Question about Dishwashers
Dishwasher tub slowly fills with water after after completion
I have a Bosch dishwasher that is eight years old (model SHU9902UC). A few months ago I found clear water in the tub following a wash done the previous evening. I drained the tub by resetting the cycle as instructed in the user manual, but the tub gradually filled up with water again after several hours. This now happens after every few washes. When I turn off power to the dishwasher, the tub still fills with water. There seems to be a slow leak in the water intake valve, but I'm not sure why this happens only intermittently - that is every few washes. Do I need to replace the water valve? If so, what's the difference between the Bosch water inlet system (part No. AP2802392) and water valve assembly (part No. AP3783031)? Which part do I need? Thanks for your help
  • Anonymous Mar 13, 2008
    is this valve open or closed when disconnected mine stays open and tub fills and floods
  • 640 Answers
The internal parts of the valve are sticking open randomley.the diaphram/piston in the valve most likley have lime deposits on it due to poor water quality.you would need the water valve assembly but before you buy this part i would look where the water line goes into the dishwasher and it will lead you to the valve.remove the valve from the unit and disassemble the valve.clean all the internal parts in the valve and reinstall.75% of the time this works ,if not change the valve.
Posted on Jan 24, 2008
Dishwasher slowly fills after cycle
If water slowly fills in the tub when not in use.
a) Most likely your machine inlet water valve not seating properly and closing. Change the machine water valve.
b) May be sink drain water back flowing to the tub. But you have checked that.
So it has to be the machine inlet water valve.
Apr 11, 2015 | Whirlpool Dishwashers
Dishwasher Does not Fill Past First Rinse
There is an anti flood valve on the bottom of the unit. IT could be sticking or have a bad connection. IT should look like a dome shaped housing on the bottom of the tub. If that is not the problem then you are looking at further troubleshooting to see if it is the contoller.
Jan 19, 2014 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
My Bosch dishwasher fills with water but when it comes to the wash cycle it does nothing.
If your dishwasher is brand new, then call Bosch service as they can repair it under warranty.
Feb 26, 2012 | Bosch Dishwashers
My Bosch dishwasher is taking hours (at least 3 - maybe more) to complete a cycle. There is gummy, yucky stuff building up inside - sorta pinkish brownish. Could the water not be hot enough? A couple of...
if your on demand heater is one of the small ones that mounts under the sink, it will not flow enough water to fill your dishwasher. the dishwasher is waiting for the water level to fill before it starts washing. your bosch will heat its own water. hook it up to a cold line ahead of the water heater so that the fill valve is fed with full pressure. the residue sounds like detergent build up. when you get the water issue resolved, run a few cycles with no dishes and no detergent, on the highest temp setting. add a cup or two of white vinegar or dishwasher cleaner ( order online or get from an appliance repair store) through it. Dont forget your dishwasher has a filter in the bottom under the spray arm that needs to be cleaned periodically. if you dont clean it once a month it will get all kinds of nasty stuff built up in there.
Nov 20, 2010 | Bosch SHX46A07UC Built-in Dishwasher
Dishwasher signals "clean" inside five minutes
I would check tosee if your water meaning hot water temp is hook up correctly. i have seen cold water going to machine and causing the machine to do funny things. 1 the unit drains.2. it fills.3.it washes if the water is cold there is your problem .make sure b4 you start machine the water going in is hot. let me know how you made out maybe we can further check. p.s im a old bosch tech:)
Jan 26, 2010 | Bosch SHE4AM16UC 24 in. Built-in...
Bosch SHU 43C06 UC17 dishwasher the dishwasher is just draining with no water in the tub, and is not filling, it does not seem to begoing out of drain mode
water in the bottomof the base remove side panel and dry out the bottom base . the float is up . thats why its in drain mode. bosch old tech speaking.
Oct 10, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch dishwasher fills with water after cycle is completed
Sounds like you need a new water inlet valve. It's not shutting off completely, so water slowly enters the machine even while it isn't running.
Jul 03, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
559 people viewed this question
Top Dishwashers Experts
