Mold in Washer Dispenser Drawer
My 4 year old washer has dark mold growing n the back of the detergent dispenser drawer tray and housing. Bosch technician said that this growth started in the drum. My question is how did it start in the drum? I do Not have the usual problem with mold around the door seal.
  • yelo Jan 24, 2008
    This seems to be a wide spread problem people are having with front-loader washing machines in the US, according to the research i've done on the web. So why isn't it a problem in Europe where front-loaders have been used for decades?
  • Washing Mach... Master
  • 744 Answers
The washing machine drawer keeps building up mould,this video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your
FREE question.
Posted on Aug 05, 2013
    Novelist:
    Champion:
  • 244 Answers
No its not what it is is the dispenser never gets air to it to dry it out what you need to do is pulcompletely out some need yanking out and some need to be pulled open and then push down at the back and pull that bit more once out u will need to put it in the sink wash the inside and th bottom of it now u will need to clean the inside of the washer were the dispenser goes the mouldwill be bad in there once done u can replace the dispenser now to stop this from happening once the washer has finished its cycle slightly open the soap drawer to let air get inside this will dry it out naturally and wont build the mould up again shown this to alot of my customers and it doesnt happen again let me know how it goes
Posted on Jan 24, 2008
  • peter gittos
    peter gittos Jan 24, 2008
    it does happen alot over here aswell its just maybe its hotter over there then it is in england so its sweeting inside like i say m8 only thing you can do is open the soap drawer just a few mm after cycle as finished after its all been cleaned most of the washers i go out to have this problem
I have a Samsung front load washer WF316BAW. I clean dispenser drawer regularly,today when I removed the drawer I seen mold inside. How do I get rid of it?
Spray Tilex brand mold and mildew remover into the dispenser. Once you have let it sit for awhile wash it out with hot water.
Jun 29, 2017 | Samsung Washing Machines
Leaves detergent in despencer tray
Most of the time this is a dispenser housing issue. Remove the dispenser tray from washer and make sure it is cleaned very well. In the more serious clogs, you may need to clean the hose from the dispenser to the drum.
  1. Make sure the detergent dispenser drawer is opening. This issue occurs due to jammed soap dispenser. Dispenser Distribution System is located in the top left corner of the washer. The system consists of a motor that turns a cam gear. The Detergent Dispenser Assembly is located under the washer top. Begin by removing the washer top, console and front panel.
  2. Separate the water inlet and window washer tube from the boot. Pull the water inlet tube from the outlet connector of the detergent dispenser. NOTE: When reinstalling the water inlet tube, wet the water inlet gasket on the detergent dispenser with water only. Do not use any other lubricant. Align the tab on the water inlet tube with the indentation on the dispenser connector and slide the tube onto the detergent dispenser assembly.
  3. Remove the screw securing the front of the detergent dispenser assembly to the top front frame member.
  4. Disconnect the vent tube from the detergent dispenser assembly. Remove the screw securing the detergent dispenser assembly to the top left frame member. Slide the assembly back slightly and lift the assembly out.
  5. To remove the detergent dispenser motor assembly,disconnect the cam follower spring and lift the cam follower from the diverter cam and rotate the diverter cam clockwise to access the motor mounting screws. Check for all the connections to the dispenser motor or anything obstructing the dispenser drawer functioning.
  6. Pull the diverter out and clean it, including the shaft, spring, etc.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Feb 27, 2011 | Whirlpool Duet GHW9150P Front Load Washer
The rubber seal at the front of the machine has gone mouldy. I have cleaned it before with bleach but the mould comes back all the time
Front loaders are known for building up mold and the smell.
It’s caused by using liquid detergent which is made from animal fat. Use powder. And use the minimum amount.
It’s caused by using fabric softener. Dilute it 50/50 with water.
It’s caused by the water remaining in the tub between washes. Leave the door open to allow it to dry. .
Oct 21, 2009 | Bosch Nexxt 700 Series WFMC6401UC Front...
How to take a washers detergent tray out
You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub.
Pull the dispenser drawer completely out.
There is a tab that needs to be depressed to release the drawer and remove it.
Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening.
Reach down into this opening to see if an item is inside the hose.
This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 27, 2009 | Kenmore HE2 Plus Front Load Washer
Detergent dispenser clogged-Kenmore 90 series washer
http://media.fotki.com/1_p,wbwdbgswgksbgfwxgtqsskgwtqkq,vi/ktfgsrbbdxwtwtqtfwk/1/1303472/5961857/image45924img-or.jpg
Jun 16, 2009 | Kenmore 24902 Top Load Washer
A mold smell from my washing machine
IMPORTANT: Read thoroughly. DO NOT add detergent or other laundry products to this cycle.
1. Remove all items from the washer.
2. Open the dispenser drawer and 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment. DO NOT use more than 2/3 cup (160mL) of bleach per cycle as this will lead to product damage.
3. Close the washer door and dispenser drawer.
4. Select the Clean Washer cycle or a full wash cotton 104 F wash (40 C). DO NOT use any higher temperature as this will cause unnecessary fumes
5. Press Start and allow cycle to complete.
6. If the bad odour persists, repeat the procedure 1 or 2 more times. This may be necessary if this is the first time you have run this cycle.
7. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
8. Repeat the cleaning procedure monthly.
To maintain the washer freshness:
1. Use only HE High Efficiency detergent.
2. Leave the door open after each cycle to for better ventilation and drying of the washer interior.
3. Use warm / hot water in your machine unless the fabric you are washing requires cold.
4. Use the correct amount of fabric softener.
5. If your laundry room is damp, use a dehumidifier.
6. Clean the door seal of visible residue.
Dec 28, 2008 | Bosch Classixx WFO 2466 Front Load Washer
Maytag Neptune Washer dispenser unit has mold and mildew inside top of dispenser compartment.
You can pour the bleach in the drawer every time you do white loads and it will stay clear too!
Just flush it out good before you do colored clothes or you may get a small bleach spot on a red shirt !
Neil
Ps. Give me a problem solved rating here on fixya.com
Aug 19, 2008 | Maytag MAH6700AWW Neptune Front-Load...
Water is leaking out of detergent dispenser- big time
Water pressure may be too high,try turning the cold water feed pipe (usually the blue one)down a little,not too much though.If this does not solve it,is the machine lying level front to back? If not pack up the front of washer until level.If still no good take out dispenser drawer completely check for obstruction inside housing of machine. Also while drawer is out clean the underside or top of dispenser housing with an old toothbrush or similar tool,(you will see several pin holes where the water comes out when filling).To take out dispenser open drawer fully and there should be a clip at top back of drawer that you push while pulling drawer at the same time.Hope this is useful to you.
Aug 24, 2007 | Haier XQG50-11 Front Load Washer / Dryer
Whirlpool duet washing machine
Make a boil wash (with no clothes and detergents) put in the powder's drawer a cup of bicarbonate of soda. It should clean the machine and move out the bad smell. Good luck!
Aug 06, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
560 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
