Thermador doesn't make one, but we found the GE JEB1860SM1SS from Home Depot fit perfectly. For only $259. The repair to fix our Thermador was $618. It was only 5 years old. I couldn't believe it already went out. I won't be buying anymore Thermador appliances.
thank you, this was our problem and a great solution. Thermador was very unhelful and I won't use them again. Had problems with our $5000 Thermador oven at 6 yrs. too and they were not helpful there either, basically if you buy anything Thermador you'll have to replace it after 6 years.
I aslo have the (now discontinued) Thermador built- in microwave model number MBBS/01 as well with the original coordinating 27 inch trim kit. Because Thermador does not make a compatilble replacement, Thermador customer service is telling me I need to replace the discontinued microwave and trim kit, along with my cabinetry which sounds crazy.
Is the GE JEB1860SMSS microwave compatible with the 27 inch trim kit for the discontinued Thermador MBBS/01? If so, that would be fantastic.
I had the same problem, unbeliavable,they do not make them anymore and the new models do not have the same size ...what a rip off
Hello! Did you ever get an answer to this? I have the same problem and I want to order the GE but I don't think the trim kit will fit it. Any suggestions?
I replaced my short-life Thermador MBBS with a GE JEB1860SMSS. Perfect fit, nothing to change. Trim fits without any modification. Looks like it was built to fit right above the Thermador warming draw and the oven below the drawer.
I thank whomever on FixYa made the entry that vectored me to the GE JEB1860SMSS. I worried about slight differences in the width measurement, but found it fit perfectly into the vacated space. Saved a lot of money. What a relief!
I have repaired my Thermador microwave MBBS twice now both times repairing the plate inside of the mmicrowave where it has popped and sparked. Last week it popped and sparked so much that it is now burnt out. Instead of repairing, i want to replace with the GE module recommended. When i look it up, it says it is a "Kit" That is the full microwave, correct?
