Question about Whirlpool ER6AHKXPQ Top Freezer Refrigerator
I have ? for model # ET1MHKXMQ00
I just recently got a used whirlpool top freezer unit and it is not seeming to kick on like it should. Some days it works perfect and other days the fridge is barely cold and freezer has things in is that are beginning to thaw. If you turn the temp knob all the way down then back up it seems to kick it back on then its fine for a while. Today I can not get the fridge to kick on at all. Once turning knob freezer started chilling again but nothing in fridge, Any ideas..this sound like fixable problem??? THANK YOU!!!!
  • 4 more comments
  • tyty51282 Jan 24, 2008
    How do I figure out if thats what it is or not?? THANKS!!!
    ok we will try that when when its warm enough...thanks for your help
    well it was 43deg so I tried it and I took it all the way off wand it clicked and turned on right around the "normal" marking on the control
    when turning it back up towards the "coldest" marking
    Compressor is warm, can touch it but it is pretty warm..so that means its working!?!?! Yes everytime I mess with the knob. I guess then our option right now is to tryto replace tsat? Is that something we can do at home and where do i find how to do it? AGAIN THANK YOU SO MUCH FOR YOUR HELP!!!
    Ok will try the bypassing thing tomorrow and see where that gets us...if not I guess Ill be back for more or something!! Its working for the moment so no lost food yet!!! Thanks again.
  • 447 Answers
Sounds like you need a new thermostat to me. They are kinda expensive, not too hard to replace though.
Posted on Jan 24, 2008
  • 1 more comment
  • joey  shearer
    joey shearer Jan 24, 2008
    Its tricky, the best way is when you have found it in a warm state (warmer than 40degF) set a middle setting slowly turn the contol to warmer and listen for the click. If it gets full cold with no click, start turning it back to off very slowly, and click should happen when it gets very close to off if its warm in the FF. If it goes to off with no click, than Its the thermostat. Go all the way to off. Now back on. Did unit click and come on than??
  • joey  shearer
    Sometimes I find what happens to me that day in the field...there is usually a post or two that sounds like my exact complaint. It does seem like the thermostat is acting somewhat normal if you say it turned off --at almost off --and back on at normal (they have a large cycling window to prevent frequent cycling). I have had 2 very simple (not much to a top freezers wiring) unit similar to yours but frigidaire models do this. I replaced the thermostat in both feeling confident i nailed it. The only other reason for the unit just not coming on would be the defrost timer not advancing proper. But the thing is you have said you have always made it work by fiddling with tsat. That wouldnt have affect on the timer. Also lets start measuring temp by getting glass of water and using meat type thermo that goes to 0 or more. Measuring air temp is innacurate. If every time its warm, its silent ---no freezer fan----no noise and you can fool with tsat and it comes on. Than its a sure thing. Also you can remove cardboard rear panel (dont damage it --its vital for proper air flow) and touch compressor. It should be pretty warm around 100degF. If its cool than you also know it hasnt come on. Also keep in mind here that if there is nothing (no food,drinks,ice) in the refrig it doesnt regulate proper.
  • joey  shearer
    You should feel comp when its warm again inside. If its cool, it hasnt come on in awhile. If its off and you fiddle with tstat and it comes on than you know you have it. You can also bypass the tstat to see if it freezes everything now like it should or if other problems exist. Just axcess by removing all the 1/4" recessed screws holding the console with the tstat to top of FF. the 2 line voltage wires (not the green ground) cant be mixed up. Just put them together somehow without cutting off the terminals.
Freezer won't stay cold
What is the model number of your unit?
Feb 10, 2013 | Gladiator Chillerator Top Freezer...
Whirlpool freezer wvg301 not freezing
I have a whirlpool WVG301 freezer and have just had a similar problem with my freezer not freezing and all my food spoiling. Open the plastic cover at the top front above the door. In side is a timer which controls the automatic defrost mechanism. On top of this timer is an adjuster. This timer seemed to get jammed. Give it a slight turn with a screw driver and your compressor might just kick in and work again like mine did!!! Hope this helps?whirlpool-freezer-wvg301-not-freezing-wkabq5ktcyu2l2r5umicsblr-5-2.jpg
Jan 23, 2013 | Whirlpool Freezers
Whirlpool 20 cu ft upright frostless freezer model EVL201NXRQ. About 2 weeks ago i could hear what is sounded like the fan was making a steady loud running noise. Now the freezer has completely quit. Is...
Difficult call there as whirlpool has a strange manor especially with the larger units. I had a callout on a double door whirlpool unit once and the compressor wouldn't come on but i couldn't find anything wrong. Anyway, i decided to leave the fridge untl the next day giving it a chance to possibly come on. About 5 hours later the customer called and said unit running very well and no more problems. Basically leave on for a few hours and see. If no output then call a tech .The testing procedures need equipment and electrical info..
Feb 18, 2011 | Whirlpool 19.6 cu. ft. Upright Freezer...
This is our second whirlpool gold top freezer unit!
This may not be the problem now but by the sound of the malfunctioning unit, it could be in the future. The start device on some models of refridgerator for maytag and whirlpool have been recalled. If your appliance was manufactured in the last 5-10 years you may be having an issue with this component. Mine recently caught on fire at this device that is located near the compressor. If you would like to be a part of the petition for a recall on this appliance contact me at jboooor@hotmail.com
Jun 06, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Electronics stuck. Unplugged and it seems to have
It will only work for a few more months. You'll have to reset it a few more times. Eventually, even keeping it unplugged for a couple of days won't work. Have had ours 7 years -- and have had more than a dozen service calls on it. In the beginning, all was covered. No longer. Piece of **** is going out to the sidewalk on junk day. Will never buy another whirlpool or maytag product again.
Our crappy whirlpool fridge freezes stuff in the back of the refrigerator, while stuff comes out of the freezer a bit soft.
Awful products. Even worse customer service.
Oct 26, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Beverage-Air KF48-1AS not coooling, fans not running
some thing wrong with the evaporator fan motor. make sure the motor turns freely. your going to need service .
Jun 19, 2009 | Carrier 44.9 cu. ft. Upright Freezer...
Temperature is not cold enough?
Model #106.8678213, The complaint was the refrigerator section was getting warm while the freezer seemed OK. The unit had been unplugged for a couple days and when I turned the unit back on, the cooling system worked fine, but I did notice a lot of water in the condensate tray which lead me to a possible defrost problem. Removed the access panel to the defrost timer and found the timer motor was not running. So basically what happened was the unit stopped defrosting and eventually built up enough frost and ice on the evaporator to block the airflow to the refrigerator section. Once the power was removed, the unit defrosted by itself and left the water in the tray. I replaced the defrost timer so now it will defrost every 8 hours like it was designed to. Now get back with me and see if the model number located on bottom kick plate it should be a number that Sears only uses. They use model numbers like this on everything and every brand. looks again like this sample ( 106.8678213 ) hope this helps, Sea Breeze
Apr 12, 2009 | Kenmore 64802 Top Freezer Refrigerator
Try to find out if this unit needs a filter for the icemaker
Your refrigerator will not accept nor was designed to use a whirlpool water filter. No a filter is not required. Yes an in line filter can be installed prior to the connection at the inlet valve if you desire.
Apr 02, 2009 | Whirlpool ER6AHKXPQ Top Freezer...
Whirlpool Fridge Freezer not working fridge is
ID THERE FROST BUILDING UP IN THE FREEZER?IKE
Mar 14, 2009 | Whirlpool ET4WSKXS Top Freezer...
Whirlpool side-by-side fridge/freezer continuous operation
have you cleaned the coils under the unit remove the toe kick in front and use a shop vac
Mar 04, 2008 | Refrigerators
Whirlpool ER6AHKXPQ Top Freezer Refrigerator Logo
382 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
