Question about Maytag 24 in. MDB5600A Jetclean II Built-in Dishwasher
Dishes not getting clean
How do I remove the spin arm on the bottom to clean the filter?
  • Anonymous Feb 13, 2008
    filter on jetclean 11dishwasher
  • Anonymous Oct 23, 2008
    I have cleaned all the gunk from the spin arms but cannot figure out how to get the bottom filter out to clean it.
See this diagram...
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=45319
Posted on Jan 29, 2008
In the center of the arm is a screw on cap. It looks like it's part of the arm, but the round center screws off.
6ya staff
SOURCE:
The lower spray arm on my ASKO 1805 dishwasher has stopped turning, the dishes are still getting washed, so fluid still goes through the sytem, and drains at the end, the heater works. When turning, t
If the arm spins easily by hand, but won't spin when operating, that points to poor water delivery...
1) check the strainer. Not just the holey one you can see, but there might well be a very fine mesh filter under it ~ if so, remove it to clean it (it can appear clean, but still be clogged with transparent cellulose fibres). Try running the machine empty without the strainer/filter fitted. You should hear a difference if the filter was causing the problem.
2) you might have a weak impeller. After a while the plastic impeller on some machines just wears away, leaving insufficient fins to move the water, this can be accelerated by e.g. broken glass stuck in the pump. Impellers can also slip on the motor shaft; the motor's spinning but the impeller doesn't. This means removing the machine, turning it over and removing the pump for inspection...
Feb 13, 2015 | Asko 24 in. 1805 Built-in Dishwasher
Dishwasher spray arms don't spin & spray water
Check that the water pumped on arms has enough pressure.
Aug 15, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
There are no error codes showing, water is definately getting hot but dishes on bottom tray not cleaning, i have used few products specially designed to clean the dishwasher itself without any dishes in,...
Check that the arms spin freely when spun by hand, then check the outlet jets at the trailing end of the arms are not blocked with food particles and other solid matter. This often happens and the arm is unable to turn because the water jet that is supposed to drive the arm does not have the force to rotate it with the result is that the upper dishes do not get enough water and chemicals. .
Jun 18, 2011 | Baumatic 23 in. BDW13 Built-in Dishwasher
TOP RACK NOT CLEANING DISHES
Possible that the motor impeller has good particles in it, causing poor water pressure, which would be most evident on the top rack. You would have to remove the spray arm, then the filter, then the torx screws to get at impeller....unfortunately, that model of dishwasher isn't the greatest in the first place for washing, since it only has the one spray arm.
Apr 04, 2010 | Frigidaire 24 in. FDB126RB Built-in...
Arms don't seem to be spinning
chances are there are either dishes that are too high or utensils dropping down in the way. Adjust the height of the racks to accommodate your large dinner plates.. also spin them by hand and see if the spin easily.. if not could be several problems.. also clean the filters in the bottom of the dishwasher. Remove the arms and check for blocked jets.. I found rice in my jets. Rice should be rinsed off the plates first... many people have rice issues.
Dec 13, 2009 | Maytag Dishwashers
Clean on bottom rack but dirty on top
Clean the filter at the bottom of the tub. If it is dirty or clogged the water pressure may not be strong enough to spin the top arm. Make sure also the there is nothing blocking the holes of the spinner arm. If the filter and arm are clear then the pump may be failing.
Aug 13, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
Dishes are`t clean ,arms dont spin during wash cycle
what is the model # how mutch water is in the basin?
Jun 28, 2009 | Dishwashers
The arms do not spin and no water is going through them
Switch to a brand name powder detergent like Electrosol or Cascade. Never use ultracheap, generic DW detergent powder in any dishwasher. Run a load with dirty dishes and see the results are.
If cleaning results remain poor open the sump area by removing the lower spray arm and the filter assembly. Remove all debris in and around the sump area. Inspect the impeller down there to make sure it is not broken and that it spins freely. Clean the filter well in the sink. Reassemble. Also, check all spray arm holes for blockage.
Run a load of dishes and check cleaning results. If problems continue, you almost certainly have a failing wash motor and replacement is your next step.
Post here is you would like more assistance. Good Luck!
Apr 11, 2009 | Dishwashers
Not enough water pressure to move upper arms or clean dishes
Recommend you pull the bottom spray arm straight up, then out of the DW.
Remove 9 phillips screws that hold the filter shroud down. Remove the filter and clean/rinse it out.
While the filter it out, grab a flashlight and inspect all over the sump area. Especilly in the area the has the check valve that rotates (Vario motor-driven) to feed the water pressure either to the lower and then the upper arms. Watch out for broken glass! Also, inspect the impeller to see if it is undamaged and spins easily.
Reassemble, then test out.
If problems remain, the the wash pump motor is probably the culprit. Do you get any error messages on the time display?
Good Luck!
Apr 05, 2009 | LG LDF6810ST Stainless Steel Built-in...
Dirt left on dishes on top tray; bottom tray washes fine
The broken bottom arm is probably preventing any water / water under pressure to get to the upper arm.
After you replace the lower arm, you should have much better cleaning in the top shelf.
While you are in there replacing the lower arm, recommend you remove the filter under it and clean the filter and any debris you find. Be careful of broken glass!
Good Luck!
Apr 03, 2009 | Dishwashers
Maytag 24 in. MDB5600A Jetclean II Built-in Dishwasher Logo
242 people viewed this question
Top Maytag Dishwashers Experts
Mike
Marvin
Marvin
Vitally Alcher
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
