Question about E-Machines E17T 17" Flat Panel LCD Monitor
Monitor the monitor has a ripple effect going through it constantly
  • 2 more comments
  • Anonymous Feb 16, 2008
    emachines
    Mine has the same problem as gum1069's. A ghostly rippling effect moving diagonally across the screen. It seems to vary but generally looks like a medium sized herringbone pattern or moire pattern.
    Was an intermittent problem, but now is seen more frequently. Perhaps it is constant and more noticeable on darker screen.
    Checked the connections and made the common lcd monitor adjustments without seeing any change.
  • Anonymous Feb 29, 2008
    I'm having the same, or a similar problem with my emachines E17T4 LCD monitor. A ghostly rippling in the background. This does not effect the actual picture but can be seen through the spaces, so to speak. The effect is much worse on a darker screen. It seemed to come and go. It has become more frequent and noticable. Strangely, it seems to get worse when I'm online. An automatic update installation increases the described effect and it returns to it's usual state afterwards. I emailed the emachines tech support and they suggested that the "picture tube" was probably bad.
    This LCD monitor is two years old and has fewer hours of use than average.
  • Anonymous Dec 06, 2008
    I am having the same problem. I have used the monitor controls but that didn't fix it. Went to e-machines to see if I could reinstall driver but there was no driver offered. The driver used seems to be one that comes with Windows (plug and play). This have been going on for a long time and the monitor is old. It may be time for replacement.
    Problem Solver:
  • 9 Answers
Have You Checked Your Video Drivers?
Or Maybe The Refresh Rate?
You Could Try Emailing The Manufacturer, But If You Already Have Emailed Them Tell Me & I Will Research Some More
Posted on Jan 24, 2008
Dear brother i have problem my lcd tv samsong , a vertical line is comming in right side how it will rectify ? pl suggest . thank jks
If it's a thin vertical or horizontal line which is constantly there in the same place chances are the panel is defective.Normally a panel repairs or replacement is not cost effective and you need to live with this defect or go for new monitor. Sorry !
Samir
Jun 03, 2011 | Samsung SyncMaster 740N 17" LCD Monitor
My monitor keeps blinking constantly
It does the same on another PC?
Look for bad caps as hsown in my pictures here:
http://s807.photobucket.com/albums/yy352/budm/LG%201915S/
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Jan 04, 2011 | LG Flatron L1919S LCD Monitor
How do I eliminate ripple effect on an acer AL1916W monitor
What is your refresh rate set to? At the desktop, with no windows open, right click the mouse and a dialog window will open. Click on properties, then the settings tab at the top, then another window will open. Click on monitor then at the bottom of the new window click on advanced. Check the refresh rate and change it to a lower rate and see what happens. You might even raise it. I hope this helps.
Jul 11, 2010 | Acer AL1916W 19" LCD Monitor
Rippling effect on Relisys T565 monitor when scrolling
You need to install drivers for your graphic card
Nov 28, 2017 | Relisys TL565 15" LCD Monitor
Ripple Effect
Hi josh14
Yep, I have heard about this one. Not yet seen it myself. First thing I need to know is what browser you are using?
Do you get the same problem when you use different browsers?
Does it occur in any other applications?
If you can answer those questions I'm sure some will have the answer for you. I'll check the postings?
Paul
Sep 03, 2008 | Apple MacBook Mac Notebook
Ripples appear in the image when photographing an object with fine plaids or stripes. Why is that?
The following describes the symptoms, cause and prevention of the Moire effect. Symptoms of the Moire effect When you are shooting a subject that has a fine regular pattern such as stripes or plaids, a ripple that does not exist on the subject sometimes appears in the image. This effect is called the Moire effect. Why does the Moire effect occur? Digital cameras and camcorders are equipped with imaging devices such as CCD sensors and CMOS sensors that have pixels that are finely aligned horizontally and vertically that convert light into electronic signals. When the pixels and the pattern on the subject overlap slightly misaligned, an interference pattern occurs and a ripple that does not exist on the actual subject may appear. This is the Moire effect. Preventing the Moire effect You can reduce this effect by changing the distance, zoom setting or the angle of the image. If you are using a camera with manual focusing, the Moire effect can be reduced by simply changing the focus slightly. Reference You may find another Moire effect displayed on the LCD of the camera. As this is caused by the aligned pixels on the LCD, this effect does not necessarily appear in pictures you have taken.
Sep 04, 2005 | Canon Optura 500 Mini DV Digital Camcorder
Ripples appear in the image when photographing an object with fine plaids or stripes. How can I fix that?
When you are shooting a subject that has a fine regular pattern such as stripes or plaids, a ripple that does not exist on the subject sometimes appears in the image. An example of this can be seen in the pictures below. The photo on the left shows the fine plaids pattern on the shirt. The photo on the right is a distance shot of the same shirt. In this photo, you can see a ripple that is not visible in the photo on the left. This effect is called the Moire effect. Why does the Moire effect occur? Digital cameras and camcorders are equipped with imaging devices such as CCD sensors and CMOS sensors that have pixels that are finely aligned horizontally and vertically that convert light into electronic signals. When the pixels and the pattern on the subject overlap slightly misaligned, an interference pattern occurs and a ripple that does not exist on the actual subject may appear. This is the Moire effect. Look at the image above. This image shows red cross-stripes and black cross-stripes overlapped slightly misaligned. When you look at the entire image, you find a ripple that differs from either of the patterns. This is the same principle that causes the Moire effect. Preventing the Moire effect You can reduce this effect by changing the distance, zoom setting or the angle of the image. If you are using a camera with manual focusing, the Moire effect can be reduced by simply changing the focus slightly. Reference You may find another Moire effect displayed on the LCD of the camera. As this is caused by the aligned pixels on the LCD, this effect does not necessarily appear in pictures you have taken.
Sep 04, 2005 | Canon GL2 Mini DV Digital Camcorder
Picture ripples
The following describes the symptoms, cause and prevention of the Moire effect. Symptoms of the Moire effect When you are shooting a subject that has a fine regular pattern such as stripes or plaids, a ripple that does not exist on the subject sometimes appears in the image. An example of this can be seen in the pictures below. The photo on the left shows the fine plaids pattern on the shirt. The photo on the right is a distance shot of the same shirt. In this photo, you can see a ripple that is not visible in the photo on the left. This effect is called the Moire effect. Why does the Moire effect occur? Digital cameras and camcorders are equipped with imaging devices such as CCD sensors and CMOS sensors that have pixels that are finely aligned horizontally and vertically that convert light into electronic signals. When the pixels and the fine pattern on the subject overlap slightly misaligned, an interference pattern occurs and a ripple that does not exist on the actual subject may appear. This is the Moire effect. Look at the image above. This image shows red stripes and black plaids overlapped slightly misaligned. When you look at the entire image, you find a ripple that differs from either of the patterns. This is the same principle that causes the Moire effect. Preventing the Moire effect You can reduce this effect by changing the distance, zoom setting or the angle of the image. If you are using a camera with manual focusing, the Moire effect can be reduced by simply changing the focus slightly.
Aug 31, 2005 | Canon PowerShot Pro1 Digital Camera
Picture ripples
Aug 31, 2005 | Canon PowerShot SD300 / IXUS 40 Digital...
E-Machines E17T 17" Flat Panel LCD Monitor Logo
107 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
