Question about Mitsubishi VS-60609 60" Rear Projection Television
"ant A" and "ant B" inputs go black when the tv is first turned on.
I have had a Mitsubishi vs-60609 60 in. for about 8 yrs.. Recently the picture on inputs "ant A" and "ant B" goes out, and all we get is a black screen. After a little while it will come back on for a bit, then shut back off. This goes on for about an hour then everything is fine until the next time I turn the tv on. Any help would be appreciated.
  • 2,336 Answers
Try opening that "Ant A, B" device and apply some fresh solder to all the components inside. Also you can try to by-pass that device using the connector below. One end connects the cable in and the other end connects to the circuitry inside the TV.
Posted on Jan 24, 2008
Mitsubishi VS-55609: No video/audio - just static
You are on the right track. If you cannot see a picture on either antanna A or B then the tuner is suspect.
You may try hooking the cable straight into the TV if you are using a cable box, if not then you should be getting a picture when your other video devices are turned off.
The fact that you get a picture on video tells me that the AV circuits are fine.
Thanks
asnowman
Jul 25, 2010 | Mitsubishi WS-55809 55" Rear Projection...
Cannot connect to cable tv
Yes, connect cable to Ant A and ensure the TV is on the input for Ant A.
Then go into the setup menu and ensure that the Input is set to Cable not Antenna.
Next, choose the auto program option to load your channels.
If you still don't get a picture and you have a small tv to bring to this outlet try this and make sure you are able to get a picture.
If you still can not get a picture then the outlet is not active and you need to call your service provider and ask them to activate the outlet for you.
Dec 29, 2009 | Mitsubishi VS-55707 TV
Mitsubishi VS-45603
You will need to go into the menu, setup, a/v connection, then make sure the locked to input is selected to no..
Good luck..
Sep 17, 2008 | Mitsubishi VS-45603 45" Rear Projection...
Mitsubishi VS-60603 60
this was the perfect solution..my whole family thanks you for this information. It worked in two seconds!!
Jun 22, 2008 | Mitsubishi VS-60603 60" Rear Projection...
TV screen goes blank but power stays on
Sounds like the CRTs are going into protective blanking due to the vertical output ic needing to be resolderd. Try resoldering the vertical IC that may possibly fix the issue.
Jun 15, 2008 | Mitsubishi WS-73713 73" Rear Projection...
Mitsubishi VS-50603, input is gone
happened to me also. Go to the menu, select setting, thrn av (home theater) and see if "locked to input 1" is "on". Mine was. then I set it to "off" and everyting works great
Dec 06, 2007 | Mitsubishi VS-50603 50" Rear Projection...
Mitsubishi VS-60609 60" Rear Projection Television Logo
120 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
