Question about E-Machines eMachines Desktop PC
Computer error (BAD BIOS0
My emachines desktop gave a bad bios error, eventually power supply went bad,whiced i replaced. still will not boot,power supply keeps kickinf off. should i replace bios?
  • 1,226 Answers
Examine your mainboard maybe there is some busted capacitor on it.
If you don't see any thing on the board please observed the the following.
Did you see blue screen b4 it kick off? if so then, you a problem in your system.
please notify me for more support.
Posted on Jan 24, 2008
  • Emelio Navaja
    Emelio Navaja Jan 24, 2008
    try reinstall the system so that bluescreen will be elimated if so hoever if non then, mainboard we will discussed later.
Media test failure
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Mar 23, 2012 | eMachines T3604 PC Desktop
When i try to trun on my computer the fan doesnt stop so nothing goes to the screen
Sounds like the power supply or the motherboard. If you have another computer available, you can test the power supply. Just "borrow" the power supply from the other computer. If it still won't come on, then the motherboard might be bad and you'll need replacement.
If you swap the power supply and the motherboard is bad, you will not hurt the working power supply. The motherboard is already dead and won't feed back to the working power supply.
Also, if you have flashed your BIOS recently and it has not completed successfully, you might have a dead motherboard and you will need to replace it. You would know if you flashed or updated your BIOS chip.
Oct 25, 2009 | E-Machines eMachines Desktop PC
Emachines t3958, bad ram, green stand-by only no boot
Are you saying you bought 2 more machines to fix the problem? I don't understand. Do you have the manual for the machine. How long did your system run before a Ram stick went bad? What brand and size are your Ram sticks. Are they identicle? As far as Clearing BIOS, your manual should show you the jumper position to do this, which you will leave in this ( drain ) position for a minute. Powering up from here you need to immediately hit a key to send you to BIOS most are <del> or F10 or alt esc. You must look in your manual for this and then all your boards should work. If you need my help in finding your manual, give me all numbers pertaining to your machine.
Oct 12, 2009 | E-Machines eMachines Desktop PC
Powerbutton connection wires were disconnected from motherboard
Look in the manual there is a diagram and pin connections for each wire.
Feb 06, 2009 | E-Machines D2046 PC Desktop
Hi... When I push the power button on my HP Desktop, just the amber light in the button comes on....nothing else. No noises (hard drive spinning-up, fan, etc)...nothing.
The amber light is signifying an error. Most common are the power supply, video card, or RAM. Worst case is motherboard has went bad. Try reseating the RAM without installing the video card, if it boots then it's the video card. Replace the bad part & you should be up & running again. Hope this helps & please remember to rate my answer. Thanks.
Jan 02, 2009 | E-Machines eMachines Desktop PC
EMachine T3406 wont boot
is there a post beep when the pc is switched on. check the memory if it is a beep beep beep sound , also disconect the hard drive, dvd drive, floppy, and any usb devices and see if it boots up. if that fails it does seem like the mother board, also check the cpu fan has it stoped. also find out the power switch conector on the mother board, from the base unit switch to the mother board. also chech the power connector from the power supply to the mother board , on newer boards there are two that go to the mother board its self , a big one and a very small one .
Jul 05, 2008 | E-Machines eMachines Desktop PC
BIOS "Phlash" Error
pls run an earlier version of windows xp i.e. sp1 as earlier processor and motherboard may run xp sp 3 but it will not provide 100% compatibility
Jun 23, 2008 | E-Machines eMachines Desktop PC
Emachine t2642 power supply
Apparently this model has a bad motherboard, which manifests as a power warning and eventually a refusal to boot up. You can replace the power supply (as far as I know, any generic one 250-watt or better will work) but it's unlikely to help. You can buy a new motherboard (and new power supply, if you want to) direct from eMachines, but it's also likely to fail pretty soon. Your best bet is to get a new computer (NOT an eMachines one) and put your hard drive in as a slave so you can get your data off.
Jun 19, 2008 | Computers & Internet
Replace the CMOS battery that is busted. after replacing configure in bios setup and load bios setup default.
Feb 01, 2008 | E-Machines eMachines Desktop PC
E-Machines eMachines Desktop PC Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
