Question about Panasonic AG-455 Camcorder
Crossed polarity to Panasonic AG-455
Is there a fuse that I can access when polarity is crossed? When I plug in AC adapter there is nothing.Thanks, Nick nickbub@hotmail.com
  • Nicholas Vincent
    Nicholas Vincent Jan 24, 2008
    Thanks, but why didn't I blow the fuse in the cig lighter adapter cord that plugs into battery holder? Maybe wrong fuse, but I doubt it.
    nick
  • lesswords Feb 08, 2008
    I have a Panasonic VDR-D105 Camcorder and it does nothing with a fully charged batter and even on the ac adapter
    Sniper:
  • 80 Answers
Nick,
If you did not damage the dc converter in the camera, you can check several micro fuses located on the regulator board. There are several diodes that assist in blocking reverse polarity applied to the camera. These diodes intentionally open these fuseable devices to protect the power supply and camera.
Hope this helps you,
Joe Weibel
CustomElectronics.Org
Posted on Jan 24, 2008
Where can I buy the battery pack connector charging cable
try a teck shop like jaycar-tandy- radio shack or any shop that sells the bits and pieces used in the radio assembly hobby.
Sep 14, 2013 | Panasonic AG-196 Camcorder
The power on my banshee is coming on?
Check the polarity of the adapter, if it isn't the original one. Even if you have the right voltage, it still has to have the mA or higher but, most important is the polarity. Most guitar pedals are wired backward on the plug. The positive is on the outside ring of the plug and negative is in the middle. There should be a picture or diagram somewhere on the unit close to the plug to find out. If it is backwards, it could have damaged it, maybe not though. If it is ok, cut the plug off and switch the wires and check it. After all, it's not working now, it couldn't hurt.
Mar 15, 2013 | Rocktron Banshee Guitar Talk Box Talkbox...
I m have a laptop without the ac adapter and its an older modle serial no. is 82143976p and i want to know is which one to get for it.
Your quickest & easiest option is to take your laptop with you to an electronics store like Radio Shack to find an adapter with the correct size plug, polarity, and voltage by looking & comparing your options directly from the info on the chassis. Radio Shack would be my first stop since I know they have a good system for cross referencing the various ac/dc plugs & adapters, and if you need assistance later on, they are easy to find.
Oct 07, 2009 | Toshiba Computers & Internet
When I plug the radar in the green dot turns on for a second then turns off, nothings on afterwards... I used a new wire and fuse and nothing....what could be wrong?
Does the unit work in another vehicle? If not, first thing to check is the fuse in the power cord. The adapter (part that plugs into the lighter socket) has a replaceable 2 amp 3 AG fuse inside it. The end of the adapter, which has the silver tip, unscrews to gain access to the fuse. CAREFUL: Unscrew slowly! The tip contains a spring which may fly out when disassembling. With use, screw cap on plug may loosen. Retighten occasionally.
Jun 23, 2009 | Car Audio & Video
Panasonic SDR-H18 connected wrong AC adapter
I accidentally connected wrong ac adapter and to Panasonic dvd camcorder and it will not turn on.....Hopefully this can be corrected??
Nov 25, 2008 | Video Cameras
What type of ac adapter do I need for the av700
I would suggest to check the plug on the av700 and see the polarity, it might be indicated there.
In regards to using any adapter, you could as long is the same polarity. The original adapter is 6 Volts and 2 Amperes.
May 21, 2008 | Archos Televison & Video
Lost ac adapter
If you are trying to guess at an adapter, and plugging them in to see if they work, you run the risk of ruining your machine. With the blinking lights its not booting correctly, so I hope your not smelling smoke too. Nevertheless, you need a 9-12 dc output adapter (with I believe the negative on the inside). Your describing the input of 120V 60HZ, all of them say this since that is the power that is coming out of your wall socket. Look on the back of your machine at the connection and it will show you the polarity via a little diagram imprinted in the plastic(if the negative goes in the center or outside of the plug) This is the most important part, if it is backwards you will fry your machine, if you have not already.
Jan 10, 2008 | Panasonic KX-TG5632 Phone
Panasonic AG-455 Problem
The noise is most likely bad bearings in the video head assembly. No longer available from Panasonic. The b/w recording problem is most likely caused by a bad video board inside the camera. Unfortunately, the video board is also no longer available.
Oct 27, 2007 | Panasonic AG-455 Camcorder
AG 460 panasonic camcorder" FUSE LOCATION"
just follow the battery and you will see the small fuse color white and have a mark of 3.15 at the bottom of the battery socket..
Aug 10, 2007 | Panasonic AG-455 Camcorder
Any have the Panasonic ag-455 SVHS manual?
Hey I think it would difficult to find a manual for a AG-455, though being very similar to the AG-456 (which seems to be more popular) would you be happy with the manual for that model? I downloaded the AG-456 manual from somewhere last year but unfortunately can't remember from where. I do have the PDF file if you're interested though.. Would be happy to send to you if you're interested. Cheers
Nov 15, 2006 | Panasonic AG-455 Camcorder
Panasonic AG-455 Camcorder Logo
235 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
