Question about Canon LaserClass 2060P Plain Paper Fax
Hey I need your help. In the problem is with the Canon laser class multifunction 2006. I received "output tray is full".. And I do not know how to print from memory. I am without a instruction manual. I searched all over the Internet for the instruction manual too. Thank you Roger
  • rniles Jan 24, 2008
    YOU SOLVED MY PROBLEM, UNWITTINGLY.
    TY
    YES IT WAS CONNECTED, ITS DUE TO JAM..AND I DIDNT PUT THE PARTS BACK IN PROPERLY
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 1,362 Answers
Check where the paper comes out after a copy or fax, there is a lever ( sensor ) there, it is most likely stuck in the up position, it should be able to go down after each print. "output tray full means there is too much paper in the output bin you need to remove it before continuing to print.
Posted on Jan 24, 2008
Paper tray in my image class MF8350 won't close
There's probably a piece of paper wadded up in the feed mechanism. Carefully remove the paper tray and look in the feed rollers. Also be sure all the "guides" are in their proper orientation.
May 19, 2014 | Canon Imageclass Mf-8350cdn Color Laser...
Output bin full remove paper
open the tray where paper come out all the way and there is a switch on right hand needs to be reset
May 04, 2013 | Samsung CLX-3300 Multifunctional Laser...
How do you set the toner cartridge on a Canon Image class D1150
Try printing a test page first. 2) Shut down printer then re-start. 3) Printer on, re boot the PC. If nothing works, take cartridge out and start over when the printer is off. No help! Then you need real help because your memory is not working properly or an electrical glitch in the mother board or cord.
Aug 09, 2012 | Canon Image Class D1170 Laser...
I have a Laser Class 710 and the error light keeps blinking. There is a message that says "incorrect paper size received in memory". How do I get rid of this?
Someone has probably sent you a fax on 8 1/2 x 14 inch (legal size) paper. Pull down the manual hand feed tray which is located above the regular paper cassettes and place some legal size paper in it. Hopefully the fax will be outputted and the message will go away. Good luck.
Jul 15, 2011 | Canon LaserCLASS Fax 710 Printer
When recieving faxes on our canon laser class 2050p, the machine has a loud squeak
Your rollers will need to be replaces. Rollers feed the paper through the tray. You can find paper feed rollers for your device here:
http://www.precisionroller.com/paper-feed-components-for-canon-laser-class-2050p/products.html
They are very straight forward to install and instructions should be in your manual.
Mar 07, 2011 | Canon LASER CLASS 2050P
Prints 2 pages and says to load paper
Somehow after adding paper you changed the paper size to B5. Change it back to Letter and it should resolve your problems
Apr 11, 2010 | Dell 2135cn All-In-One Laser Printer
Paper Size
double check the menu section is it set for Letter?
check the tray do you have Letter paper in it, are the guides set correctly?
Aug 19, 2008 | Canon LaserClass 2060 Fax
Canon laser class 2050p
could you give better model number? is this a imageclass?
Jan 09, 2008 | Canon Laser Class 8500 Printer
Canon LaserClass 2060P Plain Paper Fax Logo
603 people viewed this question
old marine
old marine
