Daniel I am using an HDMI cable to connect my Panasonic DVD-S53 upconverter to my 1080i LCD TV, and I have set both my 'Video Priority' and 'Audio Out' settings to ON, yet I am still getting what I percieve to be a 480i resolution. What settings should I adjust to recieve an upconverted 1080i resolution?
    Master:
  • 518 Answers
It'll still be 480i, it'll just work on a 1080i input now. You can't make HD out of a non-HD source.
Geno
Posted on Jan 24, 2008
OH. I have a DVD player/VCR Recorder. I have Cable TV. How do I connect DVD player/VCR recorder to Samsung Smart TV?
Unless your DVD/VCR is Upconverted to use HDMI, then you would use either the RED/GREEN/BLUE + Red /White leads to your TV and then use the TV remote to select whichever your TV names that input. If it is Upconverted, then simply plug the HDMI cable into a spare HDMI input.
Oct 06, 2016 | Panasonic Original Pansonic Tv Vcr Dvd...
How to connect DvD play?
It depends on the type of TV you're connecting it to.Please be more specify the models.Preferably,use Component Cable and left/right audio cable,next use a composite cable that has yellow video,white for left audio and red plug for right audio.The plugs and jacks are colour coded,so just match them and you're all set.
If it's a 1080 upconverting dvd player with hdmi and your tv is an HDTV with HDMI,use that.
Nov 23, 2012 | Hisense Televison & Video
Mitsubishi 55 in. 1080 series
If I remember correctly, this TV has a couple of constraints that will cramp your style:
1. It supports 480i, 480p and 1080i. NO 720P
2. It has component video inputs, but NO HDMI. (as you stated)
There is no easy solution here, because I've never found an upconverting DVD player that would upconvert anything past 480p using the analog component outputs...
So..
Perhaps you can find an Upconverting BLU-RAY disk player that may allow older DVDs to be upconverted to 1080i via the component outputs.
MOST Blu-Ray players allow 1080i output via the analog connections on Blu-Ray discs, so perhaps there is your solution.
Mar 09, 2009 | Mitsubishi WS-55311 55" Rear Projection...
Upscale from 480p Signal via HDMI
ok the problem might not be with your receiver it is with your direct tv settings. Double check to make sure you go to the format and set it up to be fixed or 1080i whichever will give you the highest resolution. Check your manual for the direct tv receiver. If this is all correct for the DTV then you must go into the setup on the receiver and at hardware icon toward bottom check on that box, now goto the hdmi settings and make sure it is set to through. this will allow the best picture with no upscaling which will degregade picture for blu ray. so your direct tv will be only 1080i but very impressive. if you still want to upscale you can then you have to change the hdmi settings from before to upscale 1080p . I just hope that your dtv can output 1080i it will give a better picture than 480p even if both are upscaled to 1080p
Oh i forgot to ask if you are connected through hdmi to the tv. Hdmi is the only option for upscaling
Feb 21, 2009 | Onkyo TX-SR606 Receiver
Dvd is grainy picture
You can use your old on, but I am guessing it doesn't have progressive scan. If it does, make sure to hook it to your TV using a component cable.( RED GREEN BLUE ) Then you will have to hook the audio up seperately with a standard red and white RCA cable. Do nt try to use a standard RCA video cable in the place of a componenet cable. Once you have the compnent (RGB) cable and RCA (RW) cable hooked to the TV, check the DVD menu and make sure it is set to Progressive Scan. If you want the best picture for your HDTV. I highly reccomend a blu-ray disc player. That is the highest quality. There are some prety good upconverting DVD players out there. They take the 480p signal and upconvert them to 720p, 1080i, and 1080p. These have HDMI outputs and connect quickly and easily to the TV you have. Most of them can be purchased for less than 100 bucks. But this would be your second best option. Before you shell out 400 bucks on a blu-ray player, go to a rental company and rent a blu-ray player. Once you see the quality of blu-ray, I think you will run out and buy one!
Jan 10, 2009 | Toshiba 19HLV87 19 in. LCD HDTV
Connecting LG DVD recorder to cable box and HGTV digitally
Two things come to mind: copy protection and resolution settings.
The TV may not allow copy protected material to come from your LG, or the sampling frequency may be unacceptable. On page 15 of the manual it talks about 96kHz and 48kHz frequency settings. The third thing to check is the vertical resolution using the RES button on the front panel. SDTV is 480, and HDTV is anything above that. Using the HDMI is supposed to allow upconvert to 1080i max if your set can use that resolution.
tom
Jan 02, 2009 | LG DR787T DVD Recorder
Philips 60
There will be a big difference in video quality between HDMI and S-Video. If you happen to have a DVD player that uses HDMI you can upconvert your movies to 1080i if your DVD player allows it. The only problem that you might run into is your audio. HDMI has audio built into the cable and DVI does not, with the HDMI to DVI cable you are going to have to find an alternate source for your audio to travel through. If you are looking for video quality get the HDMI to DVI cable.
Dec 14, 2008 | Philips 60PW9363 60" Rear Projection...
Upconversion to 1080i playback
Hey smittybd,
According to information provided by the manufacturer, this specific model DVD player is only able to provide upconverted 1080i images via its HDMI output and a maximum 480p resolution using its component connectors. Please keep in mind that while component cables are able to support 1080i and 1080p resolutions, not all hardware (TV's and DVD players) will support these resolutions through component connections.
If you're having difficulty locating a model that specifically supports 1080i resolution images through its component connections, you may wish to try visiting individual manufacturers' websites for more information. Some companies (such as Sony) will provide detailed information regarding what each type of connection is capable of in their owner's manual documentation.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jul 15, 2008 | Sony 36IN TV Stand Designed for Model...
DVD Upconverters???
Greetings jhays82,
Some DVD players can upconvert DVD signals to resolutions that match those of HDTVs, and send them to a compatible TV via a digital video connection. HDMI (High-Definition Media Interface) and DVI (Digital Visual Interface) both offer high-quality digital transmission of standard- and high-definition video signals. HDMI can also carry multichannel audio, and is backwards compatible with DVI (video only). So in other words, to receive the full benefit from an upconvert, you would want to hook it up with HDMI or DVI.
Thank You,
Agent Dort,
Go Ahead. Use Us.
Apr 14, 2008 | Televison & Video
Help!
Try pressing the HDMI button on your remote a couple of times, pause about 5seconds after each press it might be slow to change. If this doesn't work try connecting just the yellow lead(composite video) into the DVD player to the TV like the old days, probably AV1 or AV2 in the back of the TV. Then access the setup menu(setup button on remote). This will bring up a menu. Use the down arrow on the remote until HDMI setup is highlighted. You should then get a selection to turn HDMI on and select the different outputs(576, 720p, or 1080i). You might actually find the picture to be worse on some DVDs.
Apr 06, 2008 | Televison & Video
Televison & Video Logo
87 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
