Question about Standard (CRT) Televisions
Can't get Television out of lock, or sleep mode, or ???
We have a TV that has no remote, or papers, or manul, and it is on lock or something. We bought a universal remote and it does nothing to get tv out of whatever mode it is stuck in. internet says Philipps is its original brandname??? It is a tall floor model.We don't know how old the tv is either.
What we do to get in unlock to work; we have tried unplugging for awhile then trying again but nothing weems to work. Thank You
SOURCE: dwt 1905 tv stuck in game mode
I have a "One for All" brand universal remote, and it has a "TV/VID" button near the left bottom corner that controls the game mode. Had the same problem, and just figured that out.
Posted on Feb 04, 2008
  • 7 Answers
SOURCE: JVC tv "stuck" on sleep timer
I think you would have to turn off the sleep timer mode completely or increase its ON time span, say to 4 hours or so
or the lenth of time you have the TV on for. If that does not fix it then it sounds like a STANDBY MODE fault problem.
Hope this helps.
Posted on Feb 06, 2008
SOURCE: sanyo stuck on video mode
Yippie, I figured out a solution that worked!!! I have a univeral remote from comcast, on that remote near the bottom left is a small button that says (input) tv/vcr, press that one time and whala!! the tv video screen was gone, I had to manually change the channel from the tv channel button on the unit. once I changed the channel to 3, my universal remote worked... the button is the second one from the bottom left... I was on hold with sanyo for a long time and just kept trying on my own, so good luck!!!!
Posted on Mar 01, 2008
SOURCE: Durabrand TV stuck on AUX mode
You can program a Comcast remote to work with the TV. Press the "TV" button on the Comcast remote. Then, hold down the "Setup" button until the red light blinks 3 times. Enter a 5 digit code:
These are the Durabrand codes: 10171 10463 10180 10178 11034
The 10171 code worked for my Durabrand DWT1905. Then use the TV/VCR button located beneath the "7" to switch inputs.
Posted on Aug 17, 2009
  • 476 Answers
SOURCE: TV is 1995 Model 25TRC1-0101 Magnavox. Seems to
The tv has been accidentally set for "demo mode". Press the volume up and volume down buttons in front of the TV at the same time for about 5 to 10 seconds untill the demo disappears or sometimes the TV will turn off. You should regain control of the TV after this.
Posted on Jul 20, 2010
Testimonial: "Thanks so Much! Worked like a charm. Would never have figured this one out. Appreciate You."
  • 3018 Answers
SOURCE: I have a TruFlat RCA
Try this -
  1. Press menu for main menu.
  2. Press CH + or CH - to highlight preferences.
  3. Press "OK" to enter preferences submenu.
  4. Press CH + or CH - to high light "FPA"
  5. Press VOL + or VOL - to turn the FPA on or off.
  6. Press MENU repeatedly to exit.
  7. Back to normal
  • FPA stands for Front Panel Lock. It makes it so kids don't push all the buttons on the front of your TV. The power button on the TV will still work and the remote will still function as normal.
Regards, Tony
Posted on Apr 30, 2011
0 characters
1 Points
Sony tv model kvf25mn2d locked on sleep mode,without a remote how do i reset the tv from sleep mode?
Without a remote control; you can't. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability. Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the sites.
Universal remote controls are available at most of the electronic spare part selling shops. Visit some on-line sites too, which deals with electronic spare parts.
Aug 15, 2016 | Sony Standard (CRT) Televisions
My RCA Truflat T.V won't turn on and the FPA lock is turned on, I have the original remote. what should i do?
TV won't turn on • Press the TV button. Make sure the TV is plugged in.• Check the wall receptacle (or extension cord) to make sure it is "live" by plugging in something else.• Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the remote control solutions on page 26.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).Buttons don't work
• If you're using the remote control, press the TV button first to make sure the remote is in TV mode.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).• Unplug the TV for two minutes and then plug it back in. Turn the TV on and try again.TV turns off unexpectedly • Sleep timer might have been activated. Go to page 24 for instructions.• KidPass might have been activated. Go to page 21 for instructions.• Wake-Up timer turned on the TV and no remote or front panel buttons were pressed for two hours.• Electronic protection circuit may have been activated because of a power surge. Wait 30 seconds and then
turn on again. If this happens frequently, the voltage in your house may be abnormally high or low.
• Unplug TV. Wait five minutes. Plug it in again.
Sep 16, 2011 | RCA 20F420T 20" TV
I have a magnavox 27MS343S and it is child locked, tv is off and do not have the original remote! What can be done?
I have a magnavox 27MS343S and it is child locked, tv is off and do not have the original remote and it wont turn on although the powered up red lighht is on. Tv has been reset to sleep mode by universal remote. What can be done?
Feb 01, 2011 | Philips Magnavox 27MS343S 27" TV
Tv shuts itself off randomly (sleep mode problem)
This is wierd the kids played with your remote and you cannot get it out of sleep mode. Well here is somthing to try. You would take back cover off but here is the disclaimer (HIGH VOLTAGE INSIDE CAN CAUSE INJURY INCLUDEING DEATH) iF YOU NOT QUALIFIED OTAKE IT TO A TECH IF ITS SOMETHING MNOR IT WILL BE DONE WHILE YOU WAIT AND WILL NOT CHARGE YOU OUT THE YANG FOR A FEE. But if you inclined chekc the power supply unit and see if it is giving the correct current to the TV if not replace it.
May 22, 2009 | JVC AV-20220 TV
TV will not come on with remote or power button
The following instructions are for the Emerson EWC1303/1903 tv/vcr. That's the closest match I could find to the Spongebob Squarepants 13' TV
If it's actually in Sleep mode, do the following:
Press the WAKE UP/SLEEP button on the remote
control until “SLEEP TIMER” appears.
To view the time left for sleep timer press the WAKE
UP/SLEEP button twice, then press the MENU button
on the remote control to exit the sleep timer setting
If unsuccessful, try unplugging the TV for 1/2 hour, then plug it in and try turning it back on either manually or with the remote. Either of these should solve your problem. Best of luck to you!
May 08, 2009 | Emerson SpongeBob SquarePants TV
Sansui TVS2746
You can download the manual explaining how to program the timer from Orion who makes this TV,
If you need a new remote you can get one from Orion or search on Ebay.
Dec 01, 2008 | Sansui 27" TV
Zenith B27A11Z remote stop working
remove the batteries from remote ,then put im back and then try again
Jan 01, 2008 | Zenith B27A11Z 27" TV
Panasonic CT - 27G13 - Menu is on Demonstration Mode
Is it a factory remote or a universal? Chances are that only the factory remote will send the special code when both buttons are pressed.
Did you try pressing the up-arrow + Exit on the front of the TV instead of the remote?
Sep 20, 2007 | Panasonic CT-27G13 TV
Black bars on top and bottom of screen
It sounds as if you have accidentally entered widescreen mode. Explore the on screen menu to find the widescreen option & switch it back.
Jul 15, 2007 | Mitsubishi CS-35405 TV
Standard (CRT) Televisions Logo
Top Standard (CRT) Televisions Experts
matt martin
matt martin
Are you a Standard (CRT) Television Expert? Answer questions, earn points and help others
