Question about Pioneer CDJ-800MK2 Turntable
JOG MODE NOT PLAYING IN JOG MODE. CAN U HELP ME PLEASE!!
  • 36 Answers
If the arm jos, check the effective weight. if might be too light.
if you do not have equipment,
1. keep the arm in balance / floating level,
2. adjust the weight at back to allow the cartridge to fall, little by little, until it does not jog.
3. then adjust the counter-balance bias, little by little if you do not have the spec.
pc-cook
Posted on Jan 25, 2008
How do I set the date
1. Close the lens barrier and press the LCD monitor ON/OFF button to turn on the LCD monitor.
2. Press the Menu button to display the Menu.
• See page 37 for how to use the Menu.
3. Press the top/bottom arrows on the Jog dial to select MODE SETUP, then press the right arrow.
4. Select the date order using the top/bottom arrows on the Jog dial. Press the right arrow on the Jog dial to adjust the first setting month/day/year.
5. Press the top/bottom arrows on the Jog dial to adjust the first setting, then press the right arrow on the Jog dial to adjust the second setting.
Repeat until the minute is adjusted.
• 00 will appear for the year 2000.
6. Press the OK button to save the setting. Press again to cancel the Menu.
• For accurate setting, press the OK button when the clock hits
00 seconds.
• If the Menu button is pressed before the OK button, the
setting and Menu mode will be canceled
Jan 31, 2012 | Olympus D-460 Zoom Digital Camera
I have a sony ericsson p990i with following (EMEI:35870030015682, EMEISV:78, EMEI:135790246811220). This phone hangs so much, and also it scrolls so fast even if you've not touched anything and lastly it...
You can do this by entering the Service Menu and selecting Format. Here is how to get there:
  1. In flip closed mode: jog-dial up, *, down, down, *, down, * -
  2. In flip open/removed mode: In phone application, jog-dial up, touch *, down, down, *, down, * .
Apr 26, 2011 | Sony Ericsson P990i Cellular Phone
How reset my sony ericsson phone lock code
Apr 18, 2011 | Sony Ericsson P990i Cellular Phone
Each time i start the phone it restart by it self and keep restarting
You will have to format your phone. Here is how to do it.
Enter the Service Menu and select Format. Here is how to get there:
Mar 29, 2011 | Sony Ericsson P990i Cell Phone
Hey! my CDJ is playing and stopping, playing and stopping not in any sort of pattern either. almost like someone is touching the top plate in vinyl mode. it happens aswell if you try and slow down the...
Hi, if you mean the fault occurs in the cdj vinyl mode and your cd dosent play... then it sounds like your jog wheel sensor membrane. but would have to be checked firstly by an engineer.
if you live in the uk then you can send your pioneer cdj for repair to www.audiovisualservices.info
Hope this has helped you.
Feb 14, 2011 | Pioneer CDJ-1000 CD Player
I am in the "s" mode for shutter speed priority and i cant change the shutter speed i use the scroll to get the arrow above the shutter speed on the view finder and from then i cant figure out how to...
Are you pressing the jog dial to save the setting? Here's what your book says:
  1. Turn the Mode dial to P, A, S, M, or C.
    The mode options are displayed.
  2. Use the jog dial:
    • Press the jog dial to open a setting.
    • Press the jog dial to save the setting.
    NOTE: Available options are white. Unavailable options are grey. Red options are out of range and may cause unacceptable image/print quality. Adjust the value higher or lower until it turns yellow.
Jun 11, 2010 | Kodak EasyShare DX7630 Digital Camera
My Aiwa cx-nma545 keeps turning off.
Your system is in 'Eco' mode. If you are in this mode, and go 10 minutes without playing a CD or cassette, it will automatically turn itself off.
Here's how you get out of 'Eco' mode:
1) Go to the jog wheel assembly
2) Press 'Eco'
3) Press 'Enter'
4) The display will show "Eco Mode On"
5) Immediately turn the jog wheel, to turn the status from 'On' to 'Off'
Feb 08, 2010 | Aiwa NSX-DS55 CD Shelf System
Pioneer cdj 800 mk2 playing mp3s, jogwheel & screen dont work
More than likely the contact pad (aka Membrane pad) is probably damaged... or the flat cable which connects to the main processor, might be loose, or damaged.
You'll need to get this professionally checked out by a qualified technician. It's not an easy fix.
- OPTiC
Master Tech
Digital Analog Therapy
Pioneer Repair : Pioneer Parts
Aug 28, 2009 | Pioneer CDJ-800MK2 Turntable
CDJ800 vinyl modus
Hi Mate
My last post was a CDJ with a separate fault, causing a similar type fault.
99% of the time, this particular fault is the Flac switch under the platter jog wheel, take the jog wheel apart clean the plastic strip that runs around the jog wheel, the one with rubber feet that activates as a pressure switch.
Often there is air bubbles, liquid, condensation in between the two layers - causing it to stay in touch mode. If that doesn't fix it then you need to replace that strip (pressure switch). They are about £30 quid.
All the best and good luck
Dec 04, 2008 | Pioneer CDJ-800 Turntable
Cd not playing in dj mode
Sounds like one of the motors went bad. If so, only a professional will be able to replace it.
- Davis
DIGITAL ANALOG THERAPY
www.repairnyc.com
www.djproaudio.com
Nov 19, 2007 | Pioneer CDJ-1000MKII CD Player
Pioneer CDJ-800MK2 Turntable Logo
194 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
