Question about Mitsubishi WD-62327 62" Rear Projection HDTV-Ready Television
62" TV WD 62327
No sound
  • Mitsubishi Master
  • 8,617 Answers
You have 3 options 1 is replace the Audio PWB. The only other thing it could be is IC3E00 which is audio output (TDA8922J)
or it could be IC3A01 Sound Processor (C-MOS-MSP3445G-Q1-B8-V3). I will include a link incase you would like to purchase the service manual. If you have soldering and some testing ability the service manual may save you alot of cash. DLPs are expensive for a tech to service. You can get the full service manual here for 10.99. They will email it to you if yourequest it by going back to the site and clicking onto the contact them link and leaving your email address. Hope this helps. here is the link,
http://servicemanuals.vstore.ca/
Posted on Jan 24, 2008
6ya staff
SOURCE:
Wd 62327 DLP red 3 blinks 1 steady red light
Call for waranty repair if less than 3 months old.
Jan 08, 2010 | Mitsubishi WD-62327 62" Rear Projection...
Where is the lamp located in a 62" mitsubushi tv dlp wd-62327? am trying to install the lamp and can't find it.
Some of their models require taking off the lower front panel. Some are in the back to the lower right corner. There is a cover about 6x6 that is removed usually with two screws and the same for the front except it will be the lower left after the cover is off.
Nov 17, 2009 | Mitsubishi WD-62327 62" Rear Projection...
Where is the Lamp located in the Mitsubishi 2004 model the number is WD-62327
Turn unit around facing you, either on right rear side or left rear side, generally looks as though it is a vent cover with one to three screws holding cover in place. UNPLUG TV BEFORE YOU WORK ON IT AS ELECTRICITY CAN KILL YOU.
Oct 09, 2009 | Mitsubishi WD-62327 62" Rear Projection...
How do I install the lamp? how to install bulb mitsubishi wd 62327
The lamp is in the FRONT of the television set. Just remove the bottom front, no screws, and you'll clearly see directions on how to install the new lamp.
Simple, just a few screws.
Feb 28, 2009 | Mitsubishi WD-62327 62" Rear Projection...
Picture but no sound
OK, I don't have a 360, but are you sure the audio cable is connected, in the correct jack, and pushed all the way in? Sometimes it looks like the jacks are all the way in, but they are not. Thus, no audio. You could also try using Component 2 if that is an option on the TV. Maybe Component 1 ports are bad. Hope this helps.
Jan 24, 2009 | Mitsubishi WD-62327 62" Rear Projection...
Troubleshooting Mitsubishi WD-62327 62 in. Rear Projection HDTV
There are filters that need to be cleaned first off. Then I checked with some people in the TV Repair Business & they gave me for FREE some helpful hints before pursueing expensive repairs.
Nov 30, 2008 | Mitsubishi WD-62327 62" Rear Projection...
Mitsubishi WD-62327 no pix and no sound
First do the self diagnosis test, search threads here or go to www.ctechnicians.com
Dec 03, 2007 | Mitsubishi WD-62327 62" Rear Projection...
Replacing the lamp wd-62327
Did you get correct lamp:lamp part # 915P020010 ?
Sep 07, 2007 | Mitsubishi WD-62327 62" Rear Projection...
Mitsubishi WD-62327 62" Rear Projection HDTV-Ready Television Logo
99 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
