Question about Philips Magnavox 27MS343S 27" TV
Magnavox tv how do I change the SAP setting
    Genius:
  • 1,694 Answers
In menu page Audio>Stereo>Mono>SAP.......Audio is sometimes called MTS........................T.
Posted on Feb 06, 2008
Picture but no sound magnavox HD tv
check to see in audio menu for set and sat or cable box if SAP is engaged as this will (Spanish) cause no sound on certain channels.
The problem or setting exists in the set and most boxes providing signal to the set.
Mar 12, 2012 | Magnavox Televison & Video
We bought a universal remote to increase our access to cable channels. Some of the channels display the symbols S.A.P. and have no volume. How do we disable the S.A.P so we can hear the volume.?
S.A.P. Means Secondary Audio Program.
SAP, Mono, Stereo, Etc. You should be able to switch this from your remote. Even universal remotes should have this button to adjust sounds. Otherwise you need to go into the TV menu (not the remote) and change it from there. The only way you can change it on those channels is to switch manually. Happens a lot on these older TVs. No worries. Very common.
On many sets, the audio channel can be switched by remote control or through a SAP switch located around the tuning panel or "on screen programming." Usually, there is a setting labeled SAP, AUDIO SELECT, B-AUDIO, MTS, or MENU. By changing the setting, you should be able to select SAP. Not all TV sets are alike, so you might want to check your instruction manual for all the details.
Mar 10, 2011 | Sylvania 6719DC 19 in. TV/VCR/DVD Combo
Magnavox 32MF321D no audio
Hi my name is Roety,
I can help you with your issue ,
You can check the setting for stereo/sap must be set to stereo
If all connections are good and the problem is inside the Tv you will need a new mainboard (or SSB, scaler), ck encompassparts.com
If I have helped you with your issue
If you have more questions you can still respond
I will reply asap
Thanks
Jan 29, 2010 | Toymax Magnavox 37MF231D 37 in. LCD TV
Mts/sap how do i set tv to antana mode?
Hi
please go to menu then click the system settings then click the Air mode, they have two mode the cable mode and the air mode hit the air mode
Thanks!
Jul 08, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
It is most likely the SAP setting is in place. This will kill the sound
To reset the audio, go to the on-screen menu and select the setting for audio and make sure it is on stereo rather than SAP (second audio channel).
toggle the two and see which is compatible to ur Dvd player
thank you
Apr 07, 2009 | Philips Magnavox 51MP392H Rear Projection...
SAP
Hi Suezie,
The problem is most likely your SAP being turned On.
SAP was created for audio programing including translations into a 2nd language. On nearly all sets, the SAP being ON will essentially select an alternate audio stream and will de-select or mute the main audio from the channel your are viewing. However not all TV stations have SAP enabled.
I am the Chief Engineer of a TV station in Denver, CO. We are not using SAP so if you selected SAP while watching my station you would get noise or static. There would not be any audio there.
Go to the front panel of your TV and select the "MENU" function. Step through the menus to Audio features and De-select SAP or Enable your main audio and this should take care of the problem. Alternatively you might be able to unplug your set for a period of time and it would reset itself. I used to get calls from elderly viewers when the set wouldn't pick up the UHF TV stations anymore. These were always after a power failure and the set had defualted to factory settings,
Different set manufacturers use different menu schemes and withou a password feature, these menus are so simple a small child playing with those fascinating buttons can change them for you to something you really don't want.
Good luck and write back if you can't find it. The set manufacturer and model number would help me look up a menu tree for your TV set.
Thak you,
Bernarr Howell
Feb 03, 2008 | Televison & Video
Turning the sap off using my universal remote
If there are any menu setting buttons on the t.v. itself then I would try using them to find the sap setting.
Jan 29, 2008 | Philips Magnavox 27MS343S 27" TV
Philips magnavox model# 9p5040c102
Goto www.TvRepairKits.com and get their shrinking/expanding video repair kit. It works on the Philips sets.
Nov 12, 2007 | Philips Magnavox 51MP392H Rear Projection...
No Sound on TV
I did not answer the original question you posed but the SAP is the acronym for Separate Audio Program and is used to provide spanish for instance on a show which is broadcast in both english and spanish. The problem is not all stations have audio on the SAP. If your audio processor is set to SAP and you switch to a channel which has nothing on SAP you loose audio. I'm guessing someone suggested this prior to this post. If you checked your TV and it is not on SAP that eliminates that. I would look at the audio circuit for problems. Either no power to the audion circuit, bad solder joints, blown output IC or possibly a blown speaker. I know the last one is remote but it does happen and it never hurts to check the simple problems first. Besides you aren't embarrassed later when you find out it was something simple. If you are going to check these issues out remember safety. Good luck.
Jun 08, 2006 | Philips TS2746C TV
Philips Magnavox 27MS343S 27" TV Logo
404 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
