Question about Apple iPod nano
Folder with exclaimation
After my son plugged into a differant computer he now gets this icon and can not do anything with the ipod. what can he do to remove and use regular again
[email protected]
  • Howielawton Jan 26, 2008
    I have the same problem I have tried to reset the Ipod and have looked on Apple.com/support/Ipod without any luck
    President:
  • 317 Answers
First make sure your hold switch isn't on. It's on the top or bottom and slides back and forth. It needs to be switched to the left. Once it is to the left, here's how you reset:
You can reset your ipod by holding down the menu and select (round button in the center) buttons down for at least 10 seconds. You'll see an apple logo flash, that's when you stop pressing the buttons. It will shut off, then back on.
If that doesn't work, try a restore:
How to restore iPod
  1. Ensure that you have an active Internet connection as new versions of iTunes and iPod Software may need to be downloaded to your computer.
  2. Download and install the latest version of iTunes if you do not already have it installed.
  3. Open iTunes, and then connect your iPod to your computer using the USB or FireWire cable that came with your iPod.
  4. After a few moments, your iPod will appear in the Source panel in iTunes.
  5. Select your iPod in the Source panel and you will see information about your iPod appear in the Summary tab of the main iTunes windows.
  6. Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download the latest iPod Software. The 4 possible restore options are:
    • Restore Option 1: Restore - Restores with same iPod Software version already on iPod.
    • Restore Option 2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available.
    • Restore Option 3: Use Newest Version - Restores with the latest iPod Software available.
    • Restore Option 4: Restore and Update - Restores with the latest iPod Software available.
  7. If you are using a Mac, a message will appear prompting you to enter an administrator’s name and password.
  8. A progress bar will appear on the computer screen indicating that the first stage of the restore process has started. When this stage is completed, iTunes will present one of two messages on screen with instructions specific to the iPod model you are restoring.
    • Restore Instruction 1: Disconnect iPod and connect it to iPod Power Adapter (typically applies to older iPod models).
    • Restore Instruction 2: Leave iPod connected to computer to complete restore (typically applies newer iPod models).
  9. During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage. Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.
  10. After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
Posted on Jan 26, 2008
6ya staff
SOURCE:
My son forgot his passcode on his ipod and now it is disabled. Please assist me in fixing this. Thanks
plug in his ipod into itunes and then press on your son's ipod and then click update that should get his ipod back to normal.
Jul 04, 2010 | Apple iPod touch
My son has a nano ipod and he locked it with a commbination and forgot it how do i unlock it?
Try plugging it into the computer your son normally syncs it with. Then open iTunes.
After iTunes recognizes the nano, you can eject and disconnect the iPod from the computer. It should be unlocked.
If that does not work, then you'll have to restore the iPod (which will remove *all* music, etc. from the iPod).
You can do that like this:
plug it in to your computer
launch iTunes when iTunes recognizes your nano, Resync the iPod (so the data is saved on the computer) Then click on "Restore" (on the "Summary" tab).
Then follow the onscreen instructions.
You'll need to resync all your music etc. to get it back on the iPod.
Hope this helps!
Jun 08, 2010 | Apple iPod nano
My son put in a code on my ipod.
there are to options by which you can unblock the code on your ipod. Follow any of the procedures tomorrow.
Unlock with the Primary Computer
  1. Plug the iPod into the primary computer linked to that iPod, the first computer you synchronized it with unless you have designated another computer as the primary computer.
  2. Open itunes and sync the iPod as normal.
  3. Remove the iPod, following the normal removal procedure. The iPod unlocks automatically as you remove it.
Unlock by Restoring
  1. Restore the iPod to factory settings if you do not have access to your primary computer. This erases all of the data you have stored on the iPod.
  2. Plug your iPod into the new computer you want to be the primary computer. Open iTunes and click on the "Restore" button.
  3. Reload your data, if it is available and sync your iPod. Remove it following normal procedures.
Good luck.
Jun 01, 2010 | Apple iPod MA446LL/A MP3 Player
I have an 80g ipod classic my 4 year son locked it
this is not a problem.
If you cannot remember the passcode, you will need to restore your device using the computer with
which you last synced it. This allows you to reset your passcode and resync the data from the
device (or restore from a backup). If you restore on a different computer that was never synced
with the device, you will be able to unlock the device for use and remove the passcode, but your
data will not be present Follow the steps that i have outlined below. If this does not completely help your situation
please let me know and i will be glad to assist you. According to Apple, if you have forgotten the code, you can unlock the IPod by doing the
following: 1 If you can't unlock IPod using either [the code or connecting it to the computer you use to
manage its songs. . . Plug the iPod USB cable into the bottom of the iPod Nano. 2 Plug the other end of the iPod USB cable into a free USB port on a Mac or PC computer. 3 Open the iTunes application by clicking on the Dock icon on a Mac or using the Start menu on a
PC. 4 Click on the name of your iPod Nano under the "Devices" list in the iTunes window. 5 Click on the "Sync" button to establish a connection between your iPod and the computer. 6 Click on the eject symbol next to your iPod's name after the syncing process has finished. 7 Unplug your iPod Nano. The device will be unlocked and you will be able to access all normal
features again. if that does not work you can restore your iPod to factory settings using iPod Updater. Please
note that this will erase all data on your iPod. Afterwards, you can add your music and data back to your iPod. If you want to change the primary computer that your IPod is associated with, do this: 1. Restore your iPod. WARNING: The restore process cannot be undone. All of your songs and files will be deleted. Always make a backup of your important data. 2. Connect your iPod to the computer that you want to be the primary computer. 3. Open iTunes and synchronize. Apple also notes that company "representatives cannot unlock an iPod if you forget your
combination. If you can't unlock your iPod and you don't have access to the primary computer,
your only option is to restore the IPod, which will erase all music and data." If you need further assistance please feel free to follow up with a comment and i will be here to
assist you. If this assisted you please feel free to rate the comment. thanks and have a great
day.
Jan 20, 2010 | Apple iPod classic MP3 Player
My son has accidently put the screen lock on my daughters ipod nano & she can't remember the 4 digit code. Help!
2. Open iTunes and sync the iPod as normal.
Oct 01, 2009 | Apple iPod nano
Don't know how to reject the ipod nano when charging at computer
  1. Once the iPod is attached to the iPod and USB port in the computer, an icon will appear at the bottom of the computer desktop. The icon is from removing the USB Mass Storage Device
  2. Now, click on the enject icon and it will show which drive the USB cord is attached to. Once the icon is clicked on, the iPod will show an arrow going down and reading "OK to disconnect". Once able to disconnect, the USB cord can be removed from iPod.
  3. Another way to eject the iPod from USB cord is through iTunes. Once anything you want sync'd to your iPod is complete, a message will appear on the iPod reading, "OK to disconnect". Just like it did on the ejecting icon on your desktop.
Sep 24, 2009 | Apple iPod nano
My iPod says that it is 2GB but it only holds 47 songs. Help?
Hi...
Maybe your Ipod have files hidden by viruses, you need to format your Ipod, to format your Ipod, you must plug it to you computer, after your Ipod detected, you need to open my computer, then after that you can see the icon of your Ipon, you just right click and format, chose the quick then ok.
After you've done formatting you can load many sons in your 2gb Ipod.
Good luck !!!
Regards
PCmania
Jul 13, 2009 | Apple iPod nano
Acer aspire desk top t180 has no sound
Sounds like he forgot to plug back in the sound cable when he took his iPod out. Simple fix for this. Pull out the desktop box (computer) and find what should be a green sound cable and plug it into a green port in the back of your computer. If your having trouble as to what it looks like, get your son to identify what he took out of your desktop to listen to his iPod and plug it back in. Also check that your speakers are turned on and are up on the speakers and on your desktop, which you can find in the bottom right hand corner near your desktop clock. The icon looks like a speaker and just click on it once and make sure its up all the way and not muted. Let me know if this works or not
Hope This Helps
Nov 19, 2008 | Acer Aspire™ T180 PC Desktop
USB 2GB Sansa express i pod with micro sd
If you are using an USB extension or an USB external hub, get rid of it.
Try plugging the MP3 to a different USB port.
Try unplugging AC charger, and removing laptop batter for ten minutes, sometimes this can fix problems caused by accumulation of electrostatic charges on USB controller.
If that does not solve the problem, test a different USB device on the same laptop, and test the MP3 on a different computer. Either one may be faulty.
If the problem is the laptop you may fix it by removing and reinstalling USB root hub on hardware devices in Control Panel.
Oct 14, 2008 | SanDisk Sansa MP3 Player
Can't get my iPod to charge or even show up on my computer
Hi there! Often, when an iPod does this it just needs to be 'reset'. To do this, turn on the iPod, and then press and hold the center button and the top ('menu') button just above it. You'll have to hold these two down together for anywhere from 10 to 40 seconds. When you see the screen go dark, you can let go. At that point, you should see the Apple logo appear as the iPod reboots. Take this opportunity to reboot your computer... this might help out as well. When both the computer and iPod have rebooted, go ahead and plug the iPod in and see if you get a response from iTunes. I'm afraid this is not "the" solution, necessarily... there are a number of potential fixes for the issue you're describing, but this is the first thing that I would try. The next thing to try would be to go into your control panel, into the add/remove software program and completely uninstall iTunes. Then reinstall iTunes, reboot the computer, and try again. Best of luck!
Sep 28, 2007 | Apple iPod mini M9160LL/A MP3 Player
Apple iPod nano Logo
27 people viewed this question
Top Apple Audio Players & Recorders Experts
Ekse
Sean Cole
Sean Cole
Jeffrey Groves
Jeffrey Groves
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
