Question about Archos 604 WiFi Digital Media Player
Archos 604 sound problem
When its turned all the way up its not loud enough.
  • 3 Answers
I think the sound out put it self is less.i have read in many fourms that the sound is not loud.but if u r using a ear picks given with the player i suggest u to buy a better ear picks as the archos ear picks are not that good.
Posted on Mar 28, 2008
6ya staff
SOURCE:
Can I charge archos 604 batteries using dvr station and power outlet?
yes you can, however the battery must be inserted into the 604. Simply dock the 604, ensure the dvr is turned on and the 604 will automatically turn on and start charging.
Sep 09, 2010 | Archos 604 Digital Media Player
When i connect my archos 604 to the computer my computer says Please insert disk into Removable disk (G:)?
Hi, ensure your Archos is already turned on before plugging in the USB cable and select HardDrive Mode on the pop up notice. If this dosn't work, once your Archos is ON and plugged in to your computer, press MENU on your Archos and select USB then HardDrive Mode on the next screen. Hope this helps, Shaz
Oct 31, 2009 | Archos 604 Digital Media Player
Archos 604(Gen 4), Remote(Archos DVR Station Gen 5) Work or not?
If you mean will the Gen 5 DVR Station Remote work with a Gen 4 DVR Station, I believe it will for at least the basic player controls on your 604 (except for the alpha keyoard entry because the Gen 4 players did not have this feature enabled).
If you mean, will the Gen 5 DVR Station Remote control your Archos 604 directly (without a dvr dock), the answer is no, you must have a DVR Station for the remote to work on any Archos player.
Hope this helps.
Jun 21, 2009 | Archos 605 WiFi Digital Media Player
ARCHOS 604 WIFI PROBLEM AFTER FIRMWARE UPDATE
if you wouldnt mind losing data then i suppose you could format it and get rid of the firmware update and the put all your stuff back on. only a suggestion.
Oct 27, 2008 | Archos 604 WiFi Digital Media Player
Archos 604 WiFi
as i am planning to buy archos 604 wifi i just wanted to know about the sound quality of the archos 604 wifi?
thanks.
Jan 27, 2008 | Archos 604 WiFi Digital Media Player
Archos 604 wifi sound problem.
Mine is the same it's just not a great speaker you can get "Portable Speakers for Generation 4 portable video" I don't have it so I can't say how good it is.
You can plug in speakers that use the same headphone size and if they have a built in amp and are battery powered then your get good sound.
Jan 24, 2008 | Archos 604 WiFi Digital Media Player
Archos 604 wifi
Are you sure the battery is charged? If so, try detach and retach the battery. Also try to attach to your computer via the usb cable and the 604 should turn on by itself, if nothing happens you need to send back to Archos for repair.
Jan 11, 2008 | Archos 604 WiFi Digital Media Player
Archos
does it have a battery? remove it
does it have a reset?
Dec 10, 2007 | Archos 604 WiFi Digital Media Player
Archos 604 wi-fi
It's sounds faulty, take it back to get repaired.
Oct 04, 2007 | Archos 604 WiFi Digital Media Player
No power going into my archos 604
If the unit was dropped, you may have to replace the battery. The batteries for those units are lithium-ion-polymer and are somewhat fragile when dropped. The other possible reason it is not working is that the shock form the drop has "bricked" or killed your unit's internal circuitry. I would also try charging it with another USB connection as the USB connection you are using may not be powerful enough to charge the unit. For more detailed help you can try the forums at ArchosFans.com There are many technical experts concerning Archos Units at that forum.
Aug 08, 2007 | Archos 604 Digital Media Player
Archos 604 WiFi Digital Media Player Logo
54 people viewed this question
Top Archos Audio Players & Recorders Experts
Marvin
Marvin
 Grubhead
Grubhead
 Mike M
Mike M
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
