Question about Whirlpool RF364 Electric Kitchen Range
Baking element not working
I replaced the baking element on my Whirlpool Model RF364PXM oven, but it still does not heat up. The broiler works, but obviously not getting power to the baking element. Any ideas??
  • jjcopen Jan 25, 2008
    Thanks for the response. I did, in fact, find that the problem was with the main control/timer circuit. The baking relay that is in the unit was not sending power to the element. What stinks is you have to purchase the entire main control, as you cannot just replace the relay. I did manage to get Whirlpool to send me the part for half price, since the oven is only 3 years old.
    Thanks
  • Anonymous Mar 17, 2014
    My whirlpool knob for baking and broiler broke i don't know if its baking
  • 5,911 Answers
If you have already replaced the bake element (which would have been MY first logical choice) and it still does not work, the problem is more likely with the Electronic Clock Control. The control has two separate circuits that will select and turn on either the bake of the broil elements. It is usually a defective relay that causes the particular mode of choice to stop working. The part number for the ECC is 1166040 and costs about $128. It's not a cheap fix, but it would cost you much more if you had a service man fix it for you. Unless...of course, you still have a warranty. Most manufacturers cover all parts from defects for the 1st year. Some parts are covered longer than the initial warranty, however. It may be worth you while to double check your purchase date and appliance paperwork. This repair is not difficult and can be accomplished by the average do-it-yourselfer. If you decide you want to repair the appliance on your own, let me know and I can give you step-by-step instructions on how to do it.
PS Double check the wiring from the ECC to the bake element as well. You could have a broken wire causing the same symptoms too. Also, don't be alarmed by the failure of the ECC. Although they are generally reliable for quite a number of years, they have been known to fail during electrical storms and/or power surges. Something else you may consider: check your home owner's insurance policy to see if it covers the loss of appliances in the event of such incidents. I hope you find this information helpful.
Posted on Jan 24, 2008
  • Jeff Rockwell
    Jeff Rockwell Jan 25, 2008
    Fantastic! You sound like someone that has done their homework. I have often wondered why you couldn't find components for those control boards as well. Since they are considered "non-serviceable", the consumer is forced to replace the entire card...or do without an oven. Pretty crappy design if you ask me. You're lucky Whirlpool gave you such a deal. Some companies would not have gone that far to try to keep a customer (something you may remember in future purchases). On some brands, that same control board can run as high as $300! That doesn't include the labor to install it, either. Keep your warranty information handy and your manufacturer's phone number handy. I hope this doesn't happen to you again. Good luck to you.
Kenmore electric range model 911.95875790, no heat to either baking and broiler elements.
Hello. I looked carefully at the service manual for your unit--surprisingly, there is no thermal switch inline with the bake/broil elements. Usually, if the bake or broil elements pop, this blows out the thermal switch, killing power to the elements for safety. The main control board can get damaged due to the high current draw during a short-circuit. The part number for the main board is WB27T10008. The overlay(the decorative sticker with the button/names on it) numbers are as follows: almond WB27T10022, black WB27T10023, and white WB27T10021. I hope this helps you!
Sep 18, 2015 | Kenmore Ovens
Broiler will not work on a whirlpool range rf367lxsyo
the broil element
is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage.
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control.
Apr 17, 2015 | Whirlpool 30" Self-Cleaning Freestanding...
All the lights and buttons work/sound on control panel. Broiler oven works but baking element not working. Replaced baking element with new, but still doesn't work. Convection fan works, light works,...
Manufacture and model would be nice ohm out the bake element might be open some are in the oven cavity others are hidden below the lower oven plate and have to check from the rear by removing back cover in the bake mode the broil element element cycles on/off thats why you have some heat.
Feb 10, 2014 | Ovens
The broiler works but the oven won't bake. i think the bottom heating element needs to be replaced
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Feb 02, 2011 | Whirlpool Ovens
Whirlpool range oven will not start to heat on bake but, the glow plug is working. the broiler does work.
sounds like you need a new bake element or could be a burnnt wire at the element look at the element is it broken ?
Aug 20, 2010 | Kitchen Ranges
My broiler and range work but my "bake" option will not produce any heat??? Please help!!!
If this is an electric range, it sounds like you have a bad bake element in the oven. The broiler and bake features each have their own heating element. Thats why the broiler still works. The following link explains how to replace a heating element in an electric range:
http://www.fixya.com/support/r469407-replacing_bake_or_broil_element_in
If the model range you have this question listed under is correct, the part number for a replacement element is WB44K5012. It lists for about $25 at pcappliancerepair.com.
If you have questions, or if the model number is not correct, please post back with your information so that I may be able to provide you with better assistance.. I hope you find this information helpful.
Oct 15, 2009 | Hotpoint RB757 Electric Kitchen Range
I have Whirlpool oven Model # RB220PXK (almost 30 years old) and the lower element sparked and stopped working. I measured the resistance of the element and it showed 1.6M ohms. Is my element bad or is...
HI. You can Expect resistance in the range of 20 to 40 ohms. Infinite or kilo-ohm resistance usually indicates a bad element and it should be replaced.
This easiest test you can do is to turn on the oven and observe the heating element. If it glows red, the element is working. When baking, the broiling element may come on to assist with preheating or to maintain the oven temperature. When set to bake, if the broiler comes on, but the baking element does not, the likely cause is a burned out baking element.
NOTE- The element may have small holes and bubbles on the coils as well. This is a sign of a burned out element. Test the element connectors as well.
Oct 12, 2009 | Ovens
Kenmore electrical oven
Trying to better define the problem....
Do you have any cuts, holes or "shorting" or tin-foil/aluminum around your bottom bake heat-element? If so, you may need to replace the baking Heat Element. (Ensure you do not use aluminum foil around your heat element to prevent your oven from getting dirty)
To replace your baking heat element, with power off; remove 2 screws securing the bake element. Slightly tug and pull towards you for about 3 inches or so and disconnect the connecting wires at each end. Then completely remove the heat element and install new in reverse manner. Whats' you're model number?
Jan 26, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Whirlpool RF364 Electric Kitchen Range Logo
571 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
