it helps
Z33m
Dec 10, 2007 | Microsoft Xbox 360 Console
Acer AL1711 17" LCD Monitor Logo
223 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
