Question about Motorola Mobility E815
Water damaged motorola e815
A friend gave it 2 me 2 see if i can fix ut, The dot on the phone is red, but the one on the battery is white. Can it be fixed? How do the cell phone repair shops do it?
  • Anonymous Feb 22, 2008
    I have that same problem, the dot on my phone is red, but on my battery it is white. Can it be fixed? and how?
  • 38 Answers
You could check here for parts like LCD,keypad,mics ETC.
Shop around if too expensive. Link:
Flex LCD and Parts V710-e815
Posted on Jan 24, 2008
    Scholar:
  • 93 Answers
We do it with lots of patience. We clean all the corrosion by emersing the board into alchahol, use a tooth brush to clean the corosion. then heating it up in a special "oven" . Then we replace any parts that are beyond repair, like LCD;s and mic's. check my profile if you need help
White screen
did you drop it in water, ?did you press the screen to hard and cracked the lcd panel? those are the most common reasons, oh, and dropping it, and also dropping it in water. I would suggest going over all those possibilities.. open up the back of your phone and pull out the battery, in all phones now they have a water sensor dot, it remains white always unless the phone was damaged by water, and warranty doesnt cover water damage, look for that little white dot, if its red, that means you gotta get a new phone, and if you try peeling if off theyll know youre covering up water damage, unless you were able to somehow obtain another white color changing dot to put back in your phone now in the exact place it should be, but techs are very good at catching bluffs. but if that white is intact to begin with, your phone should be under warrenty of some sort, and that means they owe you a new one. bottom line. BOOM
Sep 20, 2012 | Motorola Mobility MOTO W755 Cellular Phone
How do i find out if the motorola cliq im going to buy has had water damage?
when you pop the battery off there is a circular dot near the middle near the orange or black rubber thing that helps lock the SIM in and SD card.
The dot is likely either white or red. White should indicate that it is good and red if it had significant moisture/ water contact.
Apr 01, 2010 | Motorola Mobility CLIQ Cell Phone
Motorola razr will show 'emergency only' and cannot make calls
Was the phone dropped? Did it incur any physical abuse? Water damage?  If not, try pulling the battery out of the phone completely.  Look in the battery bay to see if you can find a white or pinkish red sticker dot.  If the dot is white, there is not moisture inside the device.  Call your service provider and you may qualify for a free warranty replacement device.
Also try and letting the device charge overnight. It may be time to replace the battery.
Hope this helps, as you only gave me limited info.
Apr 21, 2009 | Motorola Mobility RAZR V3x Cellular Phone
I spilled sprite on my g1!!
I dropped my motorola sliver in the bathtub full of water and it quit working totally. I called ATT where I got the phone and they told me to look under the battery. I lifted out the battery and they asked me if there was a white dot under it. I told them no but there was a red one. They said "gone". Meaning that the dot was usually white but if it turns red, the circuits are water/liquid damaged and to throw it away and get another phone. Look under your battery.
Apr 17, 2009 | HTC G1 Smartphone
Can I Have my razr repaired
Then you should take the phone to a repair center and have it fix for a fee.
The white dot on the back of the phone is to safeguard the manufacturer from malicious damaged or use by the customer.
So if it is red that means if had to come into contact with liquid , moisture or water at sometime.
Apr 29, 2008 | Motorola Mobility RAZR V3
Phone wont charge
Did you drop your phone in water? or do you live in a humid area?
Your phone was exposed to moisture. That red dot is a moisture sensitive piece of tape that changes colors when it gets wet.
If your phone still works, but the battery won't charge when connected to a home charger, you might try charging it in your car. Its a different type of current and may work with a somewhat damaged battery.
If that fails to fix the problem you may need to get a new battery.
Hope this helps
Jan 15, 2008 | Motorola Mobility RAZR V3
Motorola E815 flashed to Cricket
you need to get that charging port repaired. www.fixphonenow.com can replace the charging port with a new on for $55.
Dec 06, 2007 | Motorola Mobility E815
Wet phone
Unfortunately you phone has water damage, and your warrenty does not cover that. For your information, either behind the battery, or within the casing, there is a white dot, and when the white dot turns red the service provider knows that your phone has been in contact with water. Your two options are to buy a new phone, or to wait it out and hopefully your phone will air dry and everything will work ok.
Sep 01, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
Problem
oooh doesnt sound too good! but my phone got a bit wet and stuffed up quite a bit so last night im my room on the shelf, i took out my sim card, battery, back cover and left it open to get some fresh air. and now it works fine:) goodluck you might want to try that but yours was alot wetter than mine!
Nov 23, 2006 | Motorola Mobility V265
Motorola Mobility E815 Logo
146 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
