Question about Kenmore 22422 Top Load Washer
Plese help Kenmore 80 series washer #110.16862503. Was working fine stopped in mid cycle. When you pull start button it buzzes and flickers house power and trips breakers. Took apart and motor coupling is fine. Is it the timer possibly? Before I buy a $100 plus part I need to know. Already had to replace level switch 2 times. Washer is only 1 1/2 years old.
  • 447 Answers
Its hard to diagnose these motor problems...takes a volt-ohm meter with a capacitor checker.... and a lot of knowledge if youre up to it, ill try to help.
Posted on Jan 24, 2008
6ya staff
SOURCE:
How do I check and replace the water level sensor on my Kenmore 80 Series Hvy Dty Washer?
Try eserviceinfo.com/index as per your 80 series. There are various downloads there that may help access the water level sensor which is most likely the problem.
Aug 08, 2014 | Kenmore Washing Machines
Kenmore 80 series washer cycle issue
motor coupler is most likely broken. remove cabinet, remove pump from motor, then remove motor from gearcase. the coupler can be purchased at local parts supplier or ordered on line.
Jan 30, 2012 | Kenmore Washing Machines
I have a Kenmore 80 series model 110 24832200 washer which stopped working mid-cycle. It won't drain and when we attempt to change the cycle or restart it the machine only buzzes. Thoughts?
These machines are direct drive and have a plastic drive coupler which fails. Unplug machine and pull away from wall careful of water and drain connections. Tilt machine back for access to bottom look for the drive coupler between the motor and transmission. It is white plastic on each end with a black rubber piece sandwiched in between. You should be able to tell if it is broken by just moving it by hand. Replace this part and you should be back in business.
Apr 18, 2010 | Kenmore 24902 Top Load Washer
80 Series Kenmore Washer, No draining or spin cycle
It does sound like a controller problem. Go to: SearsPartsDirect.com for parts diagrams and part numbers.
Nov 02, 2009 | Kenmore 22422 Top Load Washer
Kenmore washer won't stop filling during initial wash cycle
I had the same problem too on one of my washers (not kenmore) it didn't complete cycle because someone turned off the hot water valve. soo i turned on the hot water and it worked fine. keep in mind that mine wasn't a kenmore. hope this helps some...
Oct 08, 2009 | Kenmore 24032\24036 Top Load Washer
Mid-cycle my washing machine stopped working.
Could be one of three issues, timer, capacitor, or the most like canidate the motor assm. Usually 90% of the time, its that motor. Those motors are pretty expensive (part number 389248) and you need to replace motor coupler (part number 285753A) when you change it.
Apr 20, 2009 | Kenmore 22942 Top Load Washer
Knemore 80 series dryer won't start every time
Go to www.repairclinic.com and enter your model number and it will show you all your parts, but I suggest you change your thermostats and basically have the dryer cleaned out of possible lint build up on the interior
Mar 20, 2009 | Kenmore Dryers
GOES TO SPIN CYCLE THEN STOPS SUDDENLY AND REFILLS WATER IN TUB
Are you sure you don't have a second rinse button that is selected.
Jan 11, 2009 | Kenmore 24032\24036 Top Load Washer
Your transmission is not engaging thats why the speed changes your making will sometimes get it to work.Honestly any machine after the 10 year age mark is not worth the cost of replacing the transmission.
Apr 15, 2008 | Kenmore 24032\24036 Top Load Washer
I also need the answer...
where is the lint trap located
Dec 06, 2007 | Washing Machines
Kenmore 22422 Top Load Washer Logo
136 people viewed this question
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
