Question about Sharp AL 1631 Copier
AL1631 Striped copies.
I cleaned the transfer charger and still have a stripe down the middle.
  • Dailynap Jan 24, 2008
    Thanks all set!
  • brian c
    brian c May 11, 2010
    Is this happening when copying from the platen glass, or the top feeder?
Top Feeder Only
Posted on Jan 24, 2008
    Genius:
  • 1,003 Answers
Clean the scanner lens UNDER COrNER OF AUTO DOCUMENT FEEDER
  • DENNIS MITCHELL Jan 24, 2008
    clean platen glass IF THAT DOESENT WORK REPLACE DRUM\TONER CART
Hp psc 1210 will print but not copy
Symtom that scan head might be faulty, remove four screws located at corners, take out flat glass unit, remove scan head, check any damages in driving mechanism, clean reading head, fix it back and check.. If no result replace scan head unit..
acsn head snap shot:
Feb 03, 2012 | HP PSC 1210 All-In-One InkJet Printer
When we print it is striped with colors
your printer cartiges are damaged. please chang your printer cartiges.
Jul 30, 2009 | Lexmark C782N Laser Printer
Striped copies. A week or so ago I used the charger cleaner and the problem was fixed. Now the problem has returned and cleaning the charger does not seem to be of any help.
Hello sir; Tell me when the sreak line come out, is using doccument feeder or leave on the glass, if using feeder, just need to clean out the glass( narrow strip) otherwise you have to change drum cleaning blade. p.s. also need to clean white reference on the cover( when you lift up the cover on the lefthand side.)
May 18, 2009 | Sharp AL 1631 Copier
Black stripe and white stripe on copies
Black stripes can be down to dirty optics, unplug the copier and remove the glass, then clean all mirrors and the glass itself. If this does not resolve the problem, it will be the drum cleaning blade that has worn and will nedd replaceing.
Feb 16, 2009 | Sharp AL 1631 Copier
Why does minolta copier print white stripes?
TRY TO CLEAN AND CHECK MAIN CHARGER AND TRANSFER CORONA FOR VOLTAGE LEAKAGE,AND CHECK DEVELOPER GEAR AND DEVELOPER DRIVE GEAR
Dec 03, 2008 | Minolta EP1030/1030F CS/PRO Copier
White stripes on pages copied from ARM 205
If you changed your developer? Or did you change the Toner Cartridge?
White stripe? Check the charge on the drum, it might have a piece of dust on it.
take the charge out, (dont take it apart) hold it up to some light, you might see some dust particles hanging in the grid. If so, rub very lightly with finger, do not use a cloth to clean. Blow it with a can of air.
Clean the transfer charge as well
Usually replace those as it is such a pain to clean on the smaller machines.
if you need any further help let me know
Thanks
Nov 05, 2008 | Sharp AR-M205 Copier
When I fax docs, it is received with stripes and stains
first check the printer by copying something,here u can see the problem that u r telling me,or check it by scanning something in ur computer,if u can see that problem,all u have to do is,open the top glass cover, under the top cover thers a scanning unit(lamp unit),in that scanning unit ther are some mirrors clean that mirrors with cotton bud,clean the top glass,n fix everything again,problem will be solved
thnx N
Jan 29, 2008 | Samsung SCX-4216F All-In-One Laser Printer
Mita dc 1860 copy machine
Check Drum from scratches,check cleaning blade.Also check Heat roller.
Nov 15, 2007 | Office Equipment & Supplies
Sharp AL 1631 Copier Logo
121 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
